Razer Blade 15 2018 h2 Specs, Features, Price, and Reviews 2025
| Updated on January 6, 2025
Product Image
Product NameRazer Blade 15
Price
Available Colors Black
Review Rating
3.7
Gaming laptops are the current requirement of gaming geeks. Finding the best laptops with appreciating pixels and storage support is a challenging task when we have a plethora of options in the market to explore.
Razer Blade 15 laptop features and reviews with price details have been presented below in the coming article. Without any further ado, let’s know Razer blade 15  specs one by one.
Key Takeaway: Razer Blade laptop makes the greatest option if you play multiplayer games, as the graphics NVIDIA GeForce GTX 1060 support apt storage quality, and the processor is powered in this laptop model.
Razer Blade 15 Specs
Specifications of Razer Blade 15 laptop from storage backup to the pixel and graphic detail have been presented in the table below.
FeaturesSpecifications
Display15.6”
Pixels per-inch141.2 pixels per inch
Prize$1128
RAM16 GB
Storage1128 GB
Battery life4.9 hours
Frame per inch50.25 frames per inch
Processori7-8750H (2.20 GHz)
Weight2.1Kg
Operating SystemWindows 10 home
GPUNVIDIA GeForce GTX 1060 Max-Q
Memory Speed2666MHz
Processing Speed2.40GHz
Apt Gaming Features in Razer Blade 15 2018 h2
A gaming laptop should match current high-pixel gaming requirements and should have reliable storage and battery life. Let’s find out if the Razer Blade laptop fills some of these high-tech requirements.
  • Battery Life
    Battery life is one of the primary things that helps a gamer acknowledge if the laptop can fill his late hours of gaming needs. Razer Blade 1060 battery life doesn’t have an acceptable strength in withholding heavy game for long hours. Its battery backup varies from 4.5 to 5 hours which is an unreliable source to help a gamer geek to stay long.
  • Processing Power
    The Intel-powered processor i7-8750H, with a processing speed of 2.20GHz, is not decent enough to withstand the current high-end games in the market. One should be skeptical before considering this gaming laptop as it will most probably fail to meet high-quality needs.
  • Storage Power
    16GB of RAM and 1128GB of SSD is an apt storage backup that can hold multiple applications at a time. Powerful storage assists the user in continuing gaming entertainment with the least hindrance. Razer Blade 15 2018 h2 has an awesome storage backup and thus is the best option for you if you are looking for satisfying storage options.
  • Graphics Compatibility
    Razer Blade 15 2018 is powered by the NVIDIA GeForce GTX 1060 Max-Q graphic card, which is best for a multiplayer gaming experience. Old games can be played easily on it, but it won’t be able to process the graphics of the current new games. It is better to consider Razer 15 2018 h2 only if you want to enjoy multiplayer games.
  • Resolution
    The resolution 1920×1080 in the Razer blade laptop is a decent feature to consider if you are looking for a laptop for gaming purposes or personal document editing. The display with 15.6 inches complements the resolution and thus is the best feature attribute to play various games.
  • Weight
    Gaming laptops are speculated to be heavy in origin but the Razer Blade advanced laptop doesn’t leave any complaints for its users. It has 2.1 kg in weight and therefore is a convenient option to be carried along while travelling.
Pros and Cons Of This Gaming Laptop
The pros and cons of Razer Blade 15 with their respective features have been articulated below with ratings beside.
Pros
  • Display
  • Resolution
  • Weight
  • Convenient Weight
Cons
  • Expensive Prize
  • processor
  • Battery backup
Major Drawbacks of Razer 15 Laptop
There were multiple reasons making Razer blade laptop an unsuitable option for the current game needs of the new players. Some of them have been listed below.
  • Inconvenient Graphics: Graphic NVIDIA GeForce GTX 1060 Max-Q is unreliable for heavy games. It doesn’t stand the current gaming infrastructure needs.
  • Battery Power:  We all know that battery power stands as an essential attribute for lasting long in gaming entertainment.
  • Slow Processor: i7-8750H (2.20 GHz) of Razer 15 2018 doesn’t support heavy processing games and is unsuitable for newly developed games.
Users Reviews & Price of Razer Blade 15 2018 H2
Here are some reviews on Razer Blade 15
  • This laptop cannot be considered the best laptop option as battery backup is one of the disagreeing features.
  • The graphics are going to support users’ medium game demands, and the processor too will not be able to help multiple applications at the same time.
  • The resolution and the storage are the amiable features of the Razer Blade 15 laptop which can be altered for the user’s needs.
Closing Thoughts
Razer Blade 15 gaming laptop is not a perfect option if someone is looking for a cheap gaming laptop; it will surely disappoint in the battery backup and graphics that it provides. This gaming laptop cannot support heavy games and can surely disturb your gaming performance through its slow processing speed.
