Zoom AI Recording: What It Does, What It Misses, and Better Alternatives
| Updated on May 28, 2026
zoom
Employees spend 11.3 hours per week in meetings, which works out to almost a third of the average workweek. The real surprise is the work that starts after they end: notes, summaries, follow-ups, reports, and presentations.
Zoom’s AI Companion promises to reduce that burden. It can summarize conversations, organize transcripts, and surface action items automatically. Helpful? Definitely. But if you’ve ever needed to turn a meeting into a slide deck or visual report, you’ve probably discovered where its usefulness ends.
In this guide, I’ll tell you exactly where Zoom AI recording shines, where it falls short, and which alternatives can save far more time afterwards.
  • Zoom AI Companion works well for summaries, transcripts, and quick meeting recaps.
  • It cannot generate slides, visual reports, or polished deliverables.
  • Dedicated tools like Notta offer cross-meeting analysis and visual asset creation.
  • The biggest productivity gains often happen post-meeting, not during it.
What is Zoom AI Companion Recording?
Zoom AI productivity suite makes meetings easier to revisit and understand, generating summaries and dividing the transcript into “smart chapters”.
Think of it as a helpful meeting scribe. It joins your call (as a visible bot) and takes notes. Afterward, you get a text file of who said what and a bulleted summary. It’s included at no extra cost with certain paid Zoom plans. This makes it a great starting point for basic note-taking.
What Does Zoom AI Recording Actually Do?
Zoom AI Companion covers the essentials well. Once enabled, it works behind the scenes to organize discussions and reduce manual note-taking.
  1. Generates Summaries: After the call ends, it creates a concise, bullet-point summary of key discussion points and decisions.
  2. Creates Smart Chapters: It analyzes the transcript and automatically breaks it into sections with labels like “Project Timeline Review” or “Q&A.”
  3. Provides Next Steps: It can highlight potential action items mentioned during the conversation.
  4. Answers Questions: You can ask the AI questions about the meeting content, like “What did Sarah say about the budget?”
Its main strength is integration. You don’t need another app. The summary appears right in your Zoom history. For a quick recap of a straightforward internal call, it’s often enough.
The Key Limitations of Zoom’s Built-In AI
Convenience has limits. Zoom AI Companion helps capture meetings, but it stops short of transforming that information into something teams can immediately use.
  • No Visual Outputs: It produces text only. You won’t get a PowerPoint slide, an infographic, or a formatted report. You must manually create any visual asset from the transcript.
  • Limited Language Support: It primarily transcribes in English. It lacks deep support for dozens of languages and cannot perform bilingual transcription (hearing two languages at once).
  • No Cross-Meeting Analysis: It works on one meeting at a time. You can’t ask it to analyze themes or extract data from last week’s sales call and this week’s product review together.
  • Bot-Present Required: The AI joins in as a visible participant. Some attendees find this distracting, and it can’t record if someone is using a personal meeting link.
  • Platform-Locked: The features only work within the Zoom ecosystem. You can’t use it to record in-person conversations or process audio files from other sources.
Zoom is ok if you need text summaries, not for using the content for a deck, a client report, or a training infographic.
What to Look for in a Dedicated AI Meeting Tool
The next-gen tools not only remember conversations, they turn discussions into outputs that teams can immediately act on.
  • Generation, Not Just Transcription: The tool should create finished work—slides, reports, emails—not just a transcript.
  • Broad Capture Scope: Can it record online meetings and in-person conversations and upload files? A unified platform saves hassle.
  • Visual Outputs: The ability to auto-generate infographics, comparison matrices, or flowcharts from discussion is a massive time-saver.
  • Deep Language Support: For global teams, look for real-time translation and transcription in many languages.
  • Invisible Recording: A “bot-free” mode that records locally on your computer keeps the meeting focus on people.
The best tool acts like an assistant who attends the meeting, then goes back to their desk and delivers the polished deliverables you need.
INTERESTING STAT
According to a survey, 20% workers now use AI tools to automatically generate meeting notes and 30% have skipped meetings altogether, trusting digital assistants.
Top Alternatives to Zoom AI Recording
Here are the top three Zoom alternatives that’re as good or even better.
1. Notta: From Meetings to Finished Work
Notta is an AI-powered meeting productivity platform that captures conversations, but its standout feature is Notta Brain. This AI Meeting Execution Engine works after the meeting ends to turn the raw transcript into finished work.
Key Strengths:
  • Notta Brain Creates Deliverables: This is the big differentiator. Feed it a meeting, and it can output ready-to-use slides (PPT), infographics, reports, and action lists. You can use @ to reference multiple meetings for combined analysis.
  • Wide Capture Range: Use the Bot-Free Desktop app (invisible, works with any software), the Notta Memo physical recorder for in-person chats, or upload files. Everything is centralized in one place.
  • Superior Language Handling: It transcribes in 58+ languages and offers bilingual simultaneous transcription—a rare feature.
  • Strong security (SOC2, HIPAA) and deep integrations (Slack, Notion, Drive).
Considerations:
  • Its free plan is limited (120-200 mins/month). Processing deliverables isn’t the fastest.
  • It’s growing in the US market, so brand recognition is building.
