How to Avoid Common Network-on-Chip Design Mistakes in Complex SoCs
| Updated on November 12, 2026
As such designs of systems on chips become more complex, there is also an increasing need to ensure effective connection between different elements within them. There needs to be continuous communication within processors, memory controllers, and various accelerators.
It is only through the network-on-chip (NoC) that communication becomes possible; however, even small flaws in the design will cause severe impacts on the performance of the whole chip.
A correct network design from the very beginning will help to avoid expensive redesign at later stages of development. It is important to know typical design mistakes to avoid them.
Choosing a Suitable NoC Layout
One frequent error is selecting a NoC layout based only on how simple or familiar it is. A basic grid might work for a regular arrangement of components, but complex SoCs often contain units with varying communication needs. A fast hardware accelerator linked to multiple memory controllers generates significantly more data flow than a simple interface block. If the layout is not tailored to these differences, busy links become bottlenecks while other network sections stay idle. A well-planned NoC interconnect helps engineers account for these varying communication demands and choose structures that support efficient data movement.
Engineers are urged to match various layout options with physical floorplans, the estimated methods of communication, and the time needed for those actions. Rings, trees, and layers imply their own trade-offs with respect to connectivity, complexity, potential, and wiring. Layering of data networks separates traffic within each layer, reducing the load on common links, while direct linking is beneficial for paths with high data traffic. Earlier models and data analysis can tell whether the network design would be able to handle its load.
Evaluating Data Flow Styles & Congestion
Another common mistake is building the NoC based on average speed estimates without considering peak data flow or simultaneous tasks. Multiple processing units might ask for data from the same memory controller at once, while an accelerator produces long bursts of data and other units send time-sensitive requests. Even if total capacity seems high enough, competition at shared links, switches, or memory ports causes long delays. Average usage figures often hide the difficulties.
The analysis of the data flows will be best achieved when the analysis is done by considering real-world workloads, traffic bursts, different-sized data flows, and situations where multiple units are concurrently active. Engineers are supposed to focus on bottlenecks, usage, capacity, and the variability of the delays rather than just relying on aggregate speed. The stress test needs to take care of data flow combinations that are expected to happen during heavy load conditions. Having ample capacity and redundant routes helps reduce congestion, but having additional hardware without proper planning causes growth and energy consumption.
Directing Data & Avoiding System Stalls
Selection algorithms decide how data packets move through the NoC, which affects wait times, congestion, and resource use. A frequent design error is choosing a direction strategy without thinking about the specific data types or how resources rely on one another. Fixed path selection is simple to build and test, but it often crowds data onto specific paths even when other routes are empty. Flexible path selection distributes data more effectively, though it requires more complex logic and testing. Understanding network on chip technology helps engineers evaluate these routing approaches and their effects on system performance.
The engineers need to make sure there are no stalls or deadlocks in the design phase. A deadlock is the situation where packets are holding on to network resources, but waiting indefinitely for other resources that are being held by some other packets. It is the job of designers to make sure that the configuration of channels and virtual channels, along with the limitations on paths, does not form a circular wait. Any changes in data routing done towards the end of the project will need new analysis because even the slightest change impacts safety.
Setting Storage & Virtual Channels
Small buffer sizes lead to backpressure that prevents previous switches from accepting new packets, thus reducing the overall throughput even if other links further down the chain are open. The problem with too much storage capacity is that it will increase the silicon area and power consumption. One major mistake is to allocate similar storage capacity to all routers without considering the variations in data amount, link speed, and processing speed of the following unit.
Storage settings are most effective when they match the needs of specific network parts and the behavior of attached units. Virtual channels separate different types of data or tasks that use the same physical wires, which makes better use of resources and manages blocks. Virtual channels also need extra memory and control logic. Engineers are encouraged to check how full buffers are and monitor backward pressure under real work conditions before finishing the design. Simulations that include burst data and busy destinations show if buffers are the right size for constant use.
Maintaining Service Quality
Many Complex SoCs usually have a combination of control signals, memory accesses, video streams, and accelerators’ data in the network. If all the requests are treated equally, then the large amount of data will cause problems for requests with stringent time constraints. For example, the steady flow of accelerators’ data may cause delays in control signals and other time-constrained transfers.
Service quality tools are used to set clear priorities and measurable goals for important data types. Rules for choosing which data goes first, reserved speed, data shaping, and virtual channel separation help keep critical tasks safe from interference — these tools are best tested under heavy, competing workloads rather than alone. Designers are also tasked with ensuring that low-priority data is not ignored forever and that priority rules are steady across the whole network. Specific timing and speed targets help determine if the build meets system needs.
Incorporating Physical Build Limits
A NoC structure that works well in a computer simulation might be inefficient once built in silicon. Long wires cause delays, use up routing space, and might need signal boosters or extra storage. Where routers are placed, crowding in the physical layout, and connections between different timing zones also affect quality. Ignoring these limits until the end of the project leads to expensive changes when the design is already finished.
Physical parameters prove to be effective mainly for determining which layout type should be selected as well as placing the routers. It is highly recommended to cooperate with the layout team to predict the wire length, wire congestion, time considerations, and power consumption. The analysis of the floorplan makes it possible to determine the routes that require local connections or a better positioning of routers. Also, it is expected that designs will deal with clock speed variation and various power zones.
Testing Protocol & Task Behavior
However, NoC testing concentrates on speed and wait time, but does not address rare logic errors. The complex SoCs perform multiple active tasks with different response times, as well as several components that operate in common locations. Logic errors in task scheduling, packets, and credits result in data errors or freezes even if speed testing was positive, since these errors are difficult to correct because of the specific timing moments.
Testing plans are most thorough when they cover logical correctness, speed, and stability. Automatic checks can monitor protocol rules, credit counts, task finishes, and correct ordering. Random data tests find problems that planned tests miss, while mathematical methods prove that the system will not stall. Testing also includes checking error signals, system restarts, and what happens when a destination stops taking data — these tests must match the final setup, including the specific connections used by the parts of the SoC.
Defining Clear Speed Standards
Another error is judging NoC quality using only one measurement. Peak speed might look good while the longest wait times stay too high, or a low average wait time might hide huge delays for one type of data. Electricity use also goes up if routers or links stay busy during inefficient data moves. Without an even way to measure success, teams might improve one part of the network while making the whole system worse.
The most comprehensive speed tests measure the amount of data transferred, average and maximum wait time, congestion, storage usage, size, and power consumption. The tests are conducted in realistic working scenarios and tough conditions, including peak times with resource contention. This enables engineers to make decisions that will benefit the whole system.
What is a Network-on-Chip (NoC) in an SoC?
The Network-on-Chip is the on-chip communication system connecting processing units, memory controllers, accelerators, and other SoC components. The network allows efficient data exchange within a complicated system-on-chip.
What are the most frequent Network-on-Chip design mistakes?
Most frequent errors include improper network design, incorrect calculation of peak traffic, ineffective routing algorithm application, buffer size choice mistakes, failure to consider service priorities, and late physical design verification.
How could engineers avoid congestion in a NoC?
They could conduct analysis of realistic workloads, identify busy links, perform tests of peak traffic, and offer appropriate network capacity. Alternate paths and better data distribution can also be used to mitigate congestion.
What performance metrics should engineers use when evaluating NoC design?
Engineers should take into account total throughput, average and maximum latency, link utilization, buffer occupation, congestion, silicon area, and power consumption. Realistic workload testing is necessary to evaluate performance better.
