    Troubleshooting » Gmail » Fed Up of Gmail Error (#2014)? Check Out the Blog to Get Out of It
    Posted on January 4, 2022 | By Acushala Dhar
    Are you here due to an email problem that says– “oops the system encountered a problem (#2014)” or did you encounter “Email Error 2013”?
    If so, then, you are on the right track. Let’s walk you through an easy-to-use path that will help you to continue working, in case, you got stuck with “oops the system encountered a problem (#2014)”
    Table of Content
    • Problems you might Face During Gmail Errors(#2014)
    • Solutions to Resolve- “Oops, the system encountered a problem (#2014)”
    • Update Web Browsers
    • Speed Up the Internet
    • Disable Antivirus Solutions
    • Clear Browsing Cache, Cookies, and History
    • Disable Browsing Extensions
    • Switch to HTML Gmail
    Let’s have a glance at the major troubles that you might go through which will indicate that you are stuck with a Gmail error, “oops the system encountered a problem (#2014)”
    Problems You Might Face During Gmail Errors(#2014)
    • You can end up losing data from your device, unknowingly.
    • Non-optimal settings can be experienced while working
    • Chances of PC clutter or the slowed-down speed while using the device
    • Unnecessary occurrence of unneeded or duplicate data
    • Unnecessary services and items popping up
    • Invalid entries showing up on the screen
    Now, to come out of the above-listed problems that you will face under Gmail Error 2014, let’s follow the methods or solutions listed below.
    Note: All the methods can also be used if you are getting Error #2013- “Oops, the system encountered a problem”.
    Solutions to Resolve- “Oops the system encountered a problem (#2014)”
    1. Update Web Browsers
    Your outdated versions of Web Browsers can be at the fault, causing Gmail Errors #2014, or 2013. To resolve these issues, caused by a long-lost Web Browser, just follow the steps below for fresh updates.
    Google Chrome
    Step 1: Open your Web Browser through Google Chrome and click on the three vertical dots on top-right.
    three dots at the top right on Google browser
    Step 2: Choose the Help option and click on ‘About Google Chrome
    Go to help and click on about Google Chrome
    Step 3: From the About Google Chrome section, check for the Google Chrome updates, and it will be downloaded automatically.
    check and download Google Chrome updates
    Microsoft Edge
    Step 1: Go to Windows Menu, and click on the Settings tab
    go to the windows menu and click on settings
    Step 2: Type updates in the Search tab and click on Check for Updates
    under updates, click on check for updates
    Step 3: Now, from this Windows Update section, click on Check for Updates tab, as shown below.
    Step 4: You will see the following screen, regarding the status, “checking for updates”. And afterward, you will be directed to the required downloads and installations.
    Mozilla Firefox
    Step 1: Open Mozilla Firefox, click on the three lines at the top-right, and click on Help Tab.
    click on the three lines at the top right, click on the help tab
    Step 2: Under Help Tab, click on About Firefox.
    under help tab, click on about Firefox
    Step 3: As you see the following screen, check for updates and download and install the required updates, if necessary.
    check for updates and download the required updates
    Opera
    Step 1: Go to Opera Web Browser, and click on the Settings tab from the bottom left of the following screen.
    click on Setting stab from Opera browser
    Step 2: Now under Settings, click on Opera Help
     under settings, click on opera help
    Step 3: Under Opera Help, click on “Update your Browser”. Download and install the latest updates, if found.
     click on Update your browser under Opera Help
    2. Speed up the Internet
    If you are having Gmail error #2014, due to the internet connectivity, just keep a track of the following pointers:
    • Check your Wi-Fi, by turning it off and on
    • Check your Recharge plans and refill the data
    • Connect your devices with the LAN Wire, if possible
    3. Disable Antivirus Solutions
    The add-ons or third party services can cause “Oops…the system encountered a problem (#2014)”. To disable third-party services from your device, you can use Windows Defender or Windows security status, by following the steps below:
    Step 1: Go to Settings, under the Windows Menu tab
     go to settings under windows menu
    Step 2: Now, under Windows Security, click on Open Windows Security.
    click on open Windows security under windows security
    Step 3: From the Security at a Glance, check for the issues and updates. This section will direct you automatically, for the necessary checks and downloads, securely.
    Check for updates and security checks
    4. Clear Browsing Cache, Cookies, and History
    This might be the way out for you, as this method can also resolve some glitches in your device.
    For Google Web Users,
    Step 1: Open Google Browser, click on History, and click on the History tab again, as shown below.
    click on history tab from Google browser
    Step 2: Go to History, select the web pages you want to clear or delete and click on Clear browsing data, from the left side of the screen.
     select the web pages and click on clear browsing data
    Step 3: Under the following page, after clicking on clear browsing data, choose the options to clear history, cookies, and other cache data from below and click on clear data.
    click on clear data to clear cache and cookies data
    For Microsoft Edge,
    Step 1: Open Microsoft Edge, click on the three dots at the top-right, as shown below.
    open Microsoft Edge, click on the three dots at the top right
    Step 2: Click on the History tab, either by tapping directly on the History tab or by clicking CTRL + H, from the keyboard.
    go to history from the Microsoft Edge page
    Step 3: From the History tab, click on Clear browsing data.
     clear browsing data from history in Microsoft Edge
    Step 4: Under Clear browsing data, choose the period you want to clear your data for, select to clean cookies, history, and other data, and click on clear now.
     select the data to be cleared, and click on clear now
    For Firefox,
    Step 1: Open your Firefox Browser, and click on the History Tab.
