How to Create a Shortcut on Snapchat in 2026?
| Updated on October 27, 2026
How to Create a Shortcut on Snapchat Effective Method and its Impressive Benefits
Sending multiple snaps to each friend manually is very time-consuming; you have to scroll endlessly to determine who needs to see your personal life and who doesn’t.
Instead, to limit your social access and send countless snaps in a single tap, you can learn how to create a shortcut on Snapchat in simple steps, which are mentioned in this brief blog by GetAssist. Read till the end to understand some exclusive benefits of making shortcuts.
How to Create a Shortcut on Snapchat: Quickest Way
If you want to learn how to make a Snapchat shortcut for streaks or putting people in different groups based on your interaction activity or importance in your life, then this method can be very helpful. Follow these steps in the exact order to create precise groups without any loose ends.
  • Open the Snapchat app on your device and swipe right.
  • In the Chat menu, tap on New +.
    In the Chat menu, tap on New plus
  • Then select all the people you want in a shortcut.
  • Choose an emoji (it could be random or based on the category of selected users).
    Choose an emoji it could be random or based on the category of selected users
  • Now, after choosing an emoji, tap on Create Shortcut.
    Now after choosing an emoji tap on Create Shortcut
  • Now, come back to the Chat Menu
    Now come back to the Chat Menu
Benefits of Creating a Shortcut on Snapchat
Creating a shortcut on Snapchat comes with multiple benefits that can improve your social media management, segment different groups, and limit your interaction with unwanted people. For more detailed elaboration, read these pointers carefully:
  • You can pin the friends or groups who are constantly maintaining Snapstreaks with you instead of wasting your precious time scrolling all the way to the bottom whenever you want to send a snap.
  • The best part is you can create multiple shortcuts according to your preferences, like close friends, gaming buddies, or study groups. This way, you won’t send every snap to the entire friend list anymore.
  • To make each group more identifiable, you can add specific emojis according to their category, such as 🎮 for gaming, 📚 for school, or 💛(yellow heart) for your close friends.
  • Shortcut lists are directly placed at the top of your Chat screen or on the Send To screen for creating instant communication channels rather than being present in random locations.
Creating a shortcut on Snapchat is a quick and easy process. By creating a shortcut, you can instantly send snaps to a group of people you commonly communicate with by simply selecting their emoji. This eliminates the need to scroll through your contacts and speeds up sending snaps tremendously.
You can keep streaks alive or communicate with your inner circle effortlessly by utilizing this feature. It will save you time and put your contacts within seconds of sending them a snap. For more such intriguing and useful content pieces, make sure to stick with GetAssist.
How do you add people to a Snapchat shortcut?
To add more people to an existing Snapchat shortcut, you can update it directly from the “Send To” screen or the Chat tab. This way, you can connect and maintain a streak with new people.
How do I add myself to a Snapchat shortcut?
To add yourself to a Snapchat shortcut, you can include your own profile while creating a new shortcut.
How do I show myself in Quick Add on Snapchat?
To appear on Snapchat’s Quick Add (now also referred to as Find Friends), you need to enable the visibility setting in your privacy preferences.
Sources
Vera Olehi
Social Media Writer
