How to Stream Netflix on Discord? Methods, Issues, and their Resolutions
For creating a binge session with your online friends and family, Discord is a fantastic place, and learning how to stream Netflix on Discord can make the evening more captivating. However, Netflix doesn’t allow any third-party intervention, so there might be some issues, like a black screen or Netflix login failures.  That’s why, to avoid all of this chaos, read this article till the end!
How to Stream Netflix on Discord? An Easy Method
If you want to know how to stream Netflix on Discord, then you need to follow some convenient steps that will break the platform barriers and cast it perfectly without the repetitive issues of audio lags and black screen. Let’s see how to do this action without resetting your Netflix Password.
Procedural Outlook
  • Open Discord and Join the Channel
  • Then go to Discord’s User Settings
  • Click on Voice and Video Settings
  • Click on the Video section
  • Disable the graphics acceleration settings.
  • Go to your browser settings and disable the same setting (graphics acceleration)
  • Cast the Netflix window without any delays or disruptions
  • Open Discord on your system.
    Open Discord
  • Then, join the voice channel of your server.
    Join the voice channel
  • Go to User Settings.
    Go to User Setting
  • Click on the Voice and Video Option.
    Click on Voice and Video Option
  • Choose the video option.
    Select Video Option
  • Here, you will see an enabled option of Hardware Acceleration in the Advanced settings Disable it.
    Enabled Setting
  • Disable the settings
    Setting Disabled
  • Now, open your browser settings.
    Open Browser Settings
  • Now, in the browser settings, go to the settings options.
    Go to Settings options
  • Click on System and Preferences.
    Select System and Preferences
  • Go to Graphic Acceleration.
  • Now, disable the setting of “use graphic acceleration when available.”
    Disable the setting of use graphic acceleration when available
  • Come back to Discord again and click on the “Share Your Screen” option.
    click on the Share Your Screen option
  • Here you can see the option of the “Sharing window” to cast the Netflix browser window without any black screen.
    Now you can share the Netflix window
Craving more such hacks and everyday solutions? Then, without wasting any more time, check out and subscribe to the GetAssist YouTube Channel, along with pressing the bell icon for the latest tech updates.
What Problems Can Occur During Screen Sharing on Discord?
Well, specifically, there are only a few problems or glitches that appear in Discord every once in a while, which can make the experience a bit frustrating. These issues are commonly known as:
  • Black Screen issues: A black screen appears when you play a video instead of the actual movie with sound. This is the issue that users face too often, and it happens due to the platform’s streaming restrictions.
  • Audio Missing: Some users can encounter a problem where audio is missing, but the video playback is moving perfectly.
  • Laggy Streams: There are chances that due to poor system conditions or network retention, the streaming services could jitter. Lag, or even crash, during media playback.
  • Browser Incompatibility: Browser incompatibility issues are one of the most untalked-about problems faced by users, as they mostly remain unnoticed. People who rely on old browsers like Firefox face this issue more significantly.
How to Fix Streaming Issues on Discord?
To minimize your searching time to fix the potential issues, we have curated a chart that provides the best troubleshooting solutions for all the recurring problems.  That chart can help you watch Money Heist on Netflix or any of your favorite shows with your friends without the chaos of fixing things.
Issues Troubleshooting solution
Black ScreenDisable “Hardware Acceleration” or “Graphic Acceleration” (according to your browser) and turn off this setting too in Discord.
Audio Displacement Make sure that your system’s sound is enabled, and don’t go for the “Entire Screen” option; instead, go for sharing for a particular window of the streaming platform.
Laggy Streams Close background applications, lower the streaming quality, and turn off the power saving mode of your systems.
Browser IncompatibilityDisable the DRM setting, and if the problem persists, then change the current browser.
Surpassing every issue and platform restrictions, we have successfully shown users how to stream Netflix on Discord so that they can enjoy their captivating thriller shows and mind-bending movies without any disruptions. Also, if issues persist, then these troubleshooting solutions can help you in so many ways, if they don’t work, then we advise you to restart your systems and clear the background cache from the hard drives.
How to bypass the Netflix black screen when screen sharing?
To share Netflix without a black screen, disable hardware acceleration in your browser (Chrome/Edge) or Discord, which prevents DRM (Digital Rights Management) from blocking the stream.
What are the risks of streaming Netflix on Discord?
Although there are no system-disruptive risks involved, you can face problems like a black screen, audio incompatibility, browser crashes, etc., during your playback session. All these things can ruin both your mood and experience of the people watching.
What’s a soft ban on Discord?
A soft ban on Discord is a consequential step that bans and then immediately unbans a user to purge their recent messages (typically within the last 24 hours) from a server.
