Streaming is one of the coolest features that content creators all over the world use to reach out to their audience and share their talents and creativity. Businesses and people who are not necessarily content creators also use streams to pass important information or just have fun. A good smartphone, computer with a camera, and internet connection are must-haves for streaming. But is that all you need to perform an outstanding stream?
Today, you can find several ideas and tips that you can use to improve your live communication with the audience on the internet. But let’s face it, there is so much information out there that it may feel difficult to differentiate between truly helpful and useless streaming tips. Thus, in this article, we have compiled the best streaming tips every content creator needs to hear about.
10 Tips to Perform an Outstanding Stream:
Make a Simple Setup and Have Backup Equipment
One common stream mistake you need to avoid is using too much equipment in your setup, this may complicate everything because if one piece of added equipment fails, it may jeopardize the entire stream. Therefore always keep a simple setup to lower the odds of errors.
Again, even with your simple setup, remember that your equipment may still fail. Even though some tools and equipment are designed to be reliable, some smaller components like monitors and cables within your setup may put at risk your entire stream. It is always advisable to have backups whenever possible.
Make Sure You Have Bandwidth Availability and Extra Time for Audio
While streaming on a platform like Talkytimes, which content creators may use to showcase their talents to the world and reach out to paying users, send them online, or real gifts, you need to ensure that your network is working properly. You can do this by testing upload speed. Your stream simply needs to be viewable by your audience.
Sometimes streams do not get all the attention that they deserve because of bad audio quality. Audio setup needs to function properly for you to deliver information clearly. Also, try to minimize the noise around the room, test acoustics, and ensure to configure your audio encoding settings.
Thank Newcomers on Your Stream
Viewers on streaming platforms such as Talkytimes are your bread and butter as a content creator. Therefore, you should always thank them. Even the smallest contribution can add value to your stream and help push your content to more people, so ensure your audience knows that you appreciate them. Thanking your viewers may be difficult if you are focusing on a game or other type of mind-engaging content. But this should not be an excuse for not making personal mentions during your stream. Find a gap between your stream where you can shift your attention to appreciate your viewers.
Get Better with Your Content Creation
Do you struggle to generate topics and expound on them during streams? This can be very frustrating but there is nothing to worry about, Rome wasn’t built in a day. The same applies to ideas and content, they just have a way of getting better with time. As you interact with your audience, you will become well versed with your niche and resonate perfectly with your audience.
After setting up your equipment and everything looking rock solid, It is time to go live! Below are streaming tips that you can use to make your stream as professional as possible.
Use an External Display to Monitor Your Stream and Always Look at the Camera
To stream like a pro, confidence monitoring is important. Add an extra display on your stream so you can see your live show from the audience’s perspective. You can do this using a streaming device like Webcaster. An extra display will help you see the comments, and, likes and even know who has gifted or donated while engaging with your audience, that is if you are on a platform like Talkytimes.
According to Streamyard another mistake you can make while streaming is not looking at the camera. You need to frequently look your audience in the eyes, this will help with engagement. You can do this by looking at the camera and not yourself on the monitor. Many streamers make the mistake of staring at the monitor for long. It can be tempting but resist the urge of staring at the monitor longer than needed. You can still place the monitor below the camera for confidence monitoring purposes and quick access to the screen, but don’t stare for too long or too often.
Take All the Time You Need to Prepare for the Show and Respond to Comments
Preparing for a professional stream can take much more time and effort than you think. You need to be well organized and prepared. Being ready mentally is also important if you want to deliver a high-quality stream to your audience. Allow yourself more time to prepare before the stream to reduce stress and give the best possible show!
To boost engagement, you need to interact with your viewers. You can do this by responding to or liking their live comments. For better engagement ensure you are responding to the comments quickly. This will keep them coming back to your stream because replying to comments also shows that you recognize their presence and value their opinion.
Start Right Away and Let Someone Else Monitor Your Stream
In the past, some streamers on platforms like Talkytimes used to let placeholder images roll to give themselves more time to prepare for the stream. For example, they will overlay a text with the words “The stream will start soon, stay tuned”. However, this method is not ideal for live video. Therefore, it is advisable to have everything set up and start the stream right away.
