How to Delete Tabs on iPhone, Mac, Android, and Windows
| Updated on September 21, 2026
You can easily delete tabs on any browser in just a few clicks. After deleting the tabs, you will lose all the unsaved data on that webpage. There are slightly different steps for different browsers. How to delete tabs at once. Let’s follow this guide and delete all the unwanted tabs.
How To Delete Tabs On iPhone And Android
You can delete tabs in Chrome on Android easily, and clear cache on Android will decrease the risk of viruses and malware and protect your personal information and data from viruses and malware. It also helps to increase performance and battery backup by reducing CPU and memory usage.
For Android
  • Open Chrome on your device.
  • Open tabs in Chrome.
  • Tap on the three-dot menu.
  • Tap on Clear all tabs.
    Tap on Close all tabs.
For iPhone:
  • Open your Settings.
    Open Settings.
  • Scroll down to Safari.
  • Tap on clear history and web data.
    tap on clear history and web data.
How To Delete Tabs On Windows and Mac?
  1. Let’s delete tabs on Windows. It is equally important to delete open tabs and background tab history to prevent any kind of viruses and malware from entering the system and to reduce CPU and memory load. Let’s discuss how to delete tabs on Windows step by step.
    • Open Chrome on your Windows PC.
      Open Chrome.
    • Open any tab.
      Open tabs.
    • Click on the close icon on the tab you want to remove.
      Click on this icon to close the tab.
  2. Let’s delete tabs on Mac in just a few easy steps. There is no security compromise on Mac, but they consume memory and CPU and slow down performance.
    • Open safari on your mac
      Open Safari
    • Open tabs in Safari.
      Open tabs in Safari
    • Left-click on any tab to open a menu.
      Right-click on the tab to open the menu
    • Click on Close Other Tabs to remove all the tabs except the one you right-click on.
      click on Close Other Tabs to close all the
What Happens After You Delete the Tabs?
After deleting the tabs, they disappear, and you lose all the unsaved information and data on that tab. You can recover your deleted tabs easily in the browser history. After deleting the tab running, on you memory usage will decrease, and performance will increase. You can use a shortcut to recover your deleted tab on Windows and Mac: for Windows, Ctrl+Shift+T, and for Mac, Cmd+Shift+T.
It is important to delete old tabs or tabs you are not using; those tabs run in your memory in your device’s background, which causes many problems like high memory usage, high CPU usage, a laggy experience while using your device, less battery life, and viruses. Regularly clear the old open tabs that you are not using; you will see the performance difference instantly. In this guide, we show you how to delete tabs on your iPhone, Android, computer, and Mac. For more such guide videos, check out the Getassist YouTube channel.
Can I bring back deleted tabs?
Yes, you can bring back deleted tabs in Windows by clicking Ctrl+Shift+T, and for Android or iPhone, you can check the deleted history in your browser and find all the deleted tabs.
Can I see a history of closed tabs?
Yes, you can see the history of closed tabs in Windows. Press Ctrl+H, and on a phone, open your browser, click on the three dots, and open browser history.
Do tabs close automatically?
No, tabs do not close usually unless you use a specific setting or browser extension.
Can someone see my Chrome history?
Yes, anyone can see your Chrome history if they have your device, if you share your synced Google account, or if they manage your network.
Why can’t I delete my tabs on my iPhone?
You are not able to delete your tabs cause of a temporary software glitch or a frozen browser. You can just restart your device.
