Are you not finding an appropriate platform that works easily to log in and use Snapchat on a computer? If so, just be with us till the end. If you scroll down till the end, you will be able to answer all the following issues or queries regarding Snapchat Login through PC.
Now, put your hands off your smartphone and onto your Pc!
Benefits of Using Snapchat on PC
It is easier and better to use Snapchat on your PC or Computer, due to the following reasons:
- Handy– It is handy while browsing on PC
- All features in use– Without missing out on any feature, you will be able to see and use all the Snapchat features on your device.
- Share– Share, upload, and add a caption to snaps and videos easily with a bigger screen
- Create stories– Create stories by adding multiple snaps easily and quickly
- Use in the workspace– It is hard for people in workplaces to use cell phones all the time for updates. So, in these cases, Snapchat via computer is the easiest and reliable way to use Snapchat without compromising work or getting caught by your boss
Run snap without a mobile app! To do so, just
Follow the steps to use Snapchat directly on your Pc within a go!
How to log in and use Snapchat on PC?
This is a one-time start to finish guide to log in and use Snapchat on Computer through Bluestack. You can use any other Apps with the help of the following steps:
1. Via Blustacks
Bluestacks is one of the trusted platforms to download and install any Android app to use. It is simple and easy to use. Let us show you how to use Snapchat on a computer or laptop through Bluestacks:
- Step 1: Search and download Bluestacks emulator from the Web Browser in your Pc
- Step 2: After clicking download, click install as shown below for automatic installation
- Step 3: Open the emulator, as and when it gets downloaded, and Launch it
- Step 4: Search Snapchat at the search bar of the Bluestacks emulator
- Step 5: You will be directed to the Play store. Sign in, in case you are not signed in automatically.
- Step 6: Sign in to your Google play store
- Step 7: Type Snapchat at the search bar and click on Install
- Step 8: After Installation, just click on Open as shown below
- Step 9: As the App opens, you will see the following page on your screen. From here, just Login in your Snapchat Account
It has been observed that there are times when Bluestacks hangs while downloading an app. To avoid it from happening to you, we are mentioning some steps below for another emulator in brief:
2. Manymo
Manymo is another emulator to log in to Snapchat. The best part is that it does not need to be downloaded, you can sign in and quickly access different android applications with a click. Just scroll down to see the steps:
Step 1: To launch Manymo, log in with your active username and password for Manymo.
Step 2: After launching the emulator, download Snapchat .apk file from your PC
Step 3: Enter your Snapchat login details. Now, you can run Snapchat online.
Continue Snapping!
QUICK TRICK: For macOS, you can use these emulators- Nox Player, KO Player, and Bliss. These can be used in both Android and iOS devices. |
Snapchat log in through Web browser in 2 steps
There are certain instances, where you want to continue a task. But, you also want to use Snapchat easily. Follow the steps below to learn and log in to Snapchat online on a browser to use it while working on your PC or computer-
Step 1: Type Snapchat login at your Google search bar
Step 2: As the following page appears, enter login details and click Log in
After logging in to Snapchat easily on your computer, you will feel like saving the login platform. So that you don’t have to repeat the process again and again from start to finish.
But, when we are there, not to fear!
Save Snapchat through Shortcut in 2 steps
Snapchat Shortcut is a clean-cut, easy way to save Snapchat on your Pc/Computer for easy and frequent use.
Follow the steps to save Snapchat once and for all-
Step 1: After logging in to Snapchat, go to the three dots at the top right
Step 2: Save the shortcut on your desktop, easy to use and handy
By this, you can use Snapchat as and when you like, even if you are multitasking. No need to worry about Downloading the App.
Also Read- How to Create a Snapchat Account?
