How to Avoid IP Blocks and CAPTCHAs During Large-Scale Web Scraping
| Updated on October 31, 2026
For businesses, web scraping has become a great way to gather useful information online. without needing to check page after page by hand.
But in the process of collecting from such a large pool of data, IP blocks and CAPTCHAs are normal ot find.
Teams planning to buy residential proxies can reduce some of these problems in many ways; spread the blog to learn what they are.
Why Websites Block Automated Data Collection
To detect suspicious traffic and to protect their servers, websites use security systems. However, when they send too many requests from one IP address, legitimate scraping tools can trigger these protections. For example, an online store may temporarily restrict access if a scraper visits dozens of product pages within seconds. During large-scale collection, the risk increases, especially when multiple requests come from the same connection.
CAPTCHAs are another common obstacle. To confirm they are human, these security checks ask visitors to complete a simple task. For automated tools, they can interrupt data collection and leave gaps in the results. Several factors can increase the likelihood of restrictions:
  • sending requests too frequently;
  • repeatedly visiting pages from one IP address;
  • using IP addresses associated with suspicious traffic;
  • ignoring temporary access restrictions.
A CAPTCHA does not always indicate a permanent block. However, repeated challenges suggest that the scraping process needs adjustment.
Practical Ways to Reduce IP Blocks and CAPTCHAs
A reliable scraping process combines suitable network infrastructure with reasonable request limits and careful error handling. Avoiding interruptions requires more than changing an IP address occasionally.
Use Residential Proxies for Distributed Requests
Residential proxies route internet traffic through IP addresses assigned to residential connections. The destination website sees the proxy’s address rather than the original connection. These addresses differ from those associated with traditional data centers. They can be useful for collecting publicly accessible information across different geographic markets.
For instance, an international retailer may need to compare product listings shown to visitors in several countries. Residential connections help researchers view location-specific pages without physically visiting each market.
Several important capabilities should be provided by a suitable proxy service:
  • a sufficiently large pool of residential IP addresses;
  • for countries and relevant cities geographic targeting ;
  • flexible IP rotation settings;
  • for longer browsing sessions, stable connections;
  • straightforward management tools and clear traffic limits.
A large pool offers limited value if connections fail frequently or geographic targeting is inaccurate. The quality of these features matters more than the number of available addresses alone.
Choose the Right IP Rotation Method
IP rotation means changing the address used to connect to a website. The appropriate method depends on the scraping activity. Some proxy services support automatic changes at regular intervals, while others maintain the same connection for a specified period.
Rotating addresses between batches may help distribute traffic for independent product pages. Without relying on information from a previous visit, each page can be collected. Other activities require a consistent session. For example, a permitted multi-page browsing process might depend on cookies that connect several requests. Changing the IP address in the middle of that process can interrupt the session or trigger additional security checks.
The best approach is to select rotation settings according to the task. Frequent changes are not automatically better, particularly when a website expects consistent session information.
Control Request Frequency
Often one of the simplest ways to improve scraping reliability is sending requests more slowly. Many beginners assume that increasing speed will always produce more information. In practice, excessive traffic can cause restrictions that leave substantial gaps in the collected data. A modest number of requests is what starts a better process. According to the website’s responses and published limits, the collection rate can then be adjusted.
Useful practices include setting delays between visits, limiting simultaneous connections, and scheduling larger collections outside unnecessary peak periods. Scrapers should also avoid downloading the same information repeatedly. Saving previously collected results reduces traffic and makes subsequent updates more efficient.
Handle Errors Without Repeating Them Endlessly
Temporary errors are normal during automated collection. A connection might fail, a page may load slowly, or a website could temporarily restrict access. A well-designed scraper should recognize these situations rather than immediately repeating every failed request.
For example, an HTTP 429 response usually indicates that too many requests have been sent. Repeated access attempts after a clear restriction can make the situation worse. Persistent failures deserve investigation rather than an endless cycle of retries. The appropriate response is to slow down and respect any waiting period specified by the website.
Building a More Reliable Scraping Workflow
Large-scale projects benefit from a structured collection process that limits unnecessary traffic and identifies problems early. Even suitable proxies cannot compensate for poor planning.
Start With a Small Test
Potential problems before substantial resources are committed are revealed by testing a scraper on a limited number of pages. A practical setup process involves the following steps:
  1. Identify the required information. Decide which publicly accessible pages contain the necessary data and review their access conditions.
  2. Configure the connection. Use the appropriate locations. Set up the scraper and any authorized proxy connections.
  3. Run a limited collection.  With conservative request settings, test a small group of pages.
  4. Review the results. Check whether pages load correctly and whether the collected information is complete.
  5. Increase the workload gradually. Only when the website’s rules and observed responses support doing so, expand collection.
  6. Monitor interruptions in response times. Record failed requests, CAPTCHAs, and changes.
This process provides useful information about how the scraper behaves under realistic conditions. It also helps prevent teams from discovering major issues after collecting thousands of unusable records.
Monitor More Than Collection Speed
A scraper that downloads pages quickly is not necessarily performing well. Whether it consistently collects accurate, usable information is the important question.  In response times, teams should monitor successful requests, missing records, connection failures, and unusual changes. Whether problems originate from network connections or the target website. These measurements help identify problems.
It is also useful to track data freshness. For example, an e-commerce company may need updated competitor prices every day, while a market research project may require less frequent collection. Matching collection frequency to business needs can substantially reduce unnecessary requests.
Respect Website Access Rules
Reliable scraping also involves respecting the websites that provide the information. Before collecting data, review applicable terms, published access restrictions, and robots.txt guidance. Where official APIs are available, they may offer a more predictable method of obtaining information.
Without an appropriate legal basis, avoid collecting private information. Login requirements, explicit access denials, and other restrictions should not be treated as technical obstacles to defeat. These precautions support responsible data collection, and the likelihood of operational or legal problems is reduced.
Final Thoughts: Reliable Scraping Starts With Good Planning
When websites receive excessive automated traffic, large-scale web scraping becomes difficult. Residential proxies can help distribute authorized requests and support research across different regions. IP restrictions, CAPTCHAs, and temporary errors can interrupt collection and affect data quality. Sensible rotation settings, reasonable traffic levels, and the website’s access rules determine their effectiveness.
Choosing a reliable proxy provider is particularly important for projects that require consistent connections and accurate geographic coverage. Look for transparent pricing, clear IP sourcing policies, responsive technical support, and tools for monitoring connection quality.
Ultimately, successful web scraping is measured by the accuracy and consistency of the information collected. Careful testing, responsible request management, and dependable infrastructure create a stronger foundation for long-term data collection.
1- Why does my web scraper keep getting blocked?
Because its traffic does not look like a real browser on at least one of three axes: fingerprint, rate, or IP reputation. The request might come from a flagged data center IP, carry a thin or contradictory set of headers, or arrive faster and more regularly than a human could click.
2- What is an effective way to avoid blocked web scraping requests?
Rotating across a pool of good IPs, ideally residential ones for strict targets. The most common block is a per-IP rate limit, and spreading the same volume of requests across many addresses means no single one ever crosses the threshold.
3- What is the best way to bypass CAPTCHA?
The most reliable approach combines residential proxies, browser automation, realistic browser fingerprints, sticky sessions, cookie persistence, and conservative request pacing.
