How to Enable MMS on iPhone? Quick Method And Understanding Common Issues
| Updated on October 22, 2026
For sending messages to different people as an Apple user without any disruptions, you need to enable MMS on iPhone. On most of the phones, it is pre-enabled, but sometimes due to iOS updates, restarts, or factory resets, it gets disabled. In this blog post, we are going to show you how to turn it on or off in the quickest way possible.
Read till the end!
How do I Enable MMS on iPhone: Quickest Method to Try
To enable MMS on iPhone for sending uninterrupted text messages to anyone, you need to follow these steps in the mentioned order.
  • Open Settings and click on Apps.
  • Search for Messages and tap on it.
  • In the in-app settings, enable MMS messaging using this toggle.
Common Problems Users Face While Enabling MMS on iPhone
When enabling MMS on iPhone, many users run into common problems you may see too. So, to provide clarity and help you to dodge them, we have mentioned these issues in detail:
  • Sometimes the “MMS Messaging” toggle might be completely missing from your iPhone settings, or turning it on has no effect. This can happen because your monthly carrier plan doesn’t include MMS, or your network provider hasn’t provisioned it for your account.
  • MMS fails the moment you leave your house or disconnect from Wi-Fi, or fails continuously if “Cellular Data” is disabled in your Control Center.
  • You can text non-Apple users individually, but you cannot receive or reply to group threads involving them.
  • Using MMS, you cannot send high-quality videos, documents, and photos, as the supported file size limit is up to 3 MB.
iPhones have so many unique features that most users ignore, and they have limited access to them, but if you want to explore new things about the Apple ecosystem every day, then make sure to check out the GetAssist YouTube channel.
To conclude, the process of enabling MMS on your iPhone is simple and takes only a few taps in your settings. You can turn on MMS Messaging and Group Messaging in your cellular settings to start sending pictures and videos right away. If you ever have any problems, you can always do a network reset or power down your phone to restart it. Update your settings now and start sending messages to all of your friends! Don’t forget to follow GetAssist for more such content.
1. Why is MMS not working on the iPhone?
Ans: If MMS is not working, then you should try enabling MMS messaging again or turn on cellular data on your iPhone.
2. How to enable MMS on iPhone 17?
Ans: To enable MMS on your iPhone 17, open the Settings app, scroll down to Apps, select Messages, and toggle on MMS Messaging.
3. Should I enable MMS on my iPhone?
Ans: MMS messaging should generally be turned on on your iPhone so you can send pictures, videos, and group texts to non-iPhone users (like Android users)
Rajesh Pandey
iOS and Gadgets Writer
