Alienware Area-51
The dynamic gaming world always demands a gaming peripheral that is much more advanced and free from earlier ideas and designs. Alienware has always surprised its audience with exclusively designed desktops like Alienware Aurora 2019, which withstands not just the single task of gaming perfectly but balances your other video editing, spreadsheet, and document work in an outstanding way with zero complaints.
In this article, we will discuss one of the masterpieces constructed by Dell, i.e., Alienware Area-51 Threadripper Edition. Not only its hexagonal pattern is cool, but the graphic configuration of two Nvidia Geforce 1080 cards, 16 cores, and 32 GB storage with extra SSD units makes Alienware Area-51 a dreamer’s desktop PC.
Gamers would love to get authentic reviews of this exclusive equipment, so without any further ado, let’s move to comprehensive details on it.
Key Takeaway: If you are in love with multitasking which includes both gaming and balancing huge spreadsheets and video editing, Alienware Area-51 Threadripper Edition is the perfect desktop PC for you. With the epic design, you get a pair an AMD graphics, decent storage, numerous ports, and a stabilizing cooling system
Specification Table of Alienware Area-51 Threadripper Edition
The Alienware Area-51 Threadripper is the best discovery in desktop PCs ever, as it is capable of eternal gaming with high efficiency. The coming specification table gives a vivid view of Alienware’s desktop PC’s pleasing processing performance.
FeaturesSpecification
Operating System Window 10
ProcessorRyzen Threadripper 1950X 16-Core/32-Thread
GraphicsPair of Nvidia GeForce GTX 1080 Ti( room for 3 graphic cards)
Storage32GB RAM, 3TB SSD( divided as 1TB SSD and 2TB hard drive)
Cooling System Alienware Premium socketTR4 CPU Liquid Cooling
Ports USB 3.1 Gen 1 Type-AHeadphone 1/8″ PortMicrophone 1/8″ PortMedia Card ReaderE2500 Gigabit Ethernet PortUSB 3.1 Gen 2 Type-AUSB 3.1 Gen 1 Type-AUSB 3.1 Gen 2 Type-C w/ 15W SPDIF Digital Output
Price$6000
You can trust this epic beast with its intelligent graphic, processing, storage, and cooling system. The criticism around this exclusive desktop gleams with its high-performance score.
All-in-One Desktop PC: Alienware Area-51 Benchmark Features
Being a multi-purpose PC, Alienware Area-51 has various unconventional features wrapped in the configuration; it would be fun to know the reason which makes it a high-end gaming desktop. Interestingly, while you open the left side door of this desktop PC, a light turns inside the case helping in identifying various parts of the motherboard and around it.
Graphics
Alienware Area51 Threadripper graphics
Rating: ★★★★
Alienware Area-51 has room for up to 3 graphic cards. This masterpiece desktop PC comes with a pair of Nvidia GeForce GTX 1080 Ti, the major reason making this desktop is expensive. With 4k gaming, you can expect 80 fps which is decent for beginners but might screw up the mood of pro gamers. The maximum extended frame rate of 3D gaming with 4k resolution can be 84.
Area-51 does speechless performance at 1080p resolution, but it is still not a value for money as the user doesn’t expect to pay $6000 for a desktop PC that stumbles in giving an outstanding 4k performance.
Processing
Alienware Area51 Threadripper Processing
Rating: ★★★★★
The 16-core Ryzen Threadripper 1950X processor helps in the smooth gaming experience and is more advanced than previous models of Dell Alienware. It works as an uncompromising multitasker, thus leading to an excellent multithread performance in 4k gaming. Being a highly efficient processor is one of the prior reasons for turning this Dell Alienware a whole lot more expensive.
Design & Display
Design & Display
Rating: ★★★★★
You are completely going to love its awestruck-ing beauty construction, which is quite different from the old desktop PCs made by Dell. The irregular hexagonal structure with metallic frames and plastic panels makes this high-end quality desktop PC altogether a need. The silver and black color combination makes its display look aesthetic. Meanwhile, due to its irregular shape, you need to make quite a space for it.
The light inside the case and on the rear I/O card helps in the visibility of the components and connectivity, respectively, and this makes its display design look cooler.
Storage
Rating: ★★★★
Storage capacity is enough to ensure a smooth, unstaggering gaming performance with no issues of file storage in between your official task too. With 32 GB of RAM, you are gifted with 3TB of storage. The 3TB storage is divided into 1TB SSD and 2TB hard drives. You are going to face the least impediments in between the flow of your regular task due to any storage issue for sure.
Thermal Features
Alienware Area-51 Threadripper Thermal Features
Rating: ★★★★
Area-51 has got an Alienware Premium socketTR4 CPU Liquid Cooling system to manage all the heavy processing game energy. It has got slats for cooling where air passes through the PC, moves across the CPU and GPU, and exits back. The fan’s voice while playing extensive games is the least audible, ensuring an efficient airflow.
Ports
Alienware Area-51 Threadripper ports
Rating: ★★★★
There are numerous ports in Area-51, making it a desirable high-end desktop PC. First, there is a DVD slot in the front. Later on in the front panel, you also get USB 3.0 ports, a headphone jack, a microphone jack, and an SD card slot. This desktop PC also contains six display ports, two ethernet jacks, two HDMI jacks, an audio port, 3 USB 3.0 ports, two USB 2.0 ports, and one USB-C port.