    Click on the history tab from the three lines at the top right
    Step 2: Under the History tab, click on Clear Recent History
    Under history, click on clear recent history
    Step 3: After clicking on Clear recent History, select a time range for which you wish to clear the data, like- cookies, caches, and more. And then, click on the OK tab.
    Note: Do not forget to click on the Cookies and Cache section.
    chose the time range and click on ok
    For Opera,
    Step 1: Open Opera web browser, and click on the click icon, i.e.- History, from the left side of the screen.
     click on the history icon from the opera browser screen
    Step 2: Under History, click on the Clear Browsing Data tab, as shown below.
    Under history, click on the clear browsing data tab
    Step 3: Under Clear Browsing Data, slide to the basic section and select on Browsing history, cookies, and other site data and cached images and images section, and then click on clear data.
    select the data you want to clear, and click on the clear data tab
    5. Disable Browsing Extensions
    For Google Chrome,
    Step 1: Click on the puzzle icon (for extensions), from the top-right of your Google web browser screen.
    click on the extensions icon from the google web browser
    Step 2: Under the extensions, click on the three dots of the saved extensions that you are planning to remove. And afterward, click on the extension’s icon. Now, click on Remove from Chrome tab.
    click on the three dots and  then click on remove from chrome
    For Microsoft Edge,
    Step 1: Open the Microsoft Web Browser, click on the puzzle icon, from the top right of the screen.
    Click on the extension icon from the Microsoft web browser
    Step 2: You will be able to see all the pre-saved extensions under the extensions bar, click on the three dots on the ones that you want to remove from the browser. And afterward, click on Remove from Microsoft Edge.
     Click on the extensions icon, choose the saved extension, and click on remove from Microsoft edge
    For Firefox,
    Step 1: Open Firefox browser, and click on the pre-saved extensions in the top right corner of the Firefox web screen, as shown below.
    click on the extensions from the top bar of the firefox web screen
    Step 2: After clicking on the saved extension icon, click on the remove extensions tab.
    click on remove extension
    Step 3: Now, as the following screen appears, click on the remove tab.
    click on remove tab
    For Opera,
    Step 1: Open Opera web browser, and click on the box icon for extensions, from the top right corner of the screen. And then, click on the Manage Extensions tab, as shown below.
    Click on the manage extensions tab under the extensions icon
    Step 2: Choose the extension you wish to remove and as you open the saved extensions, click on the disable Tab.
    under extensions, click on the disable tab.
    6. Switch to HTML Gmail Services
    If the above methods didn’t work out. You should switch your latest Gmail services to the HTML version. But, before switching Gmail to HTML version, keep in mind:
    1. You will not be able to access certain Gmail features
    2. You won’t be able to apply certain keyboard shortcuts
    3. You won’t be able to use quick actions
    4. You won’t be able to use extra add-ons, like-spell check or extensions.
    Choose to switch your Gmail to the HTML Version of Gmail wisely.
    Also Read: How to Fix Gmail Server Error 007?
    Here’s How you can Fix Gmail’s ‘Address Not Found’ Error
      • 12 Best Web Scraping Tools for Developers
      • What is SIM Not Provisioned Error? How Can We Get It Fixed?
      • How to Recover a Hacked WhatsApp Account?
      • How to Make International Calls for Free
      • How to Make Your Blog Visible for Search Engines?
    • A Complete Guide to Fix When Outlook Cannot Connect to Gmail in 2022
      Configuration.exe- A Complete Guide to Fix When Outlook Cannot Connect to Gmail in 2022 ( For All Versions)
      If one has to count the number of developers that made Gmail, it can be...
    • Recover your Gmail Account
      How to Recover Your Gmail Account and Never Loss It Again
      Gmail accounts are tied to significant features on your computer or Android phone, including YouTube,...
    • Helping Handbook to Fix Gmail 007 Error
      Helping Handbook to Fix Gmail 007 Error, Trouble-Free
      Gmail is a free email servicing app, provided by Google, that has been growing every...
    • not-receiving-google-verification-code
      Not Receiving Gmail’s Verification Codes? Here’s the Helping Guide
      If you are a frequent Gmail user, you must be aware of how annoying it...
    • Gmail not syncing with iphone
      Effective Guide to Fix Gmail Not Syncing with iPhone Issue
      Whenever you add your Gmail account to a device like iPhone, it starts synchronizing so...
    • Gmail is not syncing with outlook
      Gmail Not Syncing with Outlook? 6 Solutions You Must Try
      Configuring your email accounts brings a lot of conveniences as you need not go back...
    • Gmail address not found error
      Troubleshooting Guide to Fix ‘Address not found’ error in Gmail
      Most email account owners prefer Gmail owing to the fact that it is easy to...
    • Why does gmail app keeps crashing
      Why Does the Gmail App keep Crashing and How to Fix it?
      Key Takeaways:The Gmail app keeps crashing if the app is not updated, or it has...
    • cant send emails from gmail account
      Gmail is Not Sending Emails? Here are the Causes and the Workarounds
      Realizing one day that your Gmail account is not letting you send emails can be...
    • gmail login problem
      Gmail Sign-In Failed- How to Deal with Gmail Account Login Problem?
      It’s been years now that I have been using a Gmail account and have faced...
