As a business, Monoprice has established an outstanding reputation for its products and customer support. Worldwide, consumers and professionals can choose from more than 7,000 high-quality, reasonably priced electronics and accessories at Monoprice.
The Monoprice 110010 headphones should be in your shopping cart right now if you’re looking for wireless headphones with respectable noise cancellation and good audio quality.
Monoprice Headsets
You can choose from a wide range of features with these headphones. For instance, comfort (if you enjoy playing video games for a long period), incredible sound quality, background noise suppression, and even longer battery life.
You will have a lot more mobility with these wireless headphones because you won’t have to deal with the cord constantly. You can utilize it as you go about your regular activities. Monoprice 110010 is excellent even for working out in the gym. Here are a few reasons for purchasing Monoprice headphones.
Also, Read: Bose QuietComfort 25 Headphones Review: Are They Worth the Hype?
Monoprice 110010: Features
In this section, we will discuss the highlights of The Monoprice 10010 headsets. Let’s examine them.
Sound Quality
These headsets are budget-friendly headphones with acceptable sound quality and little distortion. Thanks to its 40 mm driver and low noise design, they are easy-to-use headphones that deliver respectable quality for any headphone user.
The headphones’ bass, treble, and midrange audio are of good quality, and they are most appropriate for quiet settings like at home or when you’re playing video games alone.
Battery Life
With the Monoprice 110010, the battery life is excellent for the pricing category at 52 hours. If you enjoy gaming or binge-listening to music, that is more than enough.
You won’t need to recharge these headphones occasionally. Worry not if you have a limited budget because their price is reasonable given the incredible features they offer.
These headphones will also be useful if you frequently travel and enjoy listening to music while riding a bike or driving a car without a roof. They don’t require recharging after several episodes of your favorite TV show or movie, and they are comfortable to wear.
In general, the Monoprice 110010 headphones are a good choice if you’re looking for a good pair of wireless headphones with long battery life.
Read This Also: An In-Depth Review of the Turtle Beach Recon 50X 50P Gaming Headset
Noise Cancellation
The sound is balanced, and the headphones also block out noise to prevent disturbing those nearby. They are good at noise isolation and noise blocking, but you won’t be able to hear the sounds coming from the headphones if you have to wear them in a noisy setting.
Design & Build Quality
The Monoprice 110010 headphones are less durable and lightweight than already existing higher-end models. The rubberized headband of the metal-made headphones. The ear cups, however, are made of inferior plastic.
The cable can either stay connected or come loose depending on whether you use Bluetooth or not. The headphones only weigh 6.3 ounces or less, making them a lightweight option.
Comfort
Low pressure on your ears is facilitated by the headphones’ adaptability. However, people with larger ears find it difficult to wear them due to the small ear cups. The headband is not particularly comfortable because it is not properly cushioned.
The headphones are an excellent option for use while talking on the phone because of their lightweight design.
Water Resistance
Unfortunately, the Monoprice 110010 headphones are not sweatproof or waterproof, but they are water resistant. This means that even though you shouldn’t let them get close to water, they are built to withstand accidents as long as you act promptly to get the water out of them.
If you’re interested in using headphones while working out or when near water, you can look at Monoprice’s Move Wireless Bluetooth Earphones, which are sweatproof and waterproof options with an IPx7 classification for waterproof capabilities.
Microphone
The microphone is adequate, and thanks to the Monoprice 110010 set’s Bluetooth capabilities, you can make and receive hands-free stereo calls while being up to 32 feet away from your paired Bluetooth device. However, because the microphone is sensitive to sound, it’s possible that it will pick up ambient noise, which could cause your voice to sound distorted.
Monoprice 110010: Pros & Cons
PROSCONS
Great audio reproduction in the midrange and bass.Poor quality headband.
Simple and effective button design.Small ear cups.
Monoprice 110010 Price
When it comes to inexpensive electronics, Monoprice is a very reputable brand. The Monoprice 110010 headphones are no exception, providing excellent sound quality for a portion of what other premium brands charge.
For gaming or home entertainment systems, the Monoprice 110010 is a cost-effective and dependable option with a price under $50. The Monoprice 110010 is a fantastic choice if you’re looking for affordable headphones that don’t skimp on sound quality
Final Verdict
Although it may not be as good as those expensive headphones, it does have some unique qualities that set it apart, and make it worthwhile to purchase despite its higher cost. It has a noise-canceling feature that has many advantages, including the ability to transmit crystal-clear sound to the person you’re speaking to.
Its audio quality is excellent, and you can experience even more audio magic if you enable the AAC or SBC codec features. If you like gaming and listening to music for longer periods of time, its 52 hours of continuous battery life on a single charge is quite good.
On the other hand, it also has a strong Bluetooth connection and supports Bluetooth 5.0. Monoprice 110010 is a worthwhile purchase when all of these features are taken into account.