Best For: Teams that need meeting content turned directly into visual assets, reports, or slides without manual work. It’s ideal for consultants, marketers, and project managers who present findings.
2. Otter.ai: The Transcription Powerhouse
Otter.ai is a well-established AI transcription and note-taking service. It’s known for accurate transcripts and a user-friendly interface.
Key Strengths:
  • Very Accurate Transcripts: It has a long history of reliable, clear transcription quality.
  • Live Collaboration Features: Participants can highlight, comment, and add photos to the live transcript.
  • Simple Integration: It joins calls as a bot and works smoothly with Zoom, Teams, and Google Meet.
  • Affordable entry point for individuals.
Considerations:
  • Its AI stops at summaries and action items. It doesn’t generate slides, infographics, or other visual reports.
  • The bot must be present in the call. It lacks an invisible, local recording mode.
  • Language support is less extensive than some competitors.
Best For: Individuals and teams whose primary need is a highly accurate, searchable, and collaborative transcript. Great for journalists, students, and legal professionals.
3. Fireflies.ai: The Sales & CRM Focused Tool
Fireflies.ai is an AI meeting assistant with a strong focus on sales teams and CRM integration.
Key Strengths:
  • Deep CRM Integration: It automatically logs call notes, summaries, and action items into Salesforce, HubSpot, and others.
  • Conversation Intelligence: It analyzes talk time, sentiment, and can even track competitor mentions or pricing discussions.
  • Customizable Workflows: You can set up automation to share summaries with specific channels or people post-meeting.
Considerations:
  • Like Otter, its outputs are text-based (summaries, snippets). It doesn’t create visual deliverables.
  • The AI bot is a required meeting participant.
  • Its pricing is higher for teams needing unlimited storage.
Best For: Sales and customer success teams that need to automatically capture call details and insights directly into their CRM. It’s built for revenue operations.
Side-by-Side Comparison
Here’s the comparison table for all four services.
FeatureZoom AI CompanionNottaOtter.aiFireflies.ai
Core OfferingBasic summaries & chapters in ZoomAI platform that creates slides, infographics, reportsAccurate transcription & live notesCRM-focused meeting intelligence
Key DifferentiatorFree with paid Zoom plansNotta Brain delivers finished workCollaboration during live transcriptAutomatic CRM logging & sales metrics
Visual Outputs❌ No✅ Yes (Slides, Infographics)❌ No❌ No
Recording MethodVisible bot in ZoomBot-Free Desktop (invisible) or botVisible botVisible bot
Language SupportPrimarily English58+ languages, bilingual transcription~10+ languages~10+ languages
Cross-Meeting AI❌ No✅ Yes (@ references)❌ NoLimited
Starting PriceIncluded (w/ paid Zoom)Free plan; Pro: $8.17/mo (annual)Free plan; Pro: $8.33/mo (annual)Free plan; Pro: $10/mo (annual)
Best ForBasic note-taking within ZoomGenerating deliverables, global teamsAccurate transcripts, collaborationSales teams, CRM integration
Verdict & Recommendations: Which Tool Is Right for You?
The right choice depends less on recording quality and more on what happens afterward.
Stick with Zoom AI Companion if: Your meetings are simple internal syncs. You only need a quick text recap and you’re already on a qualifying paid Zoom plan. Don’t pay for a new tool if this covers your basics.
Choose Notta if: You are tired of manually building decks and reports from minutes. If you need to transform discussion into a client presentation, a process infographic, or a polished summary email, Notta Brain does that work. Its zoom ai recording capability with the Bot-Free Desktop mode is also a clean, invisible way to capture any meeting. It’s the best pick for creating visual assets and handling multi-language meetings.
Choose Otter.ai if: Your absolute top priority is transcript accuracy and you want team members to add notes during the live call. It’s a fantastic collaborative notepad.
Choose Fireflies.ai if: You are in sales. Your non-negotiable need is automatically pushing call summaries, action items, and deal insights into Salesforce or HubSpot.
For most knowledge workers who present findings, a tool that generates finished work provides the highest return on time. Recording is just the first step. The real value is in how easily you can use that recording to communicate and execute.
Does Zoom AI record meetings automatically?
No, you must manually enable the AI Companion features before meetings. It does not record by default for privacy reasons.
Can Zoom AI generate a PowerPoint summary?
No, Zoom AI Companion cannot create slides, infographics, or any visual documents. It only provides text-based summaries and chaptered transcripts.
What is the most accurate meeting transcription tool?
Most top tools claim accuracy above 95%. Notta reports 98.86% accuracy, and Otter.ai is also renowned for high precision. The best choice depends on your specific accent, audio quality, and language needs.
How does Notta Brain work?
Notta Brain analyzes your transcript and automatically generates ready-to-use PowerPoint slides, infographics, and formatted reports. You don’t have to write prompts; it identifies key decisions and data to build the assets.
Are these AI meeting tools secure for confidential discussions?
Reputable tools like Notta, Otter, and Fireflies offer enterprise-grade security. Look for certifications like SOC 2 Type II, ISO 27001, and HIPAA compliance if you handle sensitive data. Always review a vendor’s security page before adoption.
