How a 20-Person Office Decides Which Task to Automate First
| Updated on November 12, 2026
For 20-person staff office, the best first task is to consider which follows the same steps every time, and pulls a skilled person away from work only they can do. Then prove the time savings, then move to the next one.
 Most of the officers pick the wrong project first and then they chase most annoying tasks or newest AI tool instead of the one that returns the most hours.
 This article will guide you how to decide which task to automate first.
List Every Repeat Task For One Week
Ask everyone in the staff to note everything they did more than twice in a week and how long it took. Common entries show copying data from emails into accounting software, building the same weekly report, chasing clients for documents, answering the same customer questions, and moving leads between a form, a spreadsheet, and a CRM. Many offices find 20-40 items that become your automation backlog.
Score Each Task On Four Questions
Give each task a score from 1 to 5 on:
  1. Frequency. How many times does this repeat?
  2. Time per round. Ten minutes repeated 30 times a week adds up to five hours.
  3. Consistency. Check whether each step follows the same procedure each time, or if it needs judgement?
  4. Cost of mistakes. Check whether any error annoys a client or creates any compliance problem.
Multiply frequency by time to get weekly hours, then favor the consistent tasks. A high cost of mistakes means a person should review the output at first. It is rarely a reason to skip the task.
Pick The Task With The Clearest Payback
Now choose the top three by weekly hours and estimate the payback. If a task takes 8 hours, it costs the office $40 per hour. That comes to about $16,000 a year, so a build costing a few thousand dollars pays for itself within a few months.
Choose the one you can measure easily. A clear before and after number makes the team trust the next project.
Check The Tools You Already Pay For
Before purchasing a new tool, first look at your current software. Microsoft 365, Google Workspace, QuickBooks, and Most CRMs include automation features that often sit unused. But Zapier or other tools can handle simple handoffs between apps without code.
Ohio consultancy NVisionaryAI reports that one custom agent it built saves about 20 hours a week of manual research and reporting, which is the kind of result worth aiming for on a first project.
Keep A Person In The Loop At First
Check the automation alongside the manual process for two weeks, then check every output. Once errors drop to near zero, switch to spot checks.
Common First Picks For Small Offices
  • Pulling invoice or receipt data from email into accounting software
  • Sending document reminders to clients
  • Building a weekly sales or revenue report
  • Drafting replies to common customer emails for staff to approve
  • Routing new leads to the right person
The Takeaway
First write the repeat work, score its frequency, time, consistency, and risk. Later, start with the task that saves the most computable hours. One well-chosen win builds the trust and can fix the budget for the next five.
Which four questions should you consider to automate the task?
First, check the frequency; then the time per round, consistency, and cost of mistakes; these four questions you should consider.
What are the strategies of automation?
An effective automation strategy is a structured end-to-end plan that unifies tools, processes, and teams to replace manual effort with repeatable technology.
Which task is best suited for automation?
Tasks best suited for automation are repetitive, rule-based, predictable, and high-frequency.
