Facing technical glitches with an email service is no new thing. Every one of us owns an email account to manage our professional and social life and it can easily get us annoyed if we face problems while sending or receiving emails.
SBCGlobal is a leading email service that has its roots back to 1882. Since then its loyal users are using it no matter what issue they face, me being one of them.
Lately, I got to know so many users are not able to send or receive emails using their SBCGlobal account and are unsure about where to get help. Let me tell you that this is an occasional glitch where you face errors in sending or receiving emails and can be resolved easily after checking a few things and doing the required troubleshooting.
Today, in this guide, we will discuss all the factors due to which SBCGlobal email is not working and why you are not able to work with emails along with the solutions.
Why SBCGlobal is not Sending or Receiving Emails?
Before learning how to fix this error, it is important to know what is causing them in the first place. There can be several reasons for which you are not receiving any emails or aren’t able to send one, as listed below:
- The emails are going in the wrong filter.
- Email forwarding is on
- Incorrect email address
- Sender is in block list
- You are blocked by recipient
- Incorrect configuration on third-party email application
How to Fix “Can’t Send or Receive Emails” Error with SBCGlobal?
After knowing the reasons, here are the troubleshooting steps that you need to apply to fix the error:
- Incorrect Email Filter
- Sender is Blocked
- Recipient has Blocked You
- Email Forwarding is On
- Entering the Wrong Email Address
- Incorrect Email Configuration
- Server is Down
- Wrong Server Address
Email filters are created to filter the incoming emails and direct them towards the stipulated folder. Creating filters to keep email account organized is helpful but it can get you into uninvited trouble if you have created wrong filters i.e. the emails that are meant for a filter have been set to be received under some other filter. So while creating filters you need to be extra careful so that no such incidents happen. Also, if you are not sure how to correct the mistake, you can simply delete the filters and then check if you can receive emails.
You are expecting mail from someone and have blocked the same person mistakenly. Yes, this can be one of the reasons for which you are receiving any email on your SBCGlobal account. So, go and check your block list and make sure you haven’t blocked someone you shouldn’t.
If you are sending a mail to someone and the other person hasn’t received it even after several attempts, ask him to ensure that your SBCGlobal email address isn’t there in his block list.
The purpose to enable email forwarding is to receive your SBCGlobal emails on some other email account for any reason. So if you have enabled email forwarding for your SBCGlobal account and have forgotten about it, it is the time to log in to your SBCGlobal email account and turn off the email forwarding.
If you are sending a mail to someone and they haven’t received it, make sure you are entering the correct email address. Also, if you are expecting an email from someone, tell them to enter your correct email address and then check if the error has been rectified.
If you have been using SBCGlobal email on any third-party email client like Outlook, configuring the account incorrectly can get you in this trouble and you will be left wondering why you are not able to send or receive emails. SBCGlobal will not work with Outlook if the sbcglobal.net email settings are incorrect.
If you still cannot send and receive SBCGlobal emails, verify that if the server is down. The problem can also appear when the SBCGlobal is down and you will face errors while sending emails. This may also stop you from receiving any email. For this matter, you can wait till the SBCGlobal email support team restores the services, and the server starts working again.
Email services keep on changing their server addresses even without informing their users. You will not be able to send or receive emails in your SBCGlobal email account if the server address was changed and you are still entering the old address. For this, you can contact your network administrator and get the new address to log in to your SBCGlobal account.
READ NEXT:
Recover Deleted Email from Sbcglobal
Sbcglobal Email Settings (IMAP or SMTP)
Can’t Log into Sbcglobal Email
