Reasons and Solutions for Cloning Hard Drive SSD Taking Too Long
To know how to effectively solve this problem of cloning your hard drive to SSD taking too long, you can first understand the main causes of this problem by reading the section below and then try to fix the problem.
- The data size is too large.
- USB connection is slow.
- Bad sectors on the source drive.
- Old computer configuration.
- Target disk has bad sectors or read/write issues.
- Tool problems.
If it is due to too much data that needs to be transferred, then we recommend you to be patient. Usually, the more data you need to transfer, the longer it will take. You can take this time to do something else. If the read/write speed is slow because of the USB connection, then it is recommended that you use a SATA connection.
You can also check the CPU and memory usage to see if it is slowing down the cloning process. If there are bad sectors on the source or target disk, then it is recommended that you replace them with new or healthy disks. Of course, the easiest way to help you solve the problem easily is through free disk cloning software.
The Easiest Way: Use the Free Disk Cloning Software
The easiest way to fix cloning hard drives to SSD taking forever is using a free and safe disk cloning software like AOMEI Backupper Standard to help you. It offers Disk Clone, System Clone and Partition Clone functions to meet your different needs. More importantly, you can successfully boot your computer from the cloned SSD after cloning. It also has the advantages below. Keep reading for more details.
- By default, the software only clones the used sectors of the disk. Therefore, it allows you to clone a larger drive to a smaller one easily. If your source disk has bad sectors, don’t worry, it can clone a hard drive with bad sectors by skipping the bad sectors automatically.
- Tick the SSD Alignment feature to let your SSD perform better.
- This software is available in different Windows OS, including Windows 7, 8, 8.1, 10, 11, XP, Vista, etc.
Preparations:
- Since cloning a disk requires erasing all the contents of the target disk, it is recommended that you backup the important files of the target disk in advance to avoid data loss.
- Then download the free cloning software AOMEI Backupper Standard. In addition, if you are a Windows Server user, the AOMEI Backupper Server version is more suitable for you.
Step by Step Guide to Clone Hard Drive to SSD:
Step 1. First, launch AOMEI Backupper Standard and click Clone > Disk Clone.
Note:
The free version only supports MBR to MBR (system disks) and data disk clone. If you need to clone GPT to GPT, or clone disks between GPT and MBR, you can upgrade to the Pro version.
Step 2. Select a disk as the source disk and click Next to continue.
Step 3. Select the SSD as the destination disk. Then, click Next.
Step 4. You can tick the SSD Alignment option to accelerate the reading and writing speed of the target SSD. Then click Start Clone.
Tips:
- Edit Partitions: This feature allows you to change the partition size manually or automatically. Upgrade now to the Pro version (5% off for one computer) or higher editions to enjoy this feature.
- Sector by sector clone: When the target drive is the same as or larger than the source drive, you can use it to clone all the sectors.
Summary
If you are also troubled with the problem of cloning a hard drive to SSD taking forever, you can learn the reasons from the article and choose the easiest solution – clone disk by AOMEI Backupper.
It can clone your hard disk to SSD easily, even if the source disk has bad sectors, it can automatically skip the bad sectors for cloning. Whether you want to clone a disk to a larger or smaller one, it can meet your needs. And it can let the target SSD perform better during the cloning process. Download this software to explore more functions.
