How to Turn off AirPlay on your iPhone, iPad and Mac?
| Updated on July 24, 2026
AirPlay is a wireless technology in Apple devices that lets you stream music, videos, photos, and your device screen from an iPhone, iPad, or a Mac to compatible TVs and speakers wirelessly.
To learn how to turn off AirPlay on your device, go through this article and follow the steps.
Steps on How to Turn Off AirPlay From Your Device
The process of turning off AirPlay on iPhone and iPad is different from Mac. Check out the steps on how to turn off AirPlay on iPhone/iPad and Mac.
Steps to Turn Off AirPlay on iPhone and iPad
  1. Navigate to device settings on your iPhone.
    Click on the device settings
  2. After opening settings on the device, click on General.
    Click on General
  3. Tap on AirPlay and Continuity.
    Click on AirPlay and Continuity
  4. Tap on the Automatically AirPlay option.
    Click on Automatically AirPlay
  5. Select Never.
    Click on Never
Steps to Turn off AirPlay on Mac
  1. Click on the Apple logo in the top left corner of your Mac.
  2. After clicking on the Apple logo, a menu will appear; click on System Settings.
    Click on the System Settings
  3. Click on General.
    Click on General option
  4. Head over to AirDrop & Handoff.
    Click on AirDrop and Handoff
  5. Toggle off the AirPlay Receiver.
    Click on AirPlay receiver and turn it off
  6. After turning off the AirPlay receiver, it will ask for your Mac’s password. Enter the password, and you are done turning off AirPlay.
    Enter the password
If you are a new Apple user, it can be a little overwhelming for you to turn off AirPlay. The above-mentioned steps can guide you smoothly to turn off AirPlay in just minutes.
Therefore, you can also figure out more such troubleshooting issues by following the GetAssist YouTube channel.
Can I prevent someone else from using AirPlay on my device?
Yes, you can prevent someone else from using your AirPlay. You simply have to go to the AirPlay settings and choose who to show your device to.
Is there any other way by which we can turn off AirPlay temporarily?
Yes, as we know that AirPlay relies heavily on Bluetooth and local wi-fi. Turning them off will automatically turn off AirPlay as well.
What is the difference between screen mirroring and AirPlay?
In screen mirroring, the TV acts like an exact clone, showing bit by bit whatever you are showing on your screen. But AirPlay does this as well, and you can select a video from a particular app to stream and use another app as well.
Sources
Rajesh Pandey
iOS and Gadgets Writer
