How To Restore A Snap Streak? Simple Methods And Tools Uncovered
| Updated on July 3, 2026
Breaking regular streaks with best friends and family by accident seems a bit depressing, as that count shows how much effort two people are putting into staying connected.
But thankfully, there are two effective ways that can bring back your streak count in minutes. Follow along and learn how to restore a snap streak using the restore button and official Snapchat support help.
At a Glance
To restore your streak on chat with someone, you have two official methods:
  • Restore Streak: From here, you can restore up to 6 free streaks, and after that, you have to pay for restoration.
  • Snapchat Support: If you have a genuine issue that caused the breakdown of your streak, then you can submit your reviews on https://help.snapchat.com/hc/en-us, where your reasons are validated and solved by experts.
How To Restore a Snap Streak in Few Easy Steps?
There are two effective ways to revive a lost snapstreak: the first one is the Restore Button, which pops up immediately after the streak dies, and you will get 6 free tokens to revive streaks, which can be used with one person or with 6 different people.
The second method is a bit lengthy, as you have to visit help.snapchat.com and add crucial details about yourself, along with the reason that caused the deletion of your snapstreak.
Let’s break down the process in detail one by one.
Restore Button
The restore button on your Snapchat profile is an easy-to-access toggle that restores your snapstreak in just a single click and protects your snapscore on snapchat from getting reduced. All you have to do is:
  • Open Snapchat
    Open Snapchat
  • Tap on the orange Restore button.
    Tap on the restore button
  • Then again, tap on the Restore button.
    tap on restore again
Official Snapchat Support Window
If somehow the restore button is not visible while your streak is broken, the official snapchat support window can do the job.
  • Then select the concern, which is “ I lost my Snapstreak.”
     Select the concern
  • In the redirected page, select “Fill out this form.”
     Tap to fill out this form
  • Then fill the form with all the credentials like username, email, mobile number, etc.
    Add details
  • Here comes the most crucial part, as you have to add some important details like “ How long was your Snapstreak before it expired?’ and “Did you see the ⌛”(Hourglass icon), which is optional.
    restoring snap streak
    Add important information
  • Lastly, provide a concise description of your situation and the reason for the error.
    Add Description information
  • After all this, your ticket request is generated, and you will get a response within the next few hours.
     Ticket Generated
Why Snap Streak Disappears And How To Avoid It?
Tired of breaking snap streak again and again, well, this happened because of some common human errors like:
  • Neglecting 24 hours cycle: Losing streak by not sending a snap in the 24 hours is the biggest reason that breaks the snap streaks of most people.
  • Ignoring ⏳ (Hourglass icon): Not showing attention to the Snapchat hourglass icon, which indicates the countdown of 4 hours, will cause all your days of connection to vanish.
  • Sending inappropriate content instead of snaps: Images, videos, and voice notes are not counted as snaps; most people send them and think they maintained their daily streak just to realise they have to restore it the next day.
  • Forgetting to open the app: Not opening the app for even one day can disrupt years of streak with your friends and family, that is why adding reminders in your mobile about sending snaps is important if you have a hectic schedule.
Then, how to maintain the streak?
  • Fix the streak timing every day, as it makes you consistent
  • Keep an eye on ⏳ (Hourglass icon) because it is a pivotal countdown indicator that will show you the 4-hour period to send the streak
  • Buy its premium called Snapchat Plus, as it is “Instant Streaks”.
Restoring a streak on Snapchat with free tokens is the easiest way, while the Snapchat support window takes time in authentication, and paid restoration can hurt your pocket. You should stay attentive on the app for at least 10-15 mins and send a streak snap even if you are not having a good day.
Still, if you have missed the chance or got out of the token due to a serious reason, then show faith in the meta admins or pay to restore instantly. Got more errors like this in your digital handles? Make sure to stay connected with GetAssist for daily troubleshooting blogs.
How long is the ⏳ on Snapchat?
Well, this is the hourglass indicator that pops up on the profile of your friends whenever your streak is about to expire. This icon starts showing after 20 hours of your last, enabling a countdown of 4 hours to restore your streak by sending a snap.
How long is a 2000-day streak on Snapchat?
A 2000-day-long streak is approximately 5 years, 5 months, and 25 days, which makes it 65 months long and a great achievement of the bond between two people.
How long does 💛 last on Snapchat?
Yellow heart represents the bond of the #1 best friend on Snapchat, and it stays for a week.
