    Troubleshooting » Smart Phone » Easy-to-Read Help Guide to Resolve Message Sending Issues on Android
    Posted on November 26, 2021 | By Acushala Dhar
    A person can feel that messaging services are of no use, due to the rise of digital media and other messaging apps. But, even to this day, all the important messages or queries regarding your data, company, OTP(one-time-password), or bank accounts are only sent through SMS, to maintain utmost security. And at this point, it gets frustrating and annoying if your messages or texts aren’t sent when you are in desperate need of it.
    Assuming, you might also be one of them who is facing the above issues or has lost track of sending messages and is unable to send SMS Services through Android devices, just follow this page without a rush.
    First, we will talk about the general issues or checks faced by a person in case there are issues in messaging. And gradually, we will continue to brief all the issues in detail with the required solutions.
    The basic reasons can be:
    • No signal or partial signal, depending on location.
    • Change in settings, leading to Wrong Settings
    • Problems with Cellular Network
    • Network Jam, due to high traffic
    • Issues with Phone Number- can be blocked, invalid or disconnected
    • Issues with the Phone or Operating System
    • Disfigured Flight mode issues in the in-built messaging App
    • Invalid/No message center settings (SMSC)
    The above-listed pointers can be some of the basic and major reasons for the interruptions in your messaging services. Let’s move on to ‘how to check the issues’, which will lead us to find the required solutions.
    Preliminary Checks/Issues
    1. POOR AIRTIME: There can be a possibility that your messages are not sent on time to the receiving end or are received late, due to the lack of speed or longer messages.
    2. DEVICE HOST SETTINGS: Check your device’s host, as this could interfere with sending messages from your device.
    3. NETWORK SETTINGS: Check your cellular provider’s network and settings
    4. CONFIRM PHONE NUMBER: Confirm if the phone number you have sent the message to is correct, there can be chances that you sent the message on an invalid phone number or check if the number has been blocked by you.
    5. CARRIER SUPPORT CHECK: Check whether your carrier supports text messages.
    6. CHECK MESSAGING APP: Check if the in-built messaging app is your default text messaging app.
    7. CHECK SIM CARD INSERTION: Ensure that your SIM card is inserted properly, to function and send the messages. If it is, check your device’s network status. You can also check the same by using the SIM card on a different device.
    Finally, let’s go directly to the long-awaited topic. After checking and confirming all the above issues, let’s begin with the solutions.
    Required Solutions
    Follow the solutions listed below, if your messages or texts won’t send through Android:
    Solution 1: Refresh your phone
    Refresh your phone by hitting the reset tab. To do so, just long-press on the power button and click Restart from the screen, or turn off your phone and turn it on after 5 seconds. By this, any loops or glitches will be resolved automatically and you will be able to send messages within a click.
    Solution 2: Turn off airplane mode
    If your Android device’s Airplane mode is turned on, your phone will not be able to send messages. To prevent this, go to Settings > Turn off Airplane Mode (by sliding right to left).
    By turning off the Airplane Mode, you will get the networks and can continue SMSing!
    Solution 3: Remove the messaging app from the background
    Try to remove your messaging app from the apps running in the background. This may resolve app-related glitches. After doing so, continue sending messages to the required person.
    Solution 4: Update your phone
    Maybe you are using an outdated version of your Android phone, which can prevent you from sending messages. If that is the case, just update your Android device to its latest version and try to send a message again.
    See the following mini-steps to update your Android device:
    Your device can be updated according to your Android model, go to Settings > Software Update and install any pending updates or Settings > System > Advanced > System Update.
    NOTE: If there is an unresolved issue with the messaging app, just update it.
    Solution 5: Unblock the blocked numbers
    You might have blocked some phone numbers deliberately or by mistake and due to these reasons, you might face issues in sending messages to the ones you want to. To unblock these numbers, just follow the steps below:
    • Step 1: Go to your Dialpad of the Phone Bar and click on the Settings icon, from the top-right corner.
    Go to settings in dialpad
    • Step 2: Under Settings, click on block and filter bar, as shown below.
    Click on Block and Filter under Settings
    • Step 3: Under Block and filter, go to Block Messages section, as shown below:
    Block messages section under block and filter
    • Step 4: From Block messages, if you see the following screen, slide right to left in the column that says- “Block Messages from unknown Numbers”
    Slide off from block messages from unknown numbers
    NOTE- The above-mentioned steps may vary for different Android devices.
    Solution 6: Clear your SMS App’s Cache and Data
    This solution will clean all the junk files or unnecessary data from your messaging app, which can be an obstacle and you may wonder- ‘why won’t my messages be sent’. To resolve the same, follow the steps below:
    • Step 1: Go to the Settings of your Android device and click on Apps.
    Go to settings and click on Apps
    • Step 2: Under Apps, click on Manage Apps, as shown below.
    Go to Manage Apps
    • Step 3:  When you open Manage Apps, go to the Messaging Bar.
    Go to Messaging bar under Manage Apps
    • Step 4: Under this messaging bar, directly click on Storage.
    Click on Storage
    • Step 5: Under Storage, click on clear data, at the bottom of your screen, to clear all the junk data under your messaging App.
    Click on clear data under Storage-messaging
    Solution 7: Set SMS as your default messaging app
    This will set your in-built SMS app as default for the messaging services. So, that you use your in-built app whenever you are sending a message. To set it up, follow the steps below:
    • Step 1: Go to your Messages, and click on the Settings icon at the top right under the following section as shown below.
    Go to settings under messages
    • Step 2: Under Settings, change all the settings to the default settings.
    By this method, you will be able to set up your in-built messaging app as your go-to app.
    Solution 8: Check SMSC(short message service center)
    To choose the sim card services you want to use to access your default messaging services, follow these steps:
    • Step 1: Go to Messages, and click on the Settings icon at the top right, shown below.
    Under messages, go to settings
    • Step 2: Under settings, go to more message settings.
    Go to more message settings under settings
    • Step 3: Under more message settings, click on Message Center.
    click on message center
    • Step 4: From the following section after going to the message center, select the sim you want to use for your SMS services
    Select sim card
    By following these above-listed methods, we hope you are able to send messages on your Android.
    Happy SMSing!
    • SIM Not Provisioned MM2
      What is SIM Not Provisioned Error? How Can We Get It Fixed?
      Table of Contents What does the error SIM not provisioned error mean? Why does the...
    • iPhone Screen Replacement
      What to Do Next and How to Get an iPhone Screen Replacement If It Cracks?
      Assess the Damage: How Broken is It? You need to ask yourself: How badly is...