Price
Rating: ★★
This Alienware desktop PC has got a hefty price of $6000 in the market due to several reasons. A huge space for three graphic cards, a high-end quality processor, ample storage, an attractive hexagonal shape, and numerous ports for connectivity, plus an efficient cooling system, announce Alienware Area-51 Threadripper as a future-proof desktop buddy. But the reason above still doesn’t account for such an expensive cost.
After having a comprehensive discussion on the features of Alienware’s Area-51 desktop PC, it would be interesting to view the pros and cons table ahead.
Pros and Cons
It is essential to know both the strengths and weaknesses of any technical product before buying it. The pros and cons table gives a brief description of the performance of Alienware desktop PC.
Pros Cons
Ample storage of 32GB RAM and 3TB SSD
Attractive Design with light support
Numerous ports
Efficient thermal system
Fast 16-core processor
USB C doesn’t have Thunderbolt 3 technology
Expensive
Outstanding Performance Review of Alienware Area-51 Threadripper Edition
Dell Alienware always pleases its audience with its advanced gaming desktops and laptops. Dell Alienware M15 R6 is a competitive gaming laptop, one of Dell’s inventions that has gathered mass customers’ cheers since its launch, the same as any other Dell gaming peripheral. Similarly, Alienware Area-51 Threadripper supports multiple thread performance and has various praise-worthy features that provide fluid gaming results.
  • Fast Processing: For a multithread performance, Alienware Area-51 Ryzen Threadripper 1950X 16-Core/32-Thread processor looks like a dreamer’s desktop PC. It can withstand various tasks together, from video editing to playing various extensive games altogether. While testing, it is found to be the best desktop PC companion with competitive processing power.
  • Ample Storage to Hold Files and Games: After hearing of 32GB RAM, you must have taken a sigh of relief. Meanwhile, 3TB of extra storage is also present to provide no breaks in a gamer’s smooth gaming sessions.
  • Huge Ports: Using headphones jacks to USB ports, users can have an unhindered game evening. There is no room to complain about fewer ports.
  • Beautiful Display Design: This desktop PC has a terrific epic design that pleases the viewer with just one look. The black-silver combination with the lighting and an irregular hexagonal structure provides a stunning look too.
  • No Thermal Issues or Fan Noise: Least fan noise makes this desktop PC the most desirable gaming peripheral. The fluidity in its cooling system due to effective panel construction gives an efficient airflow.
Customer Reviews
It is essential to have a close look at customers’ experiences with the performance of technical products. Here are some authentic customer reviews of Alienware Area-51 Threadripper Edition on-ground performance.
  • “I’ve found that it fills my computing needs, and with the 6800 mobos and GTX 1080 (not the Ti), the video streaming (youtube, Netflix, HBO Go, etc.) is great. Would likely have to upgrade to 1080 ti (maybe two), 6950 mobos, & get an SSD to really game, but it can be done with this rig. Also, like the DVD/CD RW drive for older apps, movies, music, etc. I have been sitting around. I would recommend this to a friend.” ~ Willy
  • “Great for gaming, and it still has room for upgrades. Sure, you can build a replica for much cheaper, but it won’t be the original….” ~ Jgon.
  • “For the money, they should’ve included an SSD to make startup and loading seamless. Overall is good, but my iMac boots up quicker if I had to compare.” ~ Bestbuyjoe
  • “Speed of processing exceeds expectations. Awesome thermal cooling and port capability, best to buy among various Alienware desktop PC. It is one of the best choices also due to its epic display design, which is perfectly cool.” ~ Loek
After reading the customer’s reviews on multi-tasker desktop PC, take a final look at our end verdict on the performance of Alienware Area-51 to know if it’s a worthwhile tech piece to spend on.
Get Assist Verdict: Is Alienware Area-51 Threadripper Edition Worth Buy?
Alienware Area-51 is specifically for multi-tasking people who can afford a hefty amount of $6000 for handling their official work with gaming together. There are the least complaints reported for this desktop PC because of its applaudable smooth extensive game handling skills. Although the paired graphics of Nvidia brings an appreciable 1080p resolution performance, it will not withstand the need for 4k games demands.
Users might also face fixing the hexagonal structure of it as it demands huge space for better stability.
FAQs
Ans: Alienware Area-51 Threadripper is a desktop PC known for awesome graphic processing. It is known as an ideal machine for gamers with the best design, numerous ports, best thermal support, storage capabilities, and praise-worthy heavy processing.
Ans: The price ranges from $2199 to $6000 in the market due to its premium design and gaming capabilities.
Ans: Dell Alienware desktop PC is expensive due to its high-quality processing power, epic design, numerous ports, and, most importantly, the two Nvidia 1080p graphic cards.
Ans: No, the i9 outperforms even the Threadripper’s high-quality performance. It is much faster, cooler, efficient, and determined for the best gaming results.
Also, Read:
11 top-notch gaming laptops for Sims-4 of all time
The best 10 VR-ready laptops: Capable to handle virtual reality headsets 2023
Sources:
Joel Santo Domingo, Alienware Area-51 Threadripper Edition Review, PCmag, November 2, 2017,
Lori Grunin, Alienware bets on Threadripper but offers Core i9 X, too, CNET, June 12, 2017
