Are the Bose QuietComfort 25 Headphones really surpassing all the past models in every way? To find out whether they really stand out as a quick recommendation, we are here with a thorough hands-on review after testing them out.
Associated with good quality sound products, Bose is a renowned brand that has been the old player in the market for an extended period of time now.
Back in the day, it had its own era where it had many best headphones on the market. Not that it doesn’t have those anymore, because it is quite the opposite. The signature Bose sound has only improved over time, and we can’t deny that.
While there are various good headphones to choose from, one that has been the talk of the town is Bose QuietComfort 25 headphones, which came after the QuietComfort 15 headphones.
So we are here to test them out ourselves and let you know whether they are really worth it, as we have penned down our thoughts in the following detailed review.
Bose QuietComfort 25: Overview
The Bose QuietComfort 25 are acoustic and active noise-canceling headphones that are not only excellent in the smooth elimination of low-register noise but also successfully remove any frequencies which can possibly ruin your sound. And this makes you increase your volume due to the disturbing noise, which can be annoying.
Being a staple for offering one of the best AVC headphones, Bose has surely succeeded in making a name of its own over the years. With newly modified designs and catching up on the change of latest requirements needed in headphones, the Bose QuietComfort 25 might be your next pair of headphones.
With enhanced sound quality and noise-canceling, which is as good as ever, are Bose QC 25 headphones really the right ones for you? Find out by following the given below review and see if they can work for you.
Bose QC 25 Specs
To get a basic idea about the specifications of Bose QC 25 Headphones, we have prepared a table for you to help you understand it in a simpler way.
TypeOver-Ear Headphones
Frequency Range N/A
Cable Length 56”
WirelessNo
Weight 6.9 oz (excluding cable)
Dimensions 1.8 × 6 × 7.5 inches
ConnectionStereo 3.5 mm
Battery Life35 Hours of Playback
Battery Type 1x AAA
CaseYes
Water Resistance No
In-line Mic/Remote Yes
Active Noise Cancellation Yes
Price $299
Now that you know about some specifications of Bose QuietComfort 25 Headphones, let’s head over to their pros and cons and see which one weighs more.
Pros and Cons
As it is only a plus point to go through a product’s review before you consider buying it, paying attention to its pros and cons is an even more significant step one should go on with. So now, let’s move on to the pros and cons of the Bose QuietComfort 25 Headphones.
ProsCons
Excellent Noise CancellationExpensive
Clear and balanced soundThere is no function to auto-off
Comfortable to wearAAA batteries are not rechargeable
Better built compared to older modelsThere is an extra $100 charge for color
Even at higher volume, there is no deformation of sound.
After pros and cons, it is vital to go through the price of the Bose QuietComfort 25 headphones and see what options they have, since pricing plays an important role in the reviewing of a product.
Pricing
Apart from pros and cons, another essential factor that one has to keep in mind is the pricing of the product before getting it. And it is no surprise that if you’re planning to get headphones, the ones with Active Noise Cancellation (ANC) don’t come cheap.
So if you think that buying the Bose QuietComfort 25 Headphones will go easy on your pocket, we can’t really agree. But there is no doubt about this pair of headphones having a recognized name when it comes to Active Noise Cancellation (ANC). The Bose QuietComfort 25 Headphones come at a price of $299.
However, since they have now been discontinued, they are currently available on Amazon for $209.81 for the black color headphones and $229.99 for the white ones. You can also buy them in refurbished or used condition from eBay
We will advise you independently and in an unbiased manner to only go ahead with purchasing the Bose QuietComfort 25 Headphones if their price suits your pocket.
Build and Design
Another point that many prefer to consider while making a purchase of headphones is their build and design. Even though most of the earlier range of Bose headphones were gray, and weren’t really at the height of design, Bose ditched the idea and launched QuietComfort 25 headphones in 2 colors – white and black.
But if you think that these two are too basic or boring, you can actually get the pair for any color you want by ordering them. But there is a catch, if you want to color customize your Bose QC 25 headphones, you will have to pay a charge of an extra $100 for that.
Bose QuietComfort 25 Headphones Design
If we have to start with the size of its pads, they are smaller than the ones on QuietComfort 15 headphones, but if you don’t really care about those and prefer comfort and sound over them, they do just fine. You can also get a pretty nice and comfortable fit as they are adjustable, lightweight, and include a case as well.
Who doesn’t want a good combo of sound and noise cancellation? And Bose QuietComfort 25 provides just that. Even though there is still the involvement of plastic, they help in giving a classy feel to the headphones. There is some bit of fabric present on the headband, from the outside and inside, and the dome of ear cups are made of metal.
The overall build of Bose QC 25 headphones is solid, and this makes them easier to carry. The design is average as well and gives a simple yet fresh look to the headphones. The Bose QC 25 headphones are not wireless and have a cable for both Apple and Android devices. However, in the case of Apple devices, you might not be able to use them with the latest iPhones due to different port types.
If you are looking for wireless headphones, you can check out Monoprice 110010 headphones
Sound Quality
When it comes to delivering sound quality of higher standard, Bose doesn’t step back and makes sure to offer the best from its end. To give a mesmerizing music experience, there is no doubt that the Bose QC 25 headphones have succeeded.
