People have used stencils as part of their creative process for thousands of years. First-generation humans used stencil-art techniques when they coated cave walls with blooms of red or black pigment by blowing ground minerals over them with their hands. Their ghostly handprints can still be seen on cave walls today.
Stencil art techniques haven’t changed substantially in 30,000 years. The versatility of cutting a pattern or letter out of cardboard, plastic, or metal allows craftspeople to color cloth, design manuscripts, design, and print T-shirts, and add street art to city streets.
Let’s explore this rich history a bit more. You’ll learn about some stencil art principles, then guide yourself through creating your own stencil art.
Creating Stencil Art: A Beginner’s Guide.
It’s likely you’re eager to try stencil art for yourself after seeing the work of some stencil art legends. In addition, stencil art techniques are easy to learn and apply once you practice a little.
Stencil Art Design: Create a Stencil.
A working image is the first thing you’ll need. You can make stencil art from your own drawings, images or pre-existing artwork, or a combination of all three.
If you choose to use two-tone black and white, be sure that your print design is legible without too many details being lost. If you’re learning how to create stencil art, choose fonts, icons, bold illustrations, and dark photos.
The image can be inked manually or altered using a program such as Photoshop to make it both readable and appealing. It’s helpful to make your spray can art pop with strong shadows and crisp lines if you plan to make it for a wall.
Be aware that there are only so many details you can fit into your stencil. You will have trouble cutting many micron-sized lines (usually no smaller than a half-millimeter), and this will interfere with the paint’s ability to adhere to the wall.
Plan for any “bridges” necessary in the artwork as you create the stencil pattern. To avoid cutting away important design elements, be aware that there should not be any isolated areas of blank stencil material.
Textile printing is also done with stencils, as silk screening does. This method requires a one-color application at a time, so for silks with multi-colors, it must be several layers and each layer must be set aside to dry.
How Can Stencil Art be Used?
The image you want to be produced and the colors it has are both up to you when you use stencils. You are basically the designer of your project since you can make the stencil yourself. It is impossible to count the kinds and numbers of designs one can create with a stencil!
You just have to be creative and imaginative. It is easy to create your desired image if you have a little help, such as holding the stencil as you apply the color.
Your stencil art can be used in the bathroom, at home, or even at the office! No matter where it is placed, whether on a tabletop, on a window, or on a floor, stencil art will become an attractive addition to any flat surface.
