Online Call Not Connecting? How to Fix This Issue
| Updated on September 18, 2025
online call
In today’s world, online calls have become an integral aspect of our daily routines, encompassing work, education, and social interactions. Unfortunately, these calls often encounter disruptions at the most inconvenient times, leaving individuals in a state of frustration as they attempt to refresh their browsers or troubleshoot their devices.
Fortunately, the majority of online video call issues can be resolved with straightforward solutions. By familiarizing yourself with the common underlying causes of these challenges, you can efficiently address them and minimize downtime when you need to stay engaged or productive.
Often, the source of the problem is something as simple as a weak internet connection or outdated software, both of which can typically be remedied with a few easy steps. However, if you have already attempted the basic fixes and the issue continues, there may be more complex settings that require your attention.
That’s why this blog post aims to provide some comprehensive measures that will benefit readers in solving issues on multiple platforms
  • Understanding the value of a status check
  • Decoding app and account fixing solutions
  • Discovering the necessary steps to take while troubleshooting the device and network issues
  • Looking at some last-resort steps and platform trouble fixes
Start With A Status Check
Take a moment to breathe and chill out while you figure things out. Before you start freaking out and messing with your settings, let’s tackle the two easiest things first:
  • Give your internet connection a quick check. Just open any random website in your browser. If it doesn’t load, then your internet might be the problem.
  • Check if the platform is down. Services like Zoom, Microsoft Teams, or Google Meet occasionally have outages. Visit an is it down status page to see if others are reporting problems.
If the platform is having issues, there’s nothing to fix on your side. You’ll just need to wait it out until developers address the issue. Platform outages can last anywhere from a few minutes to several hours, so it’s best to be patient and avoid repeatedly refreshing your browser during this time.
Many Businesses use Contact Center as a Service (CCaaS) solutions to consolidate customer interactions from various channels into a single view for agents.
App and Account Fixes
If the platform is running fine, the next step is to check your app and account settings. Often, issues stem from configuration errors or overlooked settings that can disrupt functionality.
  • Take a moment to review these things; they might be the reason for your troubles.
  • First off, make sure you’re logged in. Then, double-check that you’re using the right account. If you need to use your work or school login, don’t accidentally use your personal account.
  • Next, verify your login details. A simple typo in your email or password could be blocking your access.
  • Don’t forget to update your app or browser. Sometimes, using an outdated version of the platform can lead to crashes or connection hiccups.
  • Clear your cache. In your app or browser settings, clear cached files and cookies to remove corrupted data.
  • Review permissions. Ensure your microphone and camera have the necessary app permissions and that notifications are enabled. Without them, you may join but remain invisible or silent.
  • Sign out and back in. This step is the account version of “turn it off and turn it back on again.” A simple reset often clears minor glitches.
Intriguing Insights
biggest virtual meeting challenges
This infographic shows the biggest virtual meeting challenges
Network Issues
Just because you’re online doesn’t mean everything’s smooth sailing. Sometimes, network hiccups can mess with your video call. If your account, browser, and app settings look good, it might be time to dig into some network troubleshooting (like checking if your internet speed is lagging or if there are bandwidth issues).
  • Try switching connections. Test both Wi-Fi and mobile data to see if one works better.
  • Restart your router or modem. Restarting your modem can fix more than just the inability to connect to your network. It can also resolve other hidden network issues.
  • Turn off your VPN. In rare cases, your VPN can interfere with call connections. Turn it off temporarily to see if performance improves.
Device Troubleshooting
Your device might be causing some of those pesky connection problems. Things like old hardware, software that doesn’t play nice together, or just a few misconfigurations can mess with your ability to connect smoothly.
  • Give your device a quick restart. You know, the classic “turn it off and on again” trick. It surprisingly works more often than you’d think!
  • Install OS updates. Out-of-date operating systems may leave your device vulnerable or lacking compatibility with certain platforms.
  • Close background apps. Streaming or gaming apps running simultaneously can destroy bandwidth and CPU processing power.
If using the web version of Zoom, Teams, or Meet, make sure your ad blockers are turned off.
Last-Resort Steps
If you’ve reached this point and nothing works, you can still try a few fixes. These steps are more advanced and should help address any lingering issues that may not have been resolved by the basic troubleshooting methods.
If all else fails, you might want to give these a shot:
  • Uninstall and reinstall the app. It might take a bit of time, but it’s worth a try if nothing else works.
  • Check out the web version. If the app is acting up, just hop onto your browser and log in there.
  • Try a different browser. If Chrome isn’t cutting it, give Edge, Firefox, or Safari a go.
  •  Clear your cache and cookies. Sometimes, those little bits of data can get messed up and cause issues; getting rid of them might just do the trick.
Platform-Specific Fixes
Here are some platform specific fixes:
Zoom Users
  • Install the Zoom app if joining through the browser fails
  • Enter the meeting details manually (log into the app, select Join, and manually enter the meeting ID and passcode).
  • Make sure the meeting ID is spot on
  • Double-check that your time zone settings line up with the meeting.
  • Search for any error codes on Zoom Support or in community forums.
Google Meet Users
  • Is your browser compatible and up-to-date? If not, try updating your browser. To update Chrome, open Settings > About Chrome and relaunch if updates are available.
  • Make sure you’re logged into the right Google account (your work one, not your personal one).
  • See if the meeting is at capacity or has any restrictions.
  • Double-check the time zone.
Microsoft Teams Users
  • Clear cached files:
    • Windows: Quit Teams. Open the Windows dialogue box with Windows + R on the keyboard. Copy and paste [ %appdata%MicrosoftTeams ]. Restart Teams.
    • Mac: Quit Teams. Open the Terminal. Copy and paste the command [ rm -r ~/Library/Application Support/Microsoft/Teams ]. Restart Teams.
  • Uninstall and reinstall Teams if needed.
Digital Efficiency
Tech troubles can be a real pain. Even minor connectivity hiccups can throw a wrench in your workflow or meetings. But hey, these moments are also a chance to get ready for next time and familiarize yourself with your gadgets, apps, and connection settings.
Keeping your apps up to date, having a backup plan, and making online tasks like logging in or rebooting your devices smoother is key. A little forward-thinking can make your digital life a lot less stressful. Thinking ahead helps keep your digital life stress-free. When the next “call not connecting” moment happens, you’ll already know exactly what to do to get back to your conversation as soon as possible.
Additionally, regularly testing your equipment and checking your settings before important calls can prevent many issues from arising in the first place. Simple actions like ensuring a stable internet connection or clearing your browser’s cache can make a world of difference. By staying proactive, you’ll be more prepared, more confident, and less likely to be thrown off track when tech hiccups occur.
How many phone calls happen every day?
While there is no precise, universally cited number for “phone calls made a day” because the data is vast and complex, some estimates suggest billions of calls are made globally.
What are the disadvantages of online meetings?
Disadvantages of online meetings include technical issues (like poor internet connections and software glitches), a lack of non-verbal communication, which can hinder relationship building.
What is another word for virtual meeting?
Synonyms for “virtual meeting” include online meeting, teleconference, video conference, remote meeting, web conference, and webinar.