You also need to have someone monitor your stream if it’s possible. Talkytimes, for example, is a platform where content creators can get followers and create a community while organically promoting their profiles to be interesting to followers. Therefore, as a content creator you will need to avoid multitasking while streaming and focus on showcasing your talent. Monitoring the stream while performing may be impossible. That is why you need an extra set of eyes on your stream. The other person will provide you with the support you need to fix any technical problems and ensure that video and audio quality is always fine.
Give the Audience Incentives So They Can Come Back
The whole point of making an outstanding stream is to appeal to your audience and have them come back again the next time you are streaming. So what can you do to motivate your audience to always return?
On a platform like Talkytimes, your audience is willing to donate or send you gifts to show support. This only happens if what you are offering is beneficial for them. Streaming is a bit different from the traditional methods of content creation, which is why you need to incentivize your viewers. One of the best ways you can do this is through giveaways and useful content. Just ensure you understand the rules of the platforms you are using as some may not allow giveaways on the platform or in the region of your stream.
Great ideas for giveaways are gift cards, you can contact your audience for details so you can send giveaways. You can appreciate and personalize your follower’s experience by mentioning your top viewers by their names and even reading their comments. This will encourage them to always come back to engage with you and other participants of the stream.
Choose Popular Stream Topics
Don’t be a boring content creator! That will make your audience equally bored. To make your stream lively, research currently trending topics. It doesn’t matter if the trend event is not associated with your field. You can always find a way to incorporate it into your stream. For instance, as the war between Russia and Ukraine continues, you can wear T-shirts with logos or graphics showing support for Ukraine or promoting peace. You can also talk about the issue briefly so your audience can help too.
If you are a blogger or a poet, when choosing topics to write about, you’ll want to opt for current and popular topics, so you can attract more attention. Trending blog titles for instance are more likely to catch the attention of your viewers and help new ones discover your channel.
Check the best blogging sites and search engines to find out about the current news and use the ones that are attractive to the audience. You can also check content from other content creators on Talkytimes and look for the trending ones. You shouldn’t copy what you find but simply borrow some ideas you can use to make your streams even more interesting. Avoid working with content that most people have seen or the one that already oversaturated the market.
Use more than one platform to stream and stay consistent
As mentioned already, you need to reach out to a larger audience, so don’t rely on one platform. Talkytimes may be the only platform that can help you grow as a content creator, but you can also live stream on Facebook and tell viewers about your account on Talkytimes. You need more viewers to grow, always remember that. Something worth noting down: multiple streams can put stress on your process and slow things down, but you can use a dedicated and powerful encoder to stream with very little effort.
Needless to say, you should go live regularly. If you are streaming twice a week, make sure you are consistent, otherwise, your audience will be frustrated and eventually stop joining your streams. Create a consistent streaming schedule and set reminders, this will also help you to promote your show.
Be Confident with Your Streaming!
Now, when you’ve learned 10 tips to perform outstanding streams, you can use them to create a high-quality stream or nail down setup activities. Today, live streaming is very important for creators and businesses. However, due to its popularity, the competition has become stiff in the market. These 10 tips can also help you improve your streams and stand out in a crowd.
The important stages in the live streaming process need you to have a positive mindset and confidence. You need to set your goals and plan things out. While streaming, consider speaking with your audience and be more in control of the space around you. After the stream, ensure you promote it on other social media platforms to increase your audience reach.
Here is a quick question for you! Are you a content creator looking for a platform that will help you create and promote your ideas?
If your answer is yes, then Takytimes is worth trying a platform that believes modern creators deserve a chance to promote their talent and get funded right away. Not so many platforms can do that. If you are just starting out, then you don’t have to worry about being looked down upon, the platform will help you reach out to an audience regardless of your level of creativity. You can take an opportunity to gain confidence with time and nurture your talent.
And here is the best part: there are users on Talkytimes that can pay for your content, as we already mentioned.
So how do you join and get monetized on Talkytimes?
To prevent scams and fake profiles, the platform will initially guide you through a verification process. The next step is filling in the profile — do it thoroughly, mentioning your niche, to attract a bigger audience right away. Now it’s time to organically promote your profile with posts, pictures, and streams to be interesting to the followers. With a community of followers, you can get online and real gifts and donations during streams.
Join Talkytimes and get monetized for your passion now!
