Once in a while, when your pal messages you on Snapchat, you may get excited to take a sneak peek without alerting them. Earlier, it was possible. Unfortunately, as of now, Snapchat Plus allows users to detect that you peeped in between their conversations. But how?
Relax, this article will unveil how to see if someone half swipes on Snapchat to secretly view the message and how to activate this feature.
Quick Answer
Only Snapchat Plus users can see if someone half-swipes their messages by turning on the captivating Peek a Peek feature.
To the one asking if you can see half swipes on Snapchat, the simple answer is yes. You can see half swipe on Snapchat with a premium membership to Snapchat Plus.
Aside from this, the free users still cannot avail of this opportunity now but can expect it in future updates.
Turning on the Peek a Peek feature indicated an eye-like emoji next to your name, informing the person that you made a secret attempt to view their message. Now, hover over to the next section to learn how to enable this exciting feature.
As the same suggests, half swipe means a little swipe across the screen, without doing it fully. Interestingly, a lot of Snapchatters can get caught because of this new feature. It is worth noting that half swipe is only useful to view messages, not snaps.
Talking about this tool, lets you swipe any page of conversations, including groups, to see the texts.
Therefore, this feature does not send any specific notifications; the only way is to keep an eye on the conversations. But always remember that to use this, you need to buy a premium version that costs $3.99 per month. With this, you can also get a range of other exciting features, including a rewatch indicator, Snapchat planet order, and more.
Firstly, to discreetly see when a friend half swipes on Snapchat, you need to toggle on the Peek a Peek feature using your SC premium version. Take a look at the steps to know how to see when someone half-swipes.
That’s it! With the above-mentioned steps, you can get rid of how to see if someone half swipe on Snapchat query.
The process of doing a half-swipe or half-slide on Snapchat is not rocket science, but you need to do it correctly without notifying your friend of the activity. Here’s how to do that:
In your chat thread, you will see the new chat label under your friend’s name. But, if your pal has Snapchat Plus, he or she will get alerted that you have half-swiped their message.
Peek a Peek is a Snapchat Plus feature, so to use it, you need to first subscribe to it. Meanwhile, premium users may be able to see eye-like emojis that will indicate half swipe only if they are on their chat screen. No specific notification will alert them.
Besides half swipe, some users put their phone on airplane mode after loading the message, to protect their activity information. But it doesn’t carry any surety. Therefore, the airplane method is widely used to screenshot content without knowing it.
To know if someone half-swiped on Snapchat Plus, you need to first toggle on the Peek a Peek feature.
No, till now, this feature is not available for free users of Snapchat.
No, your Bitmoji doesn’t pop up when you half-swipe. It only pops up when you view or write a message.
