How to Screen Record on Chromebook?
| Updated on October 15, 2026
How to screen record on Chromebook? The Simplest Method For Everyday Use
Tired of finding download links for educational videos, fetching project documents, and your important lecture recap, and want to find a solution that will help you to instantly capture them on your Chromebook?
Then don’t worry; if you learn how to screen record on Chromebook you won’t have to struggle again to find and install necessary video units. You can save the recorded files in your preferred device folders also. Read till the end to understand the complete step-by-step process.
Quick Answer
You can record your screen using the built-in tool by pressing Ctrl + Shift + Show Windows. After recording, you can save your files in your desired folders or create a new one for them.
Screen recording on a Chromebook can be done using this simple method, which requires only the keyboard and a few simple steps using the cursor. Follow the process in complete chronological order.
  • First of all, on your keyboard, press the shortcut key combination of Control+Shift+Show Windows.
    On your keyboard, press the shortcut key combination of Control+Shift+Show Windows.
  • A function bar will appear. Click on the Screen Record button.
  • A toggle will appear, from which you can choose between three options: Full Screen, Partial Screen, or Window Screen.
    Choose between three options: Full Screen, Partial Screen, or Window Screen.
  • After a countdown of 3 seconds, the Chromebook will start the screen recording process.
  • In the bottom right of the display, you will find this red button. Click on it to stop recording when you are done.
This way, you can easily download and save all your recordings to your device without any internet usage or third-party tools.
Where to Find All the Screen-Recorded Videos on Chromebook?
You can find all your screen-recorded videos in the folders you want. All you need to do is make a few tweaks in the screen recording toggle. Note the variations carefully to find your saved files without any hassle.
  • Click on the Settings icon.
  • By default, all your screen recordings get saved in the Downloads folder.
  • You can create a new folder like ChromebookScreenRecord to find all your assets in a separate destination.
  • Or, you can save recordings in different folders on your Chromebook by clicking on Select folders.
    Save recordings on different folders on your Chromebook by clicking on select folders.
This is how you can save all your recordings in your desired folders and find them whenever you need.
In conclusion, recording your screen on your Chromebook is fast, easy, and doesn’t require any special software. You only need to press the Ctrl + Shift + Show Windows keys, and this will allow you to record either your complete screen, a region, or a particular window in a few seconds! So if you need to record a class, produce a how-to video, or help someone with a problem, you are in the right place. Don’t forget to follow GetAssist for more such informative quick guides.
1. What does Ctrl+Alt+Z do on a Chromebook?
Ans: Pressing Ctrl + Alt + Z on a Chromebook turns the built-in ChromeVox screen reader on or off. It is a spoken feedback tool that reads and speaks all the information present on the screen.
2. Does Chrome allow screen recording?
Ans: Google Chrome does not have a built-in, native screen recorder built directly into its core settings, but you can record your screen by installing an official extension like the Google Vids Screen Recorder Chrome Extension or other third-party tools from the Chrome Web Store.
3. What does Ctrl+Shift+L do on Chromebook?
Ans: This shortcut immediately secures your computer when you step away by locking it. To unlock the screen and return to your work, you must type your Google Account password or PIN.
Sources
Rajesh Pandey
iOS and Gadgets Writer
