7 Tips to Protect Your Plastic Water Tank from Damage
| Updated on March 27, 2024
Water tank
We can’t overlook the fundamental requirement of having a water tank, either for your workplace or home. There are plastic tanks around which are manufactured out of materials like polyethylene or polypropylene, molded to give desired shapes or sizes.
You can install them anywhere in your home without damaging them. However, you need to note that these tanks are not at all indestructible because they might get damaged by pests or external factors if you leave them for a long time.
So, if you want to protect Plastic Water Tanks for Trucks -TTi Water Trucks from being damaged, here are some of the ways that can help you to save them.
Also Read
Store Your Tank Away from Pests
You should definitely implement this approach, especially if you reside in an area with lots of pests around you. The best practice which you can follow is to keep all the containers inside your house during the nighttime.
Else, you can also try to curate a wooden crate or any other suitable container for storing those plastic tanks a night. This will prevent it from attracting pests and or any other form of wildlife during the daytime.
Another important thing is cleaning it regularly, which is helpful for keeping your plastic water tanks in the right state. Do you know the deposition of debris or dirt inside the tank is the most significant reason that might lead to rust or corrosion of your water tanks over time? Hence, you should undoubtedly follow up by practicing cleaning your tanks to avoid being damaged by any bacteria or mold.
Don’t Overfill Your Water Tank
You might know that there are so many plastic tanks that have built-in float switches that open when the water level rises. However, if it happens in any circumstances, you must make a habit of emptying the tank properly and then refilling it.
For instance, if you really want your water tank should stay with you for more than 3 years, it is essential to ensure that it has a secure system for plumbing. For this purpose, you can look for an experienced plumber who is equipped with the knowledge of how the plumbing system gets integrated.
Get Your Tanks Regularly Checked
You cannot overlook the significance of regular tank inspections in order to maintain them. These are built to last, even if they are kept in extreme environments that witness extreme shifts in temperature, lots of wear and tear, large gusts of wind, and much more.
If the corrosion, or damages are not spotted at the right time, it will ultimately lead to severe damage to the tanks. That’s why when the problems are spotted at early stages, they can be fixed, ensuring the longevity of the tanks and also preventing the expensive fixes that might need to be done to your water tanks.
Maintaining Coating of the Tank
Coat your tanks
Do you know what is the primary defense of your water tanks against corrosion? Well, it is their coating and that’s why it is very crucial to maintain it properly. If your tank has a proper coating, it will help them to save their inner metal lining from erosion. This also saves you bucks that might be required to put in for fixing the tank.
One thing that you can practice for this is getting at least the top layer of coating done yearly. Obviously, there is no need to get it done from scratch. For instance, if you are thinking of outsourcing a professional to get it done, make sure to check the documents and convey your requirements and preferences.
Try to get the detailed and specific contract details about your needs so that anyone who will reach out to you. After that, they will be able to evaluate the atmospheric conditions, and after the assessment in case the conditions seem unfavorable, they won’t suggest you begin the work and wait until the atmospheric conditions become favorable.
Keep Your Plastic Water Tank Clean and Dry
clean and dry tanks
For instance, there is so much dirt and sediment inside your tank, that your tank may get clogged up and drainage of values will make it damaged prematurely. So, whenever you finish the procedure clean the water tank thoroughly with soap and water also try to ensure that you clean it with hot water as well.
It will remove any of the residue present in the tank. However, if you don’t have soap available for you, go for using a mild dishwashing detergent instead of using any abrasive materials such as sandpaper or steel wool.
Make sure to Eliminate Algae at Regular Intervals
Remove algae
It might sound like a tough task and doesn’t occur with all the water tanks but, in case it does, you should remove it. Also, you can choose to use an opaque water storage tank for this purpose. As, you might know algae requires sunlight to perform photosynthesis, therefore, if you pick to use an opaque one there is almost negligible scope of facing such issues.
Tip:- You can use ¼ tablespoon of bleach with one gallon of water, but, make sure this process should be followed only with those tanks that permit implementing this. Otherwise, you can decide to use 4 parts of chlorine to 1 million parts of water. Always remember, NEVER use chlorine and bleach together.
Well, using this method both the water and the tank will be saved!
Wrapping Up
These are the effective tips that you can decide to implement to protect your plastic tanks from external damage. For instance, if you wish to choose to use bleach or even chlorine, you can make sure you don’t compromise the quality of water so that it remains safe for drinking and irrigation.
Besides this, what else you can do to ensure the optimum safety of the water at your water tanks is to collaborate with your local coordinator. This will help you to ensure in what amount you need to use either chlorine or bleach, and also get the water quality assessed from time to time.
Hope, you find this helpful in protecting your water tanks!
