How to Clear Cache on Android: 3 Ways to Optimize Your Device
| Updated on September 3, 2026
If the apps on your device or your whole system have become slow and laggy, clearing the cache helps your system remove temporary data, free up storage, reduce app lag, and make apps and the system run faster.
By knowing how to clear cache on Android, you can simply make your device and apps run smoother with just a few taps. Go through this whole article and learn 3 ways by which you can clear cache on Android.
3 Ways to Clear Cache on Android: Explanation and Details
There are a total of 3 ways by which you can clear the cache on your Android: clearing system cache, clearing app cache, and clearing browser cache if your browser is facing issues like slow load times.
Clearing System Cache
If the storage on your device seems to be full, or the device is lagging, you can clear the system cache to free up some storage and make your device work smoothly.
The steps to clear the system cache are:
  • Open Settings on your device.
  • Tap and open Device Care.
  • Tap on Memory.
    Tap on Memory
  • Tap on Clean now to clear all the cache data.
    Tap on Clean now
Clearing App Cache
If your device is working fine but one of your apps is unresponsive or not working properly, then you can also clear the cache of that particular app.
Here is how to clear cache on android:
    Open Settings on your phone
  • Tap on Apps in Settings.
  • Select the app that is lagging or not working properly.
  • Tap on Storage.
    Tap on Storage
  • Tap on the Clear cache option at the bottom.
Clearing Browser Cache
If your web browser is facing issues like lag and slow load times, you can clear the cache of your web browser for it to work better.
The steps are:
  • Open the Chrome app on your device.
    Open the Chrome app
  • Tap on the three dots in the top-right corner
  • Tap on History from the pop-up menu.
  • Tap on Delete browsing data.
  • Select your desired Time Range.
    Select your desired time range
  • Check the cached images and files option.
  • Tap Delete data to complete the process.
    Tap Delete data
Notes
The steps may vary slightly depending on your Android device, as the user interface and software experience can differ between manufacturers and device models.
Clearing the cache from your device helps you fix lagging and crashing and also helps you get your phone storage back – and that too without deleting your personal information, photos, saved passwords, or account logins.
In case you are still facing these problems after trying all the 3 ways, consult an expert for guidance. Also visit the GetAssist YouTube channel for such troubleshooting concerns.
Q1. Will clearing my cache delete personal files?
Ans: No, clearing your app cache will not delete any of your personal files, photos, music, or downloaded documents. Cache removal targets only disposable files that are making the device slow.
Q2. What is the difference between clearing cache and clearing data?
Ans: Clearing the cache only removes temporary files used to load pages or app elements faster. Whereas clearing data or storage completely erases everything, such as your account login details, saved passwords and more.
Q3. How do I find which apps take up the most cache?
Ans: You can easily see the applications by opening your phone’s Settings app > Storage menu, then tap on Apps or Other apps to see the list of everything installed on the device. Tap the three-dot menu icon in the upper-right corner and select Sort by size.
