Without a doubt, Android is an amazingly full-featured, powerful, and reliable operating system for many mega brands and people as well. However, even though many market biggies like Samsung, LG, One Plus, and many more rely on it fully, it isn’t perfect. And that’s no news.
So at times, Android users face issues like ‘Apps keep crashing’ or ‘Apps close immediately after opening on Android’ which can get way too annoying especially if you’re in a hurry.
Therefore, if you are also facing any such issue or know someone who has been bugged by this issue, then there are a plethora of possibilities for why the apps are crashing on Android.
There are many possible reasons for the apps or the Android to act a certain way. In order to get your Android and the apps to behave, we have got some useful and easily understandable methods for this issue.
In this article, we are going to discuss the reasons and solutions for why the apps keep crashing on Android.
So with that said, let’s get right into it…
Why do Apps Keep Crashing on Android?
Almost all the apps that you install from Google Play Store to your Android device run smoothly. While some people think that if the app doesn’t work properly on their device, then it is due to incompatibility or error in the app, it isn’t always the case. There can be many reasons why apps keep crashing on Android. Let’s discuss some of them below:
- Poor network connectivity: It is the most basic and important need to have a proper working network connection to install or download any app. If you don’t have a good or required signal strength, then you will most likely face issues like this.
- Insufficient Storage Space available: When you run out of storage or the space available on your device is not enough, then this prevents the smooth functioning of the apps. As a result, the apps may stop working or close immediately after they are opened.
- The installed app is outdated: Sometimes the Google Play Store has glitches of its own due to which it shows the old version of apps to download. It is possible that you might have caused a similar bug, and it was the cause of the installation of the old version app.
- Your software version is not updated: If the software version of your device is not updated to the latest version available, then this can lead to various issues like improper functioning of your device and apps closing and shutting down on their own.
- App installation being unsuccessful: It is possible that the app that is crashing or stopping now, was installed hastily, and the proper process wasn’t followed for installation.
- The app is damaged: Whenever there is a new update for any app, usually the freshest update includes bugs that can make the update and the app damaged and corrupted. This can also be a possible reason why the apps are crashing on your android device.
Also Read: Can’t Send Messages on Android? Here’s What You Should Do
It is not necessary for only the above-mentioned factors to play the role in stopping or crashing apps on your android. As mentioned earlier, there could be many more reasons for this to be happening. And so, as a precautionary measure, we would advise you to consult your device company’s customer support for services if you see signs of any such error starting to happen.
So now, let’s move on with the easy steps that we have to offer which can come in pretty handy if you are in the middle of this error and don’t know what to do.
Easy Methods for Why Apps Keep Crashing on Android Issue
Now that we are aware of what might be the reasons that cause the apps to crash or close on their own, we can proceed with the solutions which can be helpful in getting away with this issue. If you are facing it and want to have a guide for what you can do which can probably help you to get out of this error, then keep reading. To get rid of this error, you can consider following the steps given below and try the methods as instructed:
Restart your Device
Although it might sound like a common tip, it does come in pretty handy sometimes. Restarting or rebooting your device not only refreshes the app’s background but also removes the minor bugs which cause damage while starting an app.
- Press and hold the lock button for 2-3 seconds and tap on Restart or Reboot.
- Wait for the phone to restart and then try opening the app that was crashing.
Reinstall the Crashing App
There are chances that the app is crashing and shutting down on its own, itself is damaged, or includes corrupted files. Reinstalling it to the latest version available can remove the errors and bugs which were stopping the app from launching properly.
- Tap on the app that is crashing for 2-3 seconds and then select Uninstall.
- Go to Google Play Store and search for the app.
- After the app appears, tap on Install and after the app is downloaded, check if it works normally.
Check that you have a Stable Network Connection
People often don’t pay attention to whether they have their data or Wi-Fi connection turned on or not. And especially if you are launching an app that requires the internet, you need to make sure that you have turned it on, and that it has a good signal strength.
- Swipe down from your phone’s home screen.
- Tap on Wi-Fi and Mobile Data to disable them.
- Then enable them and check if the app is still crashing.
Check App Permissions
If you have recently installed a new app, then there is a possibility that the settings for the app and its permissions are still set to default which is preventing the app from taking some actions. Hence, you need to check and reset the app permissions as per your needs.
- Go to Settings.
- Search for the crashing app and tap on it.
- Look for App Permissions and check if everything is customized as you want. If not, then set the options as you want.
- Now the app should be working just fine.
Keep your Software Updated
Be it Android or iOS, all the operating systems continue to release their software updates over time to make sure that the users are able to enjoy the latest updates of the software with newly released features. And if you have not updated your device’s update to the latest version possible, then there is a chance for the app to be functioning improperly or misbehaving.
- Go to Settings and look for System Updates.
- Download the software and update your device to the latest version of Android.
Clear App Cache and Data
Over time, the apps store the caches and cookies of your preferences and other information. And this storage can also include defective files which can cause errors like crashing apps.
- Open Settings and select Apps, and go to the app that keeps crashing.
- Then select Application Manager.
- Tap on Clear Cache and Clear Data options and the app will be free if there was any corrupted file present.
Free Up your Storage Space
Just like any other device, if you don’t have sufficient storage which is required for the proper functioning of the device, then the apps will not work smoothly and even cause issues in launching.
- Go to Settings and look for Storage.
- Tap on it and delete the data that you no longer want.
- You can also delete the music, photos, and videos manually that you do not want on your device.
- This way the storage will be free, and the apps will function smoothly.
Perform Factory Reset
Note: Before doing a factory data reset, make sure to save and back up all your data prior to it, or you may lose it afterward.
If none of the methods work then you can go with this last procedure of factory data resetting your device. The factory data reset option will help you in giving a fresh start to your device, and it will remove all the files and data that can possibly be causing errors in launching the apps or misbehaving.
- Go to Settings and select General Management.
- Then tap on Reset.
- After that, press Factory Data Reset.
- Now your data will be reset and Settings will be set back to default.
Note: The options in Settings may vary from device to device even if they are all Androids. You can search for the given option on your device as per the Settings and layout.
Fast Facts About Android
- As suggested by their names Jelly Bean, KitKat, etc., nearly all Android Operating Systems are named after Candy or Desserts.
- Android has 75% of the global market share.
- With its huge user base, Android has over 2.8 billion active users.
- For patent royalties, Android pays around $2 billion to Microsoft every year.
- Last year, over 1 billion smartphones were shipped.
FAQs
Q1. Why are apps not working on my Android?
There can be many reasons why the apps aren’t working on your Android. Some of them are listed below:
- Low storage
- Internet connection issue
- Device is not compatible with the crashing app
- The crashing app is not up-to-date
- Outdated software of device
- App permissions are not set
Q2. How to stop Android apps from closing automatically?
To stop apps from closing, you have to go to the Settings then Apps. After that, select Apps Launch and select the app that is crashing. Disable the Manage option and enable Run in the background. Finally, tap on OK and now your apps won’t auto-close.
You can also read:
