The click speed test is a simple and fun way to see how fast you can click in a short period. It’s not just about the number of clicks you make in the time allotted it’s about seeing if you can work on your technique and improve your score over time.
This little game has been shown to help improve reflexes and overall hand speed, but it’s also helpful just for getting a sense of what you’re capable of doing with some practice.
So, we invite you to challenge yourself to compete with friends, compete with family, compete with coworkers.
What is a Click Speed Test?
The click speed test is a simple and easy-to-use tool for measuring the speed of your clicks. It measures the time between each click in seconds, and then it records the fastest score for each round for you. The click speed test is also known as CPS Test (Clicks per second).
This is the best tool for you if you want to know how fast you can click within a duration of 10 seconds or 20 seconds or 60 seconds.
You can also compare your top score against other players on the leaderboard. You can play this game with your friends and find out who is faster at clicking the mouse during a preferred time frame.
How is the CPS Score Calculated?
The CPS score is calculated by the given formula.
CPS= Number of Clicks/ Number of Seconds
Clicks per second refer to the number of clicks a person can perform in a given time. It is measured by recording the time it takes for a person to click a button as many times as they can and dividing that by the number of clicks made during the test.
The CPS score is calculated by taking the average of different tests.
Why Clicking Speed Matter in Games?
Whether you’re playing a game on your phone during an idle moment or you are a member of a professional esports team, one thing is clear: clicking speed matters.
As an individual, it might not seem like a big deal if you’re just gaming casually, but what happens when you find yourself in a heated battle against another player?
You might be at the top of your game, but if your clicking speed is slow, you might lose the match—all because of this one factor.
The importance of clicking speed in gaming can’t be overstated. If you want to take your game to the next level and compete professionally, this is one factor that you can’t afford to ignore.
So how does it work? It’s pretty simple: the faster you click, the faster your character will move or attack so long as the game’s mechanics allow for it.
The reason why this is so important is that if you’re playing against other players, there’s a chance that they have their clicking speed set faster than yours.
This means that when they click a button on their keyboard or controller, their character will respond more quickly than yours would. If both characters are engaging in combat and the enemy has a faster clicking speed than yours, you’re bound to lose.
How To Improve Mouse Clicking Speed?
You need to be able to click quickly to keep up with other players who are playing at a faster pace than you. There are several ways to improve your mouse clicking speed, but you’ll need to put some time into practice before it becomes second nature for you. Here’s how:
Use Gaming Mouse
Gaming mouse have features that make them the ideal choice for speedy clicking. These features include high DPI (dots per inch) and a high polling rate.
High DPI allows the cursor to move faster while on the screen, meaning that you don’t have to move your hand as far to move the cursor long distances on the screen.
A high polling rate means that the mouse sends signals to the computer at higher rates, making it so that your computer can see a “click” faster than it would if using a standard mouse.
Practice Various Clicking Methods
When it comes to mastering the art of mouse-clicking, practice makes perfect. The more time you spend practicing these methods, the better you will get at each one.
Many websites allow you to practice mouse clicking. Some of them even have leaderboards where you can see how fast other people click and compare your results with theirs.
You can practice various types of mouse clicking techniques such as:
- Kohi Clicking
It involves using your fingers in rapid spasms, where you need to use two fingers to strike the mouse alternatively.
- Jitter Clicking
Jitter clicking involves vibrating your mouse in a way that triggers clicks on the mouse. Keep your fingers touched to the left click button, and lift your wrist slightly to perform it.
- Butterfly Clicking
This method involves two fingers – the index and the largest finger – that you have to slam on the left mouse button.
- Drag Clicking
This method can be done with or without tape. It involves dragging your fingers across the surface of mouse buttons.
The method that works best for you will depend on factors such as the type of mouse and mouse pad you use and what kind of hand movement you are most comfortable with.
Position Your Hand Properly
You need to position your hand properly on the mouse. This is a very important step that can boost your click speed significantly.
The thumb should be placed on the right side of the mouse and curled towards the front of the mouse. The rest of the fingers should be spread out, with the four fingers resting on their corresponding buttons.
The index finger should be placed above the left button and the largest finger should be placed above the right button.
The ring finger and pinkie finger are generally not used in gaming, but you should still place them near their corresponding buttons just in case you need them for some reason.
Use High DPI Mouse
If you have ever gone shopping for a PC mouse, you may have heard the term ‘DPI’ or ‘dots per inch. It is basically the number of counts that your mouse generates when it moves an inch.
A higher value means your mouse will generate more counts while moving an inch and this results in a faster speed.
Most of the mice available in the market today come with a default DPI setting ranging between 800 and 1600.
However, if you want to increase the speed of your mouse even further, you can buy an ergonomic gaming mouse that has a DPI setting of around 2000 or more.
Find Perfect Mouse Grip for You
There are a few different ways to hold a computer mouse the most common is the “palm grip.” To do this, rest your palm on the mouse and spread your fingers across the buttons.
This is a good grip if you have larger hands and find that your fingers feel cramped when using most mice.
Another common way to hold a mouse is called the “claw grip.” To use this grip, place your hand on top of the mouse so that it forms a claw shape with your index finger and thumb.
This grip is sometimes also referred to as “the claw.”) Using this position allows you to click faster because it minimizes space between your fingers.
Take a Break and Relax Your Hand
It is necessary to take breaks while playing the game. Taking a break will not only relax your hands but also help you to get rid of back pain and headache.
Besides, taking a break will also allow you to think of the strategies and techniques to play the game better.
Benefits of Click Speed Test Games
One of the best ways to improve your mouse-clicking efficiency is to measure it, then work on improving it. That’s exactly what click speed test games do.
These games will tell you how many clicks per second you can go, then give you a score based on your performance.
Then and this is the important part they’ll let you try again and again until you’ve honed your skills to the point where they’re truly top-notch.
FAQs
Q1. What is the Highest CPS in the World?
Ans. The Highest CPS In the World is 14.1, but this is not 100% true. Google claims that the highest CPS in the world is 14.1, but there is no proof of this.
Q2. What is the Average CPS Score?
Ans. The average CPS is 6.69, and it is much easier to get a higher score on mobile devices than on desktops.
Q3. How Do You Check Your CPS in Minecraft?
Ans. You will have to make some modifications to the PvP client to be able to measure the CPS score in Minecraft.
Q4. What’s the Fastest Clicking Method?
Ans. The fastest clicking method depends on the type of mouse and surface you are using. Some of the popular click methods include drag clicking and butterfly clicking. If you want to try drag clicking, you can either use a piece of tape or just do it without tape. Drag clicking with tape is really what it says in the name, it’s literally dragging your fingers across the surface of mouse buttons.
