• How Do LED Grow Lights Work?
    | Updated on September 17, 2021
    LED grow lights are a must-have for every indoor gardener. It is not only economic but also helps you to produce better plants. To get the best results, you must use the highest yielding LED grow light
    In comparison to traditional lighting options, LED grow lights make a better choice. Studies have shown that a full spectrum LED light resembles sunlight and thus, helps plants to grow stronger and healthier.
    Before you start with your indoor gardening, you must know how a LED grow light works. This will help you to make the most of your LED lights.
    LED Grow Lights: How Do They Work?
    Light Emitting Diode (LED) is a small electronic component that is constructed of two types of semiconductors. This includes holes that have a positive charge and electrons, the ones with a negative charge.
    When an LED is supplied with the proper voltage, it causes the electric current to flow which then makes the holes and electrons collide. The collision between the two elements generates energy in the form of light quanta, photons. This process is called recombination.
    Older LED lights had a limited selection of colors and low light output. However, things have changed today as modern LEDs are available in a variety of colors in visible ultraviolet and infrared spectral ranges. Not just that, but they are also much brighter than their older counterparts.
    Why You Should Use LED Grow Lights for Indoor Plants?
    Of course, natural sunlight is important for the growth of plants. But when you are into indoor gardening, you cannot get sufficient natural light for your plants. This is where the need for LED grow lights come into the picture.
    Compared to other lights, LED grow lights are far more effective. They can help you grow your plants better. The best thing about these lights is that they can imitate the natural sunlight better than any other type of grow light. It provides the required nutrients to your plants that other lights cannot. This is why LED grow lights are so popular among growers.
    You can use LED grow lights for all types of indoor plants. To get the best results, you must use full-spectrum LED lights as they help plants to photosynthesize. Out of all the colors in the spectrum, the blue and red color matters the most. Just so you know the blue part of the spectrum promotes leaf growth, while the red part helps in growing fruit and flower.
    With proper care and LED lights, you can grow your indoor plants healthily. Not just that, but you can also make them last a long time.
    LED grow lights emit the full spectrum of light that is required by indoor plants. Getting the best LED light for your plants can help them grow healthy and strong. Not to mention, it will also give you a better yield. But you need to make sure that you install the LED light at a proper distance from the plant.
    Author:
