How to Turn off Voice Control iPhone in the Easiest Way
Voice Control is a feature that responds to your voice commands and lets you control small operations like volume adjustments, opening apps, playing music, and sending personalized text messages without touching your phone. If you want to turn off Voice Control iPhone, read out the steps mentioned in this guide ahead.
How to Turn Off Voice Control iPhone?
You can disable Voice Control from your device settings. After you turn off Voice Control, your voice commands will be restricted.
Check out the steps to turn off Voice Control iPhone.
Method 1: Using Settings
  1. Open your Settings.
    Tap on Settings
  2. Tap Accessibility.
    Tap on Accessibility.
  3. Open Voice Control.
    Open Voice Control.
  4. Turn off Voice Control.
Method 2: Stop Voice Control from Side Button
    Open Settings.
  2. Open Accessibility.
    Open Accessibility.
  3. Tap on the Side Button.
    Tap on the side button.
  4. Under Press and Hold to Speak, tap Off.
    Turn it off.
How do I Turn off Voice Control or Siri on my Headphones?
You can easily turn off these settings. Open your Settings, tap Face ID & Passcode, then scroll down, find Voice Dial, and turn it off, then find Siri and turn it off. Check out the steps with images below.
    Open your Settings.
  2. Tap on Face ID and Passcode.
    Tap on Face ID & Passcode.
  3. Scroll down and find Voice Dial.
    Scroll down, find Voice Dial, and turn it off.
  4. Find Siri and turn it off.
Your iPhone Voice Control feature can be very helpful when you need to use your iPhone hands-free. But it quickly becomes a problem when you activate it accidentally while typing. With the help of this guide, you can turn off voice control iphone, and for more such video guides, check out the Getassist YouTube channel.
How to stop iPhone Voice Control?
You can easily stop Voice Control; follow these simple steps: open Settings, open Accessibility, find Voice Control, and turn it off.
Will disabling Voice Control affect dictation features?
Disabling Voice Control doesn’t affect your ability to dictate text and email through your keyboard.
Why does my iPhone keep going to Voice Control?
Open Settings, go to Accessibility, then open Voice Control and turn it off to prevent it from turning back on again.
How do you reset Siri voice control?
Go to Settings, search for Siri, tap Siri, then tap Talk to Siri, turn off Listen to Siri, and turn it back on.
What should I do if my phone is stuck on Voice Control?
Try to restart your iPhone. If you don’t know the shortcut, press and hold Power and Volume Up.
What’s the difference between Siri and Voice Control?
Siri and Voice Control are similar, but Siri needs internet access, while Voice Control doesn’t.
