Do you experience keyboard issues with your MacBook Pro?
Is the MacBook keyboard not working properly?
Want to know how to fix the MacBook Air keyboard not working?
If you answered “yes” to any of the questions above or if your Macbook is having other keyboard problems, you’ve come to the perfect spot to have them solved.
A Mac keyboard not working can be really annoying. It is extremely annoying to learn that the keyboard on your MacBook can be problematic because you often purchase a MacBook because you want a high-quality laptop that is simple to use and doesn’t experience failures in hardware.
Additionally, even if you have an additional keyboard close at hand, your regular workflow may be disrupted because of this issue. But don’t worry; we’ll show you what to do to swiftly fix your MacBook keyboard and enjoy the Apple experience without any hassle.
Why is My Mac Keyboard Not Working?
Macs often have a smooth operation. However, during use, hardware- and software-related problems can undoubtedly occur. There is a possibility that a bug or an incorrect configuration is to blame for the problem. Furthermore, if you’re using a MacBook with a Butterfly keyboard, debris may be obstructing the keys’ line of travel.
The following are the most typical causes of MacBook pro keyboard problems:
- Dust and other impurities
- Misconfigured software
- Unreliable apps
- Bugs and errors
- Faulty hardware
Also Read: Apple MacBook Pro A2338 M1 Chip 2020 Review
Top Solutions to Fix a Macbook Keyboard
The first thing one needs to do if the Mac keyboard stops working is to clean the entire keyboard and trackpad too. You need to attach an extra keyboard and attempt a few more fixes if that doesn’t work.
Here’s how to fix a MacBook Pro keyboard not working:
Clean your MacBook keyboard.
Your keyboard can become quite dirty from grubby fingers, dust, spills, and pet hair. Your keyboard issues might be resolved with a quick cleanup. Take these actions to clean the Mac keyboard effectively:
Plug your MacBook out and turn it off, you won’t run the chance of sending an erroneous email while cleaning the keys, and you won’t risk moisture seeping inside your computer.
Shake your MacBook gently while holding it upside-down. Any substantial crumbs or dust on your keyboard should fall off as a result.
To remove loose particles, use compressed air or a soft brush. Dust off the tops and edges of each key with a gentle paintbrush. To prevent pushing dirt deeper into any crevices, it is preferable to do this while the keyboard is still turned upside down.
You can also use a compressed air can to blow anything lodged in the keys out if you have one. Spray the air across the keyboard in a zigzag pattern, rotate it, and continue the procedure until all four sides of the keys have been covered. Also, keep in mind to avoid spraying air directly under the keys, as this could harm them.
To thoroughly clean your keyboard, you can also ask professionals for assistance. Most of the time, this will make the keyboard function properly.
Install macOS Updates
It’s not always a smart idea to ignore updates; updates involve some sort of enhancement to the functionality of your Macbook, which can enhance user experience. But failing to apply an update can result in problems, and the keyboard is no exception.
Your MacBook’s keyboard may occasionally stop working if an update is not installed. Therefore, updating software is advised to resolve issues related to the Mac keyboard not working. This will probably fix keyboard issues and fix your Macbook’s functionality.
Also Read: Why is MacOS better than Windows for programming?
Delete Faulty Applications
Users frequently have keyboard problems after installing an app. After installing the program, you must remove it from your MacBook if you discover that your keyboard is no longer functioning. Usually, once the application has been removed, the keyboard will begin to function properly.
Ensure That The Slow Keys Option is Turned off
If the Slow Keys option is used, the keys on your MacBook keyboard will respond slowly, requiring more pressing and holding time before they appear on the screen. The following steps will ensure that Slow Keys are disabled:
Step 1: In the upper-left corner of your screen, click on the Apple icon.
Step 2: Click on Accessibility under System Preferences.
Step 3: Choose Keyboard from the left menu.
Step 4: Make sure the Slow Keys box is unchecked under Hardware.
Reset PRAM and SMC
Core values are stored in PRAM (Parameter Random Access Memory), and SMC (System Management Controller) controls the CPU fan and lighting. The Macbook pro keyboard problems might be solved by resetting them.
Resetting the SMC alone won’t work, so be sure to reset both. Be sure to take a suitable backup before resetting the PRAM and SMC. Additionally, you shouldn’t have any other external devices attached to the Mac while you’re working on it.
Also Read: How to Reset Keyboard in a Simple Way?
Restart Your MacBook
You can stop and end any running programs or processes that might be interfering with your MacBook’s keyboard functionality by restarting your computer. Restarting your MacBook frequently resolves keyboard problems. Check your keyboard’s functionality after restarting your MacBook, as this straightforward adjustment works in most cases.
I hope that one of the above-mentioned solutions will fix your Macbook keyboard and trackpad issue not working effectively.
After attempting all of these repairs, if your keyboard still doesn’t work or if only a few keys are functioning, you should contact Apple for assistance. Customer service can tell you if your MacBook is covered for free service. Due to flaws in the butterfly switch mechanisms, Apple fixes some keyboard issues without charging customers.
Frequently Asked Questions (FAQs)
Ans: Make sure the USB connector is firmly inserted into the USB port when reconnecting the keyboard by unplugging it and plugging it back in. Alternatively, you might try connecting the keyboard to a different USB port.
Ans: Press Command, Esc, and Option at the same time on your keyboard, then let go of the keys to swiftly unfreeze your Mac keyboard.
Ans: Pressing either the increased brightness or decreased brightness key will turn on the backlight. Additionally, you can access the Control Center, choose Keyboard Brightness, and alternately move the slider.
Ans: You must lock the screen or put the machine in sleep mode to lock your MacBook Pro keyboard. Use the keyboard shortcut+Shift+Power to lock the screen. Close the lid, press Command+Option+Power on the keyboard, or choose Sleep from the Apple menu to put the machine to sleep.
