How to Check RAM Speed in Windows and Mac?
| Updated on September 23, 2026
Checking RAM speed in Windows and Mac is equally important because RAM is one of the most important hardware and software components.
You can upgrade your RAM in two ways: speed or GB. Both of them play an important role in the performance of the operating system; the more RAM, the more software you can use at once, and the higher the RAM frequency (speed), the more responsive your hardware is.
In this article, we will show you how to check RAM speed in both operating systems, Windows and Mac.
How to Check RAM Speed in Windows? 4 Tried and Tested Methods
RAM speed matters a lot in any operating system, especially your daily work system. Always use a good amount of RAM with a higher frequency (speed). You can check your Windows system RAM speed in many different ways. You can follow any one of the following to get to know how to check RAM speed.
Method 1: Check RAM Speed with the Taskbar
  1. Press Ctrl + Shift + Esc to open Task Manager.
  2. Click on the Performance tab.
  3. Then click on Memory.
    Click on the Memory tab
  4. Here you can see the RAM speed.
Method 2: Check RAM speed with Command Prompt
  1. Click on the Windows search bar and search for Command Prompt.
    Search for Command Promptt
  2. Run CMD as administrator.
    Run Command Prompt as admin
  3. Type this command: wmic memorychip get speed and press Enter.
    Type wmic memorychip get speed
  4. The results show the RAM speed.
    Here you can see the RAM speedd
Method 3: Check RAM speed with PowerShell
You can use PowerShell for detailed information about RAM.
    Click on the search bar
  2. Search for PowerShell.
  3. Run PowerShell as admin.
    Run as admin
  4. Type this command: Get-CimInstance Win32_PhysicalMemory | Format-Table Manufacturer, Speed, Capacity
    Type Get CimInstance Win32 PhysicalMemory Format Table
  5. Press Enter.
  6. Here you can see detailed information about RAM.
    Here you can see the RAM speeed
Method 4: Check RAM Speed with a Third-party Application
There are many third-party applications that help you find the RAM speed on your device, but there is a high risk of using third-party applications; try to avoid using unauthorized apps.
How to Check RAM Speed on MAC?
There are 2 methods to check the RAM speed on a Mac; you can follow any of them to find your RAM speed.
Method 1: Check RAM speed in the About This Mac option
  1. Click on the Apple logo in the upper-left corner
    click on the Apple logo.
  2. Then click on the Memory option.
    click on Memory
  3. Here you can see the RAM speed.
    Here you cann see the RAM speed
Method 2: Check your RAM by using Terminal
  1. Open the Terminal on your Mac.
    Open Terminal
  2. Type this command.
       system_profiler SPsoftwareDataType
    Type system_profiler SPsoftwareDataType
  3. Press Enter.
  4. Here you get details about RAM.
    Heree you can see the RAM speed
RAM is one of the most important parts of the operating system. RAM handles so many tasks at once, and if you have faster RAM, your operating system will respond quickly.
Always check your system’s RAM speed, whether you are using Windows or Mac. You can follow this guide to check your RAM speed on any device. For more such video solutions, you can check out our Getassist YouTube channel.
How do I know if my RAM is 3200MHz?
You can easily check your RAM speed with the built-in feature in the taskbar. Go to the Performance tab, then click on Memory; here you can see the RAM speed.
Is 6000-speed RAM good?
6000MHz is the best and the sweet spot for most modern and high-performance desktops.
Will 4000 MHz be better than 3200 memory speed?
Yes, 4000 is better than 3200, but there is a very small noticeable difference. You can see a difference in CPU-intensive tasks.
Is 64 GB of RAM overkill?
Yes, 64 GB of RAM is overkill for most of the people. It will be better for extreme-level multitasking.
Is 95% RAM usage bad?
Yes, 95% RAM usage shows that you need more RAM in your operating system. 95% RAM usage will also make your device freeze and experience lag.