The QC 25 headphones don’t disappoint when it comes to sound quality and let the music do the talking. And if you don’t want any sound to be missed or unclear, the QC 25 headphones surely do the task just right. There is clarity to the sound and the bass is definitely no slouch to please and satisfy the bass heads. The overall experience in the sound quality of Bose QuietComfort 25 headphones may not be a top-notch one, but it certainly doesn’t disappoint either.
Battery Life
When thinking about getting a gadget, be it from phones to laptops, or headphones, one of the most significant points that one keeps in mind is the battery life of the product. And if the battery life is not on point, it’s a big NO!
If you are looking for a pair of headphones that have a rechargeable battery, the Bose QuietComfort 25 headphones aren’t the best choice. Since most of the manufacturers have shifted from replaceable batteries due to the inconvenience of having to change them when they run out of charge.
Battery slot in QC 25 Headphones
The Li-ion battery is not rechargeable which is a bit disappointing, but it gives a playback of 35 hours. While it is easy to change a battery, you still have to keep buying batteries, though. So if you are someone who wants to carry their headphones around with them most of the time, you can go for other options. But, if you are okay with carrying the battery along and changing it when needed, go for it.
Performance
It is only natural that everyone wants the performance of the headphones that they are planning to get should be efficient. And we can assure you of this part here. When it comes to delivering the best well-balanced presentation, the Bose QuietComfort 25 headphones work just fine.
There is no doubt that factors like agility and precision are visible in the Bose QC 25 headphones and offer clear depth in sound with clarity. Their open treble stops hardening at any genre or level of volume. The noise cancellation is up to par as seen in most Bose headphones. The design also presents a decent look for headphones, and they are lightweight, making them portable for both work and general use. Hence, the Bose QuietComfort 25 doesn’t have much in the box to disappoint.
Usability & Connectivity
If you are looking for headphones that have good connectivity and usability, the Bose QuietComfort 25 headphones are neutral as a choice. Now you may wonder why? Well, since there is no option for Bluetooth connection in the Bose QC 25 headphones, you can’t connect them wirelessly.
In fact, to start with, there is a cable attached to the headphones that are connected to the device from which you want to listen to music or simply use the headphones. On the other hand, in the case of usability, the only major part that the headphones lack is a non-rechargeable AAA battery.
Noise Cancellation
One of the most important factors in headphones is their ability to noise cancellation at a maximum. So are the Bose QuietComfort 25 headphones any good at it? Well, they absolutely are.
While the older models of the Bose QuietComfort helped with noise cancellation efficiently, the QC25 takes the experience even further. There have been some improvements in the headphones, which don’t include many changes in noise cancellation.
Bose QC 25 headphones offer quite awesome noise cancellation, and they can be used easily by the switch given on the right up to simply turn it off and on (there is no auto-off function, hence, the switch). But, keep in mind that you have to turn them off when not in use as it can drain the battery (it won’t kill them as they offer 35 hours on a single battery).
Ear Cups of Bose QuietComfort 25 Headphones
In case you missed the Battery Life section and now wondering what battery we are talking about, it is not a charge and in fact an actual battery. A non-rechargeable AAA battery is used in the Bose QC 25 headphones, which need to be changed once its charge is over.
Water Resistance
Unfortunately, the Bose QuietComfort 25 headphones are not water or sweat-resistant. However, they are waterproof to some extent (not that you can wear them in your shower). They can survive minor accidents as long as you can act swiftly and get them out of the water quickly.
If you want headphones that are waterproof, you can check out the Bose QuietComfort 35 II Headphones. They are a good choice if you want AVC as well.
QC25 vs QC15
Every headphone has its own unique and different aspects, one scores higher than the other on a different basis. Be it for their comfort, design, or other features. And many often compare the QC15 and QC25 headphones by Bose for their own respective reasons. So are they really similar, just like their model names, or have a world of difference in their features and specs? Let’s find out.
While they both have their own advantages and disadvantages, doing a comparison between the two won’t hurt. Following is a table that we have prepared, so you can have a better understanding of the differences between the two in a simpler form.
Basis QC25QC15
DesignWinner 🏆👎🏻
Comfort Winner 🏆👎🏻
Battery Life👎🏻Winner 🏆
Sound 👍🏻👍🏻
Noise Cancellation Winner 🏆👎🏻
As per our analysis, we have come up with the above-given respective results. However, they can also vary from person to person and what type of music they prefer to listen to. The same goes for the feel of comfort they will get once they try both pairs on. Hence, the final outcome is for you to decide.
Final Verdict
So now coming to the most important parts – while there are always better choices out there, you’ve to be the judge and decide what works best for you. As you have made it to the end of the review of QuietComfort 25 headphones, you may have already got an idea of what are the different features and pros and cons of them.
Even though most of the major points are discussed in the review in a detailed manner, it is completely up to you whether you want to go ahead with purchasing the Q 25 headphones. Considering its price, battery life, and other factors, and what you actually want them for – gaming or listening to music in general, also matters. Taking comfort into account will also help to come up with the right decision.
