How To Do Duet TikTok in a Few Easy Clicks
| Updated on November 28, 2026
TikTok offers so many creative features that can be used to interact with other creators and share content or collaborate with each other. One of the popular features is Duet, which lets you create a video alongside another creator’s original video.
You can use this feature to share reactions in viral trends, collaborate with friends, or add your own creative touch to existing content.
If you are new to TikTok, in this guide, we will show you how to do Duet TikTok videos step by step.
What is Duet and how to do Duet TikTok?
TikTok Duet is a feature that allows users to record their own footage while the original video plays next to it. This feature is commonly used for reactions, collaborations, challenges, and viral trends.
Duet is generally used by brands and creators to increase engagement with their audience.
Follow these easy steps to create your TikTok duet.
  • Open TikTok and find a TikTok video.
    Open TikTok and find a video.
  • Access sharing options.
    Click on the share icon.
  • Select Duet.
    If the Duet button is greyed out, it means the original creator has disabled this feature for that particular video.
    Select Duet.
  • Choose your Layout
    Choose Your Layout
  • Record your Video
    Record your video.
  • Edit your Content
    With these options, you can edit your reel.
  • Configure your Posting Settings
    Adjust your posting settings according to your requirements.
  • Publish your Duet
    Click on Post to post your reel.
How To Choose Who Can Duet With Your Videos on TikTok
TikTok also allows you to control who can create duets using your videos. This feature helps you manage your privacy and decide who can interact with you.
Duet is one of the best options to boost your account by making duets with trending videos and getting more likes. There are many other ways to get more views on TikTok.
Follow these simple steps to change your Duet privacy settings.
  • Open your TikTok Profile.
    Open Your TikTok Profile
  • Open Settings and Privacy
  • Go to Privacy Settings
  • Scroll down and find the Duet option.
    Scroll down and find the Duet Option
  • Choose who can duet with your videos.
How to duet in TikTok with others?
Open TikTok and find the video you want to Duet. Tap the share button, select the Duet option and your preferred layout, and start recording a video.
Why can’t I Duet someone’s TikTok video?
You cannot create a Duet if the video does not have permission for Duet or the account is private.
Can I edit my TikTok Duet before posting?
Yes, you can add text stickers, filters, voice effects, and adjust audio levels before publishing your Duet.
How do you do a Duet?
Duet on TikTok lets you record a video side-by-side or in a split-screen format alongside someone else’s content.
Can you duet videos on TikTok anymore?
Yes, you can still duet on TikTok.
TikTok Duet is a useful feature that allows you to interact with other creators through split-screen videos. You can use this feature to share your reactions, participate in challenges, and create entertaining content. For the Duet video, the Duet permissions must be enabled by the original creator before you can use their video. If you find this article helpful, you can check out more such guide videos on the Getassist YouTube channel.
