How to Turn Off Safe Mode on Android?
| Updated on September 28, 2026
Safe mode is a very useful feature on an Android device. It will give you so many benefits, like helping remove malware and corrupt files or identify any problem-causing application. It can also increase battery life and performance.
But the main drawback is, it doesn’t allow you to use any third-party applications. If you want to use those applications, just turn off Safe Mode.
In this guide, we will show you how to turn off Safe Mode on Android.
How to Turn Off Safe Mode on Android in the Easiest Way
Turning off Safe Mode will allow you to use your third party downloaded applications. There are two methods for how to turn off Safe Mode on Android, which include a notification menu or restarting your device.
Method 1: Turn off Safe Mode from the Notification Menu
  • Slide down your notification centre.
    Slide down and open the notification center
  • Search for the notification that says Safe Mode is on.
  • Tap on the notification.
  • Turn off Safe Mode.
    Turn off Safe Mode
Method 2: Turn off Safe Mode by Restarting your Device
  • Press and hold the power button to turn off your device.
  • Wait for 10 to 15 seconds, then press and hold the power button to turn on your device.
    Press and hold the power button until the device logo appears
  • Check the Safe Mode logo in the bottom-left corner.
  • If it disappears, your device is no longer in Safe Mode.
How to Turn Off Safe Mode When Your Device is Off
You can easily turn off Safe Mode when your device is off in just a few easy steps.
  • Press and hold the power button until your device logo appears.
After turning on Safe Mode, whenever you restart your device, Safe Mode will turn off automatically.
Benefits of Safe Mode
Safe Mode has so many benefits; it will help you identify the reason for frequent crashes or any viruses and corrupt files, and it also fixes network issues. Let’s talk about them.
  • Helps Remove Corrupt and Malware Files Safely
    Sometimes we accidentally download an unauthorized application, which creates corrupt files and malware. Safe Mode stops all third-party applications from running in the background so that you can easily delete them.
  • Identify any Problem-Causing System Errors
    You can easily identify which APK versions are causing any problem in the system. Safe mode stops all downloaded applications from running in the background. If you observe any performance boost after turning on Safe Mode, there is a chance that the downloaded applications have some problems or variations.
  • Remove Frequent Crashes and Increase Performance
    Personally downloaded applications use RAM and CPU in the background and increase lag and crashes. Safe mode removes all background applications, increases performance, and reduces crashes.
  • Increase Battery Life by Removing Background Applications
    Safe mode removes background applications; after removing it, CPU and memory usage decrease, and performance and battery backup increase.
  • Fix Network and Connectivity Issues
    Some application interruptions in network and wifi connectivity; Safe Mode will stop these applications and resolve any network-related issues on your device.
Safe Mode can be used to remove lag and malware from your device, and it can also resolve network or wifi connectivity issues. However, it doesn’t allow you to use personally downloaded applications.
To use these applications, you need to turn off Safe Mode. In this guide, we show you how to turn off Safe Mode on an Android device in an easy way. For more such guide videos, check out the Getassist YouTube channel.
What is Safe Mode on Android?
Safe Mode is a feature on Android devices. It boots the device into default settings and stops all third party downloaded applications.
How do I turn off Safe Mode on Android?
After turning on Safe Mode, you just need to restart your device to turn off Safe Mode.
How to close Safe Mode on mobile?
You can easily turn off Safe Mode on mobile; just restart your device.
Does turning off Safe Mode delete my data?
No, turning off Safe Mode doesn’t delete your data; it allows you to use downloaded apps.
How do I know I’m in Safe Mode?
There will be a sign in the bottom-left corner (Safe Mode).
