How To Increase Download Speed? 10 Easy Methods To Make Installation Faster
Being stuck on the download screen for hours or watching your favourite shows with a lot of buffering can easily ruin your day. Instead of sitting idle in frustration, you can easily understand how to increase download speed and upload capabilities of your internet using a few easy methods. This detailed GetAssist guide mentions them, along with some reasons that are disrupting your internet experience.
GetAssist in Glance
To increase your download speed, you must:
  • Download Files One by One
  • Disable  Auto Updates
  • Restrict Unwanted Device Disconnection
  • Constantly check Routers and Modems
  • Use Ethernet connections
  • Prevent background download activities
  • Update to the latest operating systems
  • Use VPN
  • Switch to faster plans
  • Check for viruses
How To Increase Download Speed? 10 Simple Steps
How To Increase Download Speeds
Increasing the downloading speed of your internet is not a complicated job; in fact, you just need a little bit of presence of mind to fix the areas that are disrupting the flow of connection, or in some scenarios, you just need to change some of your habits.
Here is how to increase download speed:
Method 1: Downloading Files One by One
Selecting and setting up downloads of multiple files of apps, videos, and games can slow down the entire system of the internet and make your PC throttle in some cases, which also leads to slow download speeds as each file is consuming heavy chunks of data to get stored in your devices. The best practice here you can do is to download files by priority and avoid unwanted installations.
Method 2: Disabling Auto Updates
Sometimes everything seems perfect on the internet connection, but speeds are still flickering on your desktop, and you’re left to wonder what went wrong. That’s because there are chances that some software programs and applications are auto-updating themselves, and you forget to disable that setting. Turning off auto updates can provide an instant change in downloading speed, as the backend burden on the internet has been relieved.
Method 3: Unwanted Device Disconnection
In scenarios where the bandwidth security is weak, any random person can connect and access the internet. If your setup is also like this, then it can seriously damage your overall online integrity, along with a massive depreciation in download and upload speeds. To avoid this situation, simply keep your WiFi passwords more personal (like using slang only your close ones know) or use system authentication for strong password suggestions.
Method 4: Modem and Router Testing
Regular evaluation of modems and routers is important to ensure that all the technical aspects of internet connections are working well and there are no loose ends in the signal transmission. This maintenance helps to resolve faults or micro-damages that might be affecting the actual WiFi speed. Testing of these utilities can be done by experts, but if you are eager to do it yourself, then there are plenty of tutorials available on the internet.
Method 5: Use An Ethernet Cable
An Ethernet cable is a wire that connects your systems (specifically laptops and PCs) directly to the router or the internet modem. Through this fiber Internet transmission, it becomes almost impossible for any element to break the protocol or reduce the speed of your connection. As this projection is done by hardware utilities, factors such as unwanted and multiple connections completely vanish.
Method 6: Stop Background Downloading
Background downloading is one of the most common human errors that decreases the download speed, as many websites or applications take permissions on login pages for backend installation, which most people ignore. Disabling the background downloading on your desktop can boost your internet stability for crucial operations.
Method 7: Complete All the Latest Updates on Your Devices
Whether you use the internet on your Windows PC, MacBook, Android phones, or iOS devices, updating your devices with regular patch notes and software versions should be your priority because sometimes internet disruptions happen because of system bugs and glitches, for which we blame our ISPs and routers.
Method 8: Use VPN
Using a VPN is a very clever move to speed up your downloads as there are so many websites and applications that don’t perform well in specific regions, but through proxies, you can install things easily without any regional limitations. Some VPNs also block the unnecessary ads and pop-ups that drain unwanted data from your bandwidth.
Method 9: Buy a Faster Plan
Switching to a faster router company instead of Nomad Internet services is the ultimate solution if any of the above methods don’t work, as you will see a sudden enhancement in the overall internet speed the moment you buy the latest high-speed subscription. Many people are shifting from regular 40-50Mbps plans to higher variants of 100-200 Mbps, as this brings a slight increment in monthly charges but a noticeable difference in performance.
Method 10: Check Your Device for Viruses
External threats and viruses uploaded from malicious links in the systems can disrupt the overall well-being of your devices while simultaneously damaging your data speeds. The best way to stay away from them is by visiting with security protocols and never downloading anything from third-party sites.
What Factors Affect the Download Speed?
Factors Affecting the Download Speed
The speed can be increased with some tweaks in your systems or the router, but not by configuring and fixing the factors that are affecting the internet project, which is the main culprit that is breaking your experience. Most of the users ignore common problems of internet wreckage, like:
  • Speed Restrictions: Sometimes, the internet service providers put constraints on the actual speed limit of your data by providing low-quality bandwidth. Make sure to ask them for the deployer’s new-gen sustainable router systems.
  • Multiple Device Connections: Connecting multiple devices to one single internet system can hamper the speed of downloading or uploading experiences and break your content consumption through constant loading breaks.
  • Router range: Wireless routers have a limited range, and going out of it can decrease the connectivity strength and provide discomfort while using your PC.
  • Specs of Devices: It has been very frequent that many people keep fixing their internet bandwidths, but the actual problem lies within their systems, as older devices have slow network modems that cannot retrieve high-speed data.
Constantly boosting download and upload speed nowadays has become necessary as utilities, applications, games, and videos are getting frequent updates for optimization and new enhancements. That’s why having high-speed routers or Ethernet connections is very pivotal for both casual purposes and professional workspace management.
Increasing download speeds using methods like router upgrades and faster plan subscriptions can provide an instant fix in the situation; however, other methods are effective too. If you want to learn about tips and insights about other digital domains, also make sure to follow GetAssist.
Is 2.5 Mbps fast or slow?
Considering the usage of modern applications and today’s online ecosystem, 2.5 Mbps is very slow as today there are internet services who are providing average speed of 100Mbps.
Was the Internet big in 1996?
Well, in 1996, the internet wasn’t that big as there were only 45 million people across the globe who had access to use global domains, and companies like Google and Microsoft were growing.
Is Wi-Fi slower than Ethernet?
Yes, Wi-Fi is slower than an Ethernet cable because of wireless connectivity; the speed is constantly hindered, whereas with a wired Ethernet connection, users experience stable networks and better speeds.
