• AMD Radeon Pro WX 7100 Review (2023) – Features, Specs, Pricing, and More
    | Updated on August 7, 2023
    | Fact checked by Janvi Panthri
    ⭐ Editor’s Rating: 3.5
    AMD is undoubtedly a renowned graphics card maker that has always shown its impact on the market with every launch. It launched its Polaris-based Radeon Pro WX-series in 2017, which consists of 3 graphics cards.
    The fastest one among them is the AMD Radeon Pro WX 7100. Even though it is not the most powerful graphics card offered by AMD, it proves to be better than its higher-end siblings. Gamers usually have a heated debate regarding AMD Ryzen 7 2700x vs. AMD Ryzen 5 3600, but with the launch of the WX 7100, they have another option.
    That said, let’s get to the Radeon Pro WX 7100 review and help you make a decision after considering the specs, features, and other factors.
    Specs of AMD WX 7100 Pro
    The AMD WX 7100 Pro is based on the Polaris microarchitecture, which also falls under the category of 4th gen Graphics Core Next. So, if you want to know what this graphics card is capable of, read the specs below.
    FeatureSpecification
    GPU NameEllesmere
    GPU VariantPolaris 10 XT GL
    Release DateNov 10th, 2016
    ArchitectureGCN 4.0
    GenerationRadeon Pro Polaris (WX x100)
    Memory Size8 GB
    Memory TypeDDR5 VRAM
    Memory Bus256 Bit
    Memory Bandwidth224 GB/s
    Maximum Digital Resolution5120 x 2880
    Pixel Rate39.78 GPixel/s
    Power Connectors1 x 6-pin
    Weight2.1 lb (952.54 g)
    Dimensions (L x W x H)4.32 x 22.1 x 7.87 (CMs)
    ColorBlack
    Model NumberB06WVF8LCX
    PriceCheck the Latest Price
    Features of AMD WX 7100 Pro
    You can get an idea of the performance of AMD WX 7100 Pro for gaming from its specifications alone. However, a graphics card should run the games smoothly and have other features for error-free functioning. That said, let’s take a look at the key features that set the benchmark for AMD WX 7100.
    Gaming Performance
    The Radeon Pro WX 7100 boasts a Base Clock Speed of 1188 MHz and the Boost Clock Speed of 1243 MHz. Hence, it can handle continuous gaming to an extent that suits most gamers. In addition, the graphics card is able to run almost every popular game at 60 fps, even if you’re using a 4x4K monitor or two dual-cable 5K monitors. However, for high-end games like GTA 5, you may have to lower the settings.
    VR Testing
    The AMD Pro WX 7100 just passed VR testing and needs much improvement because it cannot run VR content at 90 FPS. It can run 3D CAD applications for sure, but it struggles if you don’t have a good-performance CPU. This could be the same for every graphic card that is Radeon Pro WX 7100 equivalent.
    Cooling
    The WX 7100 graphics card is equipped with a unique cooling architecture. It consists of aluminum fins closely attached to each other by a vapor channel. Also, the built-in fan can run up to 5000 RPM, which surely helps in cooling down the processor.
    Pricing
    The launch price of AMD Radeon Pro WX 7100 was $799, which is pretty high for such specifications. This is because you can get some other good graphic cards at the same price or lower, like the Nvidia GeForce RTX 3060 Ti. At the time of launch, WX 7100 is sure to be considered a high-end but expensive graphic card. However, with time passing by, the price went down, and you can now buy it on Amazon at $356.
    Pros and Cons of AMD Radeon Pro WX 7100
    To find out if the WX 7100 is a good offering by AMD, read these pros and cons below.
    Pros
    • Well-certified for all major CAD applications.
    • Long-lasting.
    • Excellent build quality.
    • Compact design.
    • Low power consumption.
    • Runs almost every game at low settings.
    Cons
    • Better options at the same price.
    • Can only run popular games on lowered settings.
    • Struggles when running high-demanding VR applications.
    Reading the pros and cons must have given you an overview of the GPU, but is it worth considering? Let’s find out.
    Why is Radeon Pro WX 7100 Worth Considering?
    The AMD Radeon Pro WX 7100 is a great processor as it works efficiently for video editing, rendering, and 3D workloads. If you’re a working professional with the given tasks in hand, this graphic card can work well for you. However, it may disappoint you with its gaming performance. AMD is not that great at running high-end games, whether you need them for your PC or mobile. You can take AMD Radeon RX 550 as a good example.
    AMD Radeon Pro WX 7100 – Customer Reviews
    WX 7100 has been purchased by several tech fanatics since its launch. And you can find out if the product is the best for your use or not after reading the following customer reviews:
    • The money paid great. Battery life great. Tire traction not so good.
    • Top notch for graphics design and image processing, even played a number of games with it. perfect.
    • It gave an extra life to my Mac Pro 5,1 mid 2010, super fast.
    • Made a big improvement in business graphic applications. Everything flow much smoother with no jerkiness, unlike my old graphic card. No problem with the installation.
    • Awesome price for performance! Stable drivers and 7TF of peak single precision compute. Great deal!!
    • I use Solidworks and this card provides feature I have not enjoyed before.
    We took these reviews from major e-commerce sites like Amazon and eBay, so you can consider them to find out the worth of the product.
    Wrapping Up
    The AMD Radeon Pro WX 7100 can be efficient and extraordinary as a workstation-class GPU. The reason – it is suitable for video editing purposes and running CAD applications. However, the graphics card can only run popular games on lowered settings and gives a below-average performance when running VR content at 90 FPS.
    The GPU works efficiently, but because of a single slot, you can expect it to be a bit more noisy than other options. Coming to its cost, the graphics card immediately got the tag “pricey” when it was first introduced to the market. But, it is available at a decent cost now. This may suit some users.
    FAQs
    Ans: Yes, you can run the game, but you may have to lower the settings for a smooth experience.
    Ans: The Radeon Pro WX 7100 is able to run most of the games. However, you may have to lower the settings for some.
    Ans: The AMD Radeon Pro WX 7100 graphics card has 8 GB of RAM.
    Author:
    Gaurav Rathore
    Bachelor In Science, University of Delhi
