The right video editing software can take your editing skills to the next level. Even a professional video editor needs editing software. This is why we have brought you this incredible one-stop video toolkit to help you create videos that even you wouldn’t have imagined. Joyoshare VidiKit is an all-in-one video toolkit with a screen recorder, audio capture, video converter, watermark remover, video compressor, and so much more.
What makes a tool worthy of your investment is its ease of use and accessibility, and Joyoshare VidiKit comes with all of it. So, if you are looking for a video toolkit with complete solutions to deal with your media files, this might be the one for you.
Joyoshare VidiKit: Functions and Features
With just a little touch-up, you can enhance your video and make it look like a professional one. This is what Joyoshare VidiKit does; let’s have a look at some of its features:
Record High-Quality Videos
Who doesn’t want to create a video of “exactly” what they watched? No one. This is what you get with Joyoshare. With this premium multimedia program, you get to adjust the capture area according to the actual situation, and this helps you give your video a real and magical look. It covers recordings for gaming, meeting, how-to tutorials, streaming movies, and the like. The resolution it offers can be up to 4K/1080p and also the frame rate with no drops can be 60fps.
Excellent Music Recorder
Joyoshare VidiKit has a great audio capture toolbox, letting your video grab the computer-detected sounds. There’s a lot more to this video kit like auto-deleting mute files, editing audio recordings, and applying sound effects.
Add or Remove Watermarks
Adding or removing watermarks from various places in videos and images might be essential. But not every tool assists you with that, which is why Joyoshare VidiKit comes with one-click add or remove watermarks features.
Merge Videos
It might be frustrating to merge multiple videos while compromising the quality. But with Joyoshare, you can merge as many videos as you want without compromising the original video quality.
Trim Videos
Get to provide as many cutting ways as possible to cater various needs of your clients. With Joyoshare, you get to trim specified videos loosely.
Now that we talk about screen recording on Windows with Joyoshare VidiKit let’s also learn how to record screens on Windows.
How to Record Screen on Windows with Joyoshare VidiKit?
Microsoft has made some extraordinary changes to give its users an incredible experience. And one of these changes includes introducing the screen record feature on Windows. Well, not just this, it’s the accessibility of this feature that has also been astonishing to the users. It may sound a little technical, but screen recording on Windows is utterly straightforward.
To start with the screen record on Windows, there is more than just one method. You can do so with the in-built Window tool, Windows 10 PowerPoint, and with the Joyoshare VidiKit.
To record screen on Windows with Joyoshare VidiKit, here’s what you should do:
Step 1: Download the Joyoshare VidiKit on Your Device
Screen reconding1
Visit the Joyoshare VidiKit official website and download its Windows version. Double-click on the program, select Record, and then Screen Recorder to activate the program.
Note: If you are bothered by the unknown interruptions, you may face while recording the screen on Windows, you must know that Joyoshare VidiKit is built with a close microphone voice or system sound. Even after you are interrupted by anything, it won’t affect the recorded video.
Step2: Pick Up the Recording Area
Recording Area
The tool also lets the users pick the capture area at their will. To begin with, all you need to do is click on the “Record video and audio” mode and then click on the “+” button. Then a pop-up window will appear; you can drag the edge of the window to adjust it according to your recording region.
Step 3: Customize the Recording Preferences
Joyoshare VidiKit is also supported with the output format selection. And not just that but also creating tasks by presenting start and end times, click moments highlights, and so much more. The tools come with-
  • Three basic record options
  • Record time option
  • And Cursor option
Step 4: Start Recording and Editing
To start with the screen recorder in Windows 10/11 or the later, click on the “REC” option. To end the capturing, click on the “Stop” option. Here, you will also have the option to take screenshots, trim the video, and skip the content.
Start Recording & Editing
Joyoshare VidiKit lets you preview your video as well as rename your video in the “History” option.
Note: If you started to trim your recorded video in the previous screen recording process, you would be able to see the different segments here.
So this was how to record screens on Windows using Joyoshare VidiKit. Pretty easy, right? Well, that is what makes Joyoshare VidiKit exceptional; it comes with multiple features and with ease of access too.
