    Guide » Tech » 7 Features to Look for in Your Next Motherboard
    Posted on October 23, 2020 | By Shinely Ainsworth
    Is it time to upgrade your PC? If it’s been a while since your last tune-up, you might be best to start from scratch. This means buying a brand-new motherboard.
    If your terminology is a little rusty and you don’t want to look like a noob to the salesperson, this guide will help. Just make sure that they cover off these essential features.
    1. The Right Form Factor
    You need to ensure that your motherboard is compatible with the form factor of your PC case. Some cases support multiple form factors, but never assume and take the extra time to make sure everything will work when you put it together.
    2. The Right CPU Socket
    If you’ve already picked up a CPU, then your motherboard options are going to be limited. For example, an AMD CPU won’t fit in an Intel socket as they are different shapes and sizes. So, if you’ve already got your AMD CPU, then you’re best to get something like the AMD B550 motherboard to ensure that it will work when you turn it on.
    3. Motherboard Chipset Features
    The chipset allows the hardware to communicate. If you get the wrong chipset, then the BIOS won’t detect the CPU or any other hardware. Check to ensure that the motherboard has the right chipset for the CPU; otherwise, you’ll either need to buy a new one or configure your BIOS.
    4. BIOS
    One of the features of a motherboard in a computer is that it comes pre-installed with a BIOS. This is what will detect the hardware connected to the motherboard. Ideally, you don’t want to update this yourself, so ensure that it’s got the latest version on the motherboard before purchasing it.
    5. Memory/DIMM Slots
    Memory slots come in groups of 2, 3, or 4 and support RAM installed on the motherboard. There are plenty of benefits of a good motherboard, but the most important is the number of slots available for your memory.
    This can differ according to the manufacturer. When you’re reviewing the b450 motherboard features or the MSI motherboard features, you should investigate the RAM requirements and availability.
    6. No Compatibility Restrictions
    The CPU socket, chipset, RAM, and motherboard must all be compatible for it to work. This doesn’t necessarily mean sizes. It also relates to the speed of the parts.
    7. Feature-Packed EFIs
    EFIs or Extensible Firmware Interfaces are more prevalent in modern computers. This software allows you to make tweaks and enhancements to ensure that your PC runs at full capacity. Make sure the motherboard you choose contains all the features that you need to make your adjustments.
    Need Another Assist?
    It doesn’t matter what part you choose first, as long as they all end up being compatible with one another. If you get the wrong ones, you’ll need to either replace your motherboard or hack your BIOS to get everything working.
    Technology is tricky sometimes. That’s why we provide helpful articles on the subject to help you out. Follow our blog if you want to learn more about the latest wonders in the world of IT.
      • The Most Expensive Skins in Rust
      • How to Log Out of Someone Else’s Apple ID without Password
      Banking and financial services constitute a realm in which security and performance are paramount. Therefore,...
    • CRM implemention conultant
      8 Things to Look for When Looking for CRM Implementation Consultant
      Did you notice the pop-up window that suggests you accept its cookies every time you...
    • Digital Project Manager
      What does a Digital Project Manager Do?
      While we are going through the digital era, working with pen and paper or whiteboards...
    • Consider Third-Party Helpdesks
      Telecom Tech Support Woes Troubling Your Small Business? Why You Should Consider Third-Party Helpdesks
      If your small business keeps running into telecom tech issues, it’s about time you considered...
    • multCloud
      MultCloud – A Brand New Cloud to Cloud Backup Solution in 2022
      How long have you stored your external hard drive in the unity room without using...
    • control-pc
      Easily & Efficiently Remote Control a PC from iPhone
      Why do We Need to Remotely Control a PC from iPhone? With the advent of...
    • Solar System
      On Grid Solar System vs off Grid Solar System
      Did you know that scientists estimate that approximately 80% of the US total energy needs...
    • Retail-Experience
      What Can Technology Do to Improve Your Retail Experience?
      The use of retail artificial intelligence services allows you to radically change the way companies...
    • Data-Storage-Companies
      The Value of Cloud Data Storage Companies
      Cloud computing has made a huge impact on the way we use technology for business...
    • Unlock Your iPhone
      How to Unlock Your iPhone If You Forgot the Password?
      Background: You've established a passcode on your iPhone to secure the information stored on it....
