Apple Boxing Day Deals: Which Device Is Worth It?
| Updated on November 9, 2026
Apple offers a wide range of useful devices and related products. That is why, when a sale happens, everyone is mad about buying whatever they can afford. But the real question in such situations should be which device will genuinely serve you the best. Only invest in what is truly worth it.
And if you are exploring the Apple Boxing Day deals at The Good Guys, this comparison provided below has brought you the right perspective! Get insights for maximum clarity. The ultimate goal of this guide is to help you find which device will be the most suitable in your situation.
iPhone: the everyday essential
For most people, the phone is the first and most important device to consider. It is the one you use all day long, so improvements in camera, battery, & speed are felt immediately. If your current phone is slow or no longer receives updates, an iPhone upgrade is the right option. It will usually deliver the most noticeable benefit for the money.
iPad: the flexible middle ground
An iPad can be rightly positioned between a phone and a laptop. Apple’s iPad compare page lists many items, such as the current lineup, including the iPad Pro in 13- and 11-inch sizes with the M5 chip, iPad Air in 13- and 11-inch sizes with the M4 chip, the standard iPad with the A16 chip, and the iPad mini with the A20 Pro chip. The page shows how weight varies, from about 255 grams, when compared, for the iPad mini to 579 grams for the 13-inch iPad Pro Wi Fi model. That range makes the iPad easy to match to how you are going to use it, whether you want a light reader or a large canvas for creative work.
MacBook: the productivity powerhouse
A MacBook is the strongest choice if you write, code, edit video, or run several apps at the same time. Compared with an iPad, it offers a full keyboard, more flexible file handling, and better multitasking compared to other devices on our list. It also costs more, so it makes sense if you use it for work-related tasks or even your studies.
Weigh portability against power
Ask yourself where you will use the device most. A phone is always in your pocket. An iPad slips into a bag. But a MacBook is better suited to a desk. If you travel often, the lighter devices are going to be the right pick. If you sit at a desk, power and screen size will matter more.
Consider your accessories
Many devices need extras to reach their potential or if you want to do more with them. An iPad becomes a drawing tool with a Pencil, and a keyboard turns it into a mini laptop, boosting its functionality. Add the cost of accessories to your comparison, since they can change the total cost between an iPad and a laptop.
Think about longevity
Check how long a device will get software updates and how much storage you need. A model with more memory and storage obviously costs more upfront, but it often stays useful longer. Buying slightly above your current needs is usually a wiser decision than buying the minimum.
Compare the value
A cheaper previous generation model could offer everything you need. If you do not need the latest camera version or chip, saving money on an older version can make sense. Here you can compare the specifications, not just the names, and check what you give up for a better choice.
Know your rights
Whatever you want to buy, understand your protections. The ACCC explains that when you repair, replace, refund or cancel, a business must fix a minor problem with at least a free repair, while for a major problem you can choose a refund or even a replacement. It says refunds should be the full amount paid, with no deduction for use, and that no refund policies that deny these rights are illegal or against the law for faulty goods. Businesses must also include return shipping or collection for large or installed items. Keep your receipt so you can use these rights as and when required.
Check the basics before you pay
Confirm that the device is new and fully sealed, that it includes a full warranty, and that the model matches the one you want. Look at the storage size, its color, and any bundled accessories you are supposed to receive. Check the return policy so there are no surprises to shock you later on.
Which one should you choose?
If you want one device for everything, a MacBook or a larger iPad with a keyboard may be the most flexible option for you. But if you want something simple, an iPhone upgrade is hard to beat. If you are mostly just reading and watching, an iPad delivers the most comfort and portability. Decide how you use technology every day, and the best choice usually becomes clear.
Match the device to your day
Carefully think about where you spend most of your time with technology. If you travel often, weight and battery life matter more than anything. If you have a desk job, screen size and keyboard comfort take all your priority. If you are mainly on the couch, a tablet might be the best option. Writing down your top three needs has the potential to make the choice much easier and stops a flashy discount from pulling you in the wrong direction.
Set up for the long run
After buying, spend a little time on setup. Back up your data, enable security features, and learn a few shortcuts that save time for you. A device that is configured well feels faster and more useful than otherwise, and it helps the purchase pay off over many years. Treat it as an investment in how you work and relax, not just a gadget on one of your shelves.
Ask before you buy
If you are unsure, ask a staff member or a friend who already owns the device. Questions about battery life, noise, software updates, and repair options often reveal details that a product page usually skips. Five minutes of conversation can prevent months of regret with ease.
The verdict
No device is worth buying simply because it is on sale and has a cheap price tag. The right product matches your habits, your budget and also the accessories of your preferences. Compare carefully, know your rights, and then choose the right device that will truly serve you best.
FAQs
Q. What is the best time to buy Apple?
It totally depends on two factors: the deepest discount and the newest release. Pick which one is more important and then make your decision.
Q. Is there an Apple iPhone sale on Boxing Day?
For that, check current carrier and retailer offers through all the legitimate websites.
Q. Will iPhones be cheaper on Boxing Day?
Yes, iPhones can be cheaper on Boxing Day. However, it is very rare that the prices of the newly launched models will also drop.
