• [2023] How to Get 5G Network with 5G CPE
    | Updated on July 7, 2023
    Nowadays, 5G is the main development of the new generation of mobile communication technology and an important part of the future new generation of information infrastructure. With the demand for a 5G network, 5G CPE (Customer Premise Equipment) occurs, which can transmit the 5G signals from the 5G base station into WiFi signals or wired signals for the Internet connection of local devices.
    Part I. What are the Advantages of the 5G Network?
    Before we talk about advantages of the 5G network, it is important that you should also be aware of which smartphone is the best for 5G networking.
    1. Speed
    The theoretical speed of 5G can reach up to 20Gbps, which is much higher than 4G. Not only the surfing experience will be improved, but also other applications like VR can achieve
    2. Low Latency
    According to the test, the time required for a network device to respond to a command has been reduced strikingly (Normally less than 5ms). The application and service will work in the same way wherever the position is so the latency of real-time communication is dismissed.
    3. Capacity
    The 5G can connect to more devices than 4G. It’s said that 5G allows 1 million devices to connect to the Internet at the same time per square kilometer. You must have experienced that you can’t connect to the 4G network when you are located on public occasions such as on the subway or in the supermarket. 5G tackles this problem.
    Part II. How to Get 5G Network with 5G CPE
    Whether in the house or in remote areas, 5G CPE is the best device to help access the 5G network. The characteristics of 5G CPE are flexible and easy. 5G CPE can get into service where 5G signals are covered. Therefore, when you want to deploy the 5G network in your house, you can place a 5G CPE and all families can connect to the Internet. You also can use the 5G CPE router when going to remote regions or holding public events. Now we will show you how to access the 5G network with 5G CPE.
    The first thing we should do is to choose the right 5G CPE. V-SOL 5G CPE router is a representative of various brands. It has designed different CPE devices to meet the demands of different occasions and applications with high performance, which involves indoor, outdoor, and industrial CPE routers. Here we will take an example with V-SOL 5G indoor CPE.
    1. Features of V-SOL 5G Indoor CPE
    High Speed
    The CPE adopts Qualcomm SDX55, which promises a high speed. The upload and download speeds can separately reach up to 900Mbps and 1Gbps. It’s backward compatible with 4G networks and spectrums and the throughput is 10 times higher than 4G LTE. The innovative 5G super unlink merges TDD with FDD, which enables users to upload large files or videos rapidly. You also can enjoy 4k/8k Livestream and AR/VR without lag and slow speed.
    WiFi 6 and Multiple Devices Connections
    The device supports WiFi 6 (802.11ax), which provides higher Internet speed and larger AP capacity. 128 devices can connect to the wireless network at the same time.
    Smooth and Stable Network
    The quad-core arm processor ensures smooth and stable performance when there are multiple devices connections in the meanwhile. In addition, the latency time also is reduced a lot.
    2. Guide to getting a 5G network with V-SOL 5G indoor CPE
    Step 1: Prepare a valid nano-SIM card.
    SIM card
    Step 2: Open the slot cover at the bottom of the device and insert the nano-SIM card.
    Notes:
    • If you want to take out the SIM card, please lightly press the SIM card and it will pop out.
    • Make sure the CPE is turned off before you insert or remove the SIM card, or the CPE and SIM card may be damaged.
    Step 3: Connect the supplied power adapter to the CPE. Then the CPE router will be powered on and connect to the Internet automatically.
    Step 4: Connect your device to the Internet.
    Shown as in the image, there is a smart button, a LAN/WAN port, and the other LAN port.
    WAN port
    • Get Wireless 5G network: You can get the default SSID and password on the label at the bottom of the device and connect to the WiFi network with your mobile phone or other devices.
    • Get Wired 5G network: You can connect your computer or classic switch to the LAN port via Ethernet cable to access the Internet.
    Notes:
    • If you double press the button, the WiFi will scan again and select the channel with the lowest interference.
    • If you press for 3s, it will switch on/off the radio.
    • If you press for 10s, it means changing 5G into 4G. You can restore the 5G function by pressing the button for 10s again.
    Tips:
    You can adjust the CPE’s current position and direction to obtain a better radio signal. To determine whether the CPE is receiving a strong signal, please refer to the SIG LED indicator.
    Moreover, V-SOL provides a web management page to help you easily configure the CPE. You can adjust the settings of radio, WiFi, Ethernet, etc.
    device information
    Have you mastered how to get a 5G network with a 5G CPE? Just with several steps, you can enjoy a fast, stable, and smooth 5G network!
    Author:
