POS advantages and benefits are too many to resist for many business owners. This is especially when compared to traditional cash registers. If your business has been using the conventional method of sale, at some point, it would be much easier to incorporate a Point-of-Sale system. This is the time to upgrade.
The changes that come with the Harbortouch POS Systems are the checkout and a whole lot more. Put away that cash register and try a Point-of-Sale system to help grow your business better.
Greater Accuracy
Before you rush out and upgrade to a POS system, make sure you ask about it first. An ECR and credit card terminal has accessible programs to input information, but that doesn’t necessarily mean accuracy. With an ECR and credit card terminal, sometimes the people at the register aren’t counting money or scanning items, and this can lead to inaccurate sales totals.
With a POS system, you get software with built-in testing. To make sure your POS system is accurate, you can run it through real-world tests so you know for sure that the software is providing you with the right numbers. You don’t need to call your local accountant to track down your sales, and you can check the software and see if it reflects what happened at your store.
Easy to Use
As you know, many transactions are much simpler with a POS system. As a business owner, you’ve probably experienced this when you’ve tried to use a traditional cash register. It can be slow and cumbersome, and you have to keep a close eye on the sales price. With a POS system, you swipe your card and walk away.
You’re going to have your hands full without a POS system, but it’s also easy to use. This is a massive advantage for the average small business owner. You can scan or swipe credit and debit cards with little to no training, and you can also use pen-and-paper to keep track of inventory.
However, you have to enter your customer’s credit card and feed the information into a traditional cash register for the traditional method. Things are more manageable if you have a POS system, you can choose from a wide selection of digital credit and debit payment methods. This will also help your customers take advantage of fast payment options, as many businesses opt to take cards over cash.
Cost-Effective
Using a POS system will save you time and money. A single POS system can cost hundreds of dollars, whereas more advanced techniques can cost millions. However, as your business grows, you’ll find that you can invest in a more advanced POS system that will grow with you and take less of your time.
If you already have a POS terminal in your store, you’re probably aware of the fact that the information entered on these terminals is easily stolen. If your staff doesn’t have passwords for each card that they use, thieves can access sensitive information, such as credit card numbers. With a POS system, all you have to do is input credit card information once and then transfer it to a separate, encrypted device that’s hidden away in the backroom.
Customer-Friendly
Relying on cash for transactions can slow down your business. But with a POS system, your customers will have a more straightforward checkout experience than ever before. You’ll be able to track payments through your POS system, providing you with the details of who paid and how much was charged. It can be challenging to track what was purchased and where the money went with cash. A POS system will provide all of this information, making it easier to manage your transactions.
Depending on the type of POS system you opt for, your business can offer excellent customer service because you’ll be able to provide the correct information to your customers. With a POS system, you’ll give the customer the best possible service and make sure they make a purchase when you ask them to.
With a POS system, you’ll be able to run smoother and faster transactions. Without scanning each item individually, your customers will be able to pick up their items as soon as they walk up to the checkout line, which will prevent long lines. That can save your business a lot of time.
Detailed Receipts
Have you ever received a receipt for purchases made at the supermarket? It typically has no specific item numbers listed to reduce the amount of record keeping. The only way to tell if the receipt is correct is to check it against the register tape or receipt tray. That’s why a point of sale system provides you with so many options to customize the receipt. They’ll also come with database-based reports. In this way, the system can provide you with various information on sales and inventory.
Once you have an intuitive point of sale system setup, you’ll be able to track transactions more quickly than ever. That’s because you’ll have access to all of the reports and alerts you need without the time-consuming task of entering information manually.
Time-Saving
The best POS systems are designed to simplify your business and help you run it with greater efficiency. They help you track your customers’ spending, helping you reach your goals quickly and effectively.
Better Inventory Management
An ECR is great for tracking items in stock, but it can take a lot of time and effort to manage inventory. If you still use an ECR, consider using a POS system with added inventory management tools. This way, if you need to remove an item from the inventory system, you can do so quickly and easily.
Improved Security
Most businesses don’t look into their security measures until an incident happens and leaves them concerned about the severity of the situation. But whether you have a POS or not, your employees need to know about your security procedures. What if someone uses your mobile device to store a virus? Wouldn’t you want them to know about the precautions you take to avoid such a situation? Fraud is a massive problem in today’s world. If you don’t have a POS system, you’ll be wasting a great deal of money on potential disputes, lost sales, and customer anger.
A POS system is a great way to ensure your employees know your risk management policies and take care of such issues when they arise.
More Accurate Reporting
Even if you have the best cash register in the business, it may not be set up correctly. Many cash registers offer subpar reporting, but with a POS system, this won’t be the case.
Most point-of-sale systems now can send purchase and sale orders, store inventory, and make automatic change deposits in an electronic format. All of this information is processed automatically and pushed back to the point of sale at your business.
Stores that use point of sale systems can make sure they’re following all the laws for selling products to minors and making sure the sales transaction was correctly processed, which can make a massive difference in how your business is looked at from a legal standpoint.
Bonus: Better Employee Productivity
A POS system ensures your workers get their sales transactions out of the way as quickly as possible. Your employees don’t have to enter information by hand with a POS system. They can input all of their customer information through a simple touchscreen. Using a POS system for your employees means spending more time with customers and less time on the sales floor.
