How to Track Packages Using GS1 QR Codes
| Updated on June 18, 2026
Most of the travel packages have to follow those rigid processes in which they travel various places before reaching at their set destination, including warehouses. For the last many years, traditional tracking system were helping, but for the modern needs, they have become insufficient.
This is where the modern GS1 QR comes into play. It allows one to transfer information through a code. As a result, more data and shares and with fewer distractions and a smooth channel.
Read more to learn how to track packages using GS1 QR codes.
  • GS1 QR can store much more information than traditional barcodes.
  • A single code of GS1 QR can include product, batch, serial and other delivery-related data.
  • A properly chosen GS1 QR code can uplift the smooth working of warehouse operations to final delivery
What Makes a GS1 QR Code Different for Tracking Purposes
A little square barcode on a box often displays only a shipment ID pointing to a delivery company’s page. True – yet the scanner must pull extra details from another source each time, while relying fully on that provider’s platform staying online and properly connected.
A barcode using GS1 standards holds extra details right inside it, structured through their unique tagging method. Inside one such square-shaped code on a box might sit the GTIN – this tells you exactly which item it marks.
It could also carry a batch ID, showing when and where it was made during manufacturing. Each individual piece gets its own identity too, thanks to a built-in serial tag. When dates matter, like shelf life, that expiry moment appears encoded as well. Even the outer wrapper or stack on a pallet finds definition through another linked identifier.
Because this data follows a globally acclaimed standard, any GS1-compliant scanning system anywhere in the supply chain can read it correctly without being asked to query an external database for basic identification. That makes the tracking more resilient and faster, since the core information travels with the package rather than rely entirely on connectivity to a central system.
The GS1 Digital Link standard pushes this further by encoding a structured web address within the QR code. When scanned, this code can connect to a digital record that alters in real time as the package moves through the supply chain.
Here is how this works in reality. A package is marked with a GS1 Digital Link QR code at the point of origin. As the package moves through each stage, scanning the code does two things. It reads the inserted product and shipment data directly from the code, and it can also access or update a digital record tied to that specific package’s identifier.
For the business that controls the shipment, this means visibility into exactly where a package is and what its status is at any point, without having to manually query a separate tracking system for each item. For the recipient, scanning the same code can provide tracking status, delivery figures, and handling instructions, all from a single code on the package.
The dynamic nature of GS1 Digital Link codes means the digital content behind the code can be adjusted as the package moves, without the physical code on the package ever needing to change. The code printed at origin remains valid and active throughout the entire journey.
Setting Up Package Tracking With GS1 QR Codes
Setting up might be difficult for many. Here are the clear steps to go smooth:
Step 1: Obtain your GS1 identifiers. This starts with a GS1 Company Prefix from your regional GS1 member organization, which allows you to provide GTINs for your products and unique identifiers for shipping containers, often referred to as SSCCs, or Serial Shipping Container Codes.
Step 2: Determine what data needs to be on each package. For most logistics applications, this signifies the GTIN of the product, the batch or lot number, the SSCC for the specific package or pallet, and any relevant dates such as production or expiration dates. The exact combination depends on your industry and any regulatory rules that apply.
Step 3: Choose a generation platform that supports GS1 Digital Link. This is the most important technical issue in the process. A platform that correctly applies Application Identifiers and supports the Digital Link standard. This ensures your codes will be digestible by GS1-compliant systems throughout the supply chain, and that the codes can connect to real-time tracking data if you develop that capability.
The gs1 qr code generator from digital-link-qr-code.com is built specifically for this use. It guides users through the correct GS1 data structure, ensuring that GTINs, batch numbers, SSCCs, and other identifiers are encoded correctly according to the guidelines.
The platform’s support for GS1 Digital Link means codes can be designed to connect to digital tracking records that update as packages move through the supply chain, with the destination behind each code updatable without the desire to reprint labels.
Step 4: Validate your codes before production. Before signing up to a full label print run, validate that your codes meet GS1 standards and scan correctly across the scanning equipment used by your logistics partners. This step flags structural issues before they become problems at a receiving dock hundreds or thousands of miles away.
Step 5: Print and apply labels at the point of origin. Once tested, labels are printed and applied to packages, pallets, or containers as they are prepared for shipment. The codes are now ready to be scanned at every new checkpoint.
Step 6: Ensure scanning infrastructure at each checkpoint can read GS1 QR codes. This may require updating scanning hardware or software at warehouses, distribution centers, and delivery points if they are not already designed for 2D code reading. Many modern scanners handle this natively, but it is worth verifying with each partner in the chain.
Step 7: Connect scan events to your tracking system. As packages are scanned at each checkpoint, those scan events should feed into a tracking system that updates the digital record that goes with each package. This is what creates real-time visibility for both internal operations and, if desired, for the end recipient.
Practical Benefits of GS1 QR Code Package Tracking
The benefits of this plan show up at multiple points in the supply chain.
At the point of receiving, a single scan collects the product identity, batch information, and shipment details simultaneously, destroying the manual cross-referencing that traditional barcodes often require for anything beyond basic identification.
During transit, real-time visibility through Digital Link connections means businesses can notice delays, misroutes, or issues earlier than they would with traditional tracking that only updates at major control points.
For recall management, batch and serial number data stored directly in the package code means that if a quality issue is identified, the affected units can be observed precisely without ambiguity about which production run or shipment they belong to.
For the end recipient, a single scan can contain tracking status, product information, and handling instructions, reducing the need for distinct communications or tracking number lookups.
Common Pitfalls to Avoid
A few mistakes come up repeatedly in GS1 QR code package tracking implementations, and avoiding them upfront saves serious trouble.
Using a generic QR code generator that does not carefully structure GS1 data is the most common issue. The code might look correct and even scan cleanly in a basic sense, but if the Application Identifiers are not carried out correctly, GS1-compliant systems next door will not interpret the data as it was designed. This is why having a generator built specifically for GS1 Digital Link compliance matters from the very start.
Not validating codes before a full print run is another frequent issue. A structural problem that is invisible on screen can cause failures at scale once thousands of labels are printed and applied to shipments already in motion.
Assuming all partners in the supply chain can read 2D codes without being verified is a planning gap that surfaces at the worst practical time. Typically when a shipment shows up somewhere and cannot be addressed because the receiving scanner only supports traditional barcodes.
Not connecting scan events to an actual tracking system means the package itself features rich data, but no one is gathering or using it. The code is only as important as the infrastructure that reads and records what it carries.
Looking Ahead
As the supply chains are getting more complex and the systems demand more precise location tracking to ensure safe and smooth operations. Using GS1 QR has become necessary. They are the only technology to satisfy accurate tracking demands with a defined way to share information.
GS1 QR codes make this possible. With the merging of a details product information through smart technology and a stronger base for tracking, it serves most of the modern businesses that deal with packages.
What is a GS1 QR code?
It is a standard way to a 2D barcode that shares much of the information using GS1 application features.
How does it differ from traditional ones?
Traditional one holds a single identifier, but GS1 QR can store multiple chunks of information straight in its code.
Do businesses need modern scanners to scan these codes?
No, most of the modern barcode scanners by default support 2D code reading. In some cases, it might be required.
Scanning and tracking packages on the go is easiest with a reliable smartphone. Find the latest models and best prices at Priceka.
