How to Check Motherboard on PC? (Tried and Tested Methods)
| Updated on October 5, 2026
A motherboard is the most important part of any hardware; it connects all the other components together. All components includes the CPU, GPU, RAM, and storage.
All upgrades and BIOS updates depend on the motherboard model. In this guide, we will show you how to check Motherboard on pc in two different built-in methods. One is from Windows Run, and the second is with Command Prompt.
You can check your motherboard model without stripping down the hardware. There are two built-in methods to how to check motherboard on pc. There is a chance that your motherboard needs repair if your computer randomly restarts.
Always make sure your motherboard works perfectly because a faulty motherboard can damage other components.
Method 1: Using The Windows Run Command(msinfo32)
  • Press Windows + R to run a windows run popup.
    Press Windows R
  • Type this command (msinfo32).
    Type msinfo32
  • Press Enter.
    Press Enter
  • Click on System Summary.
    click on system information
  • Here you can see all the system information, including the motherboard.
    Here you can see the motherboard information
Method 2: Using Command Prompt
  • Click on windows search bar.
    Click on the search bar
  • Search for Command Prompt.
    search for command prompt
  • Run Command Prompt as admin.
  • Type (wmic baseboard get product,manufacturer,version,serialnumber).
    Type this command wmic baseboard get product manufacturer version serialnumber
  • Click Enter.
    Click Enter
  • Here you can see motherboard information.
    Here you can see the motherboard informations
Why Is Identifying Your Motherboard Important?
Identifying your motherboard is very important because it will help you check the upgradeability of your hardware. The motherboard creates a link and connection between other components. Identifying your motherboard is important for:
  • Upgradeability of hardware like CPU, GPU, and storage.
  • To check RAM, like the maximum frequency, amount, and the slots for RAM.
  • BIOS updates: the latest BIOS can increase performance and unlock new features.
  • Wi-Fi and Bluetooth connectivity and version.
The motherboard is the essential part in the operating system; it connects all the components and makes an operating system. All the upgrades, like hardware and software, depend on the motherboard version.
You can check the motherboard version without stripping it down with the help of 2 built-in features in Windows. In this guide, we show you how to check Motherboard on pc in two easy methods. For more such video solutions, you can check out our Getassist YouTube channel.
How do I test my PC motherboard?
You can test your motherboard outside the pc cabinet with basic components like a CPU, power supply, and RAM. Always place your motherboard on a non-conductive surface.
How to find the CPU and motherboard model?
To find out the CPU model, go to the taskbar, click on the Performance tab, then click on CPU; here you can see the CPU model.
To find the motherboard model, press Windows + R, type msinfo32, and hit Enter; here you can find the motherboard model.
What are the symptoms of a dead motherboard?
  • Physical damage.
  • Unstable power response.
  • Random shutdown.
  • All the other components stop working.
  • No power response.
Can a motherboard be repaired?
Yes, a motherboard can be repaired, but it also depends on the damaged component or area.
How can I tell if I need a new motherboard?
  • Unstable power supply to the components.
  • You want to upgrade a component, and the motherboard doesn’t support it.
  • Random crashes.
  • Dead USB ports.
