How Airbrush Can Help Improve Low-Quality Photos and Videos
| Updated on September 17, 2026
This is not always the case with every image or video that you come across. For example, an unforgettable picture might have come out blurry, an outdated file might appear too small for current displays, or an effective video might become low-quality through repeated sharing and compression.
Using the help of AI, such problems can be addressed in order to edit the existing files rather than discarding them. Airbrush provides efficient solutions when it comes to dealing with the above-mentioned issues.
For authorized content, its tools can remove watermark from video and improve footage, while its AI image enhancer can help sharpen details, clean distractions, and make older images more suitable for modern uses.
Improve Photos That Look Blurry or Soft
Blur is among the most frequent image quality issues. It can happen because the camera moved, the subject was in motion, the focus was slightly off, or the original file was compressed.
A slightly blurry photo may still contain a valuable moment or important information. Instead of immediately deleting it, AI enhancement can be used to improve the picture’s visibility.
Airbrush AI Photo Enhancer analyzes the image and works to improve details, sharpness, and overall quality. It can be useful for portraits, product images, travel photographs, older pictures, and everyday smartphone photos that need some improvement before they are shared or reused.
The initial quality does matter.  AI can improve many images, but severely blurred or heavily damaged files may have less recoverable information.
Make Pixelated Images Clearer
Pixelation often becomes noticeable when a small image is enlarged beyond its original dimensions. It can also appear after repeated compression, cropping, screenshots, or downloads from online platforms.
It results in visible squares and makes the viewing of elements such as faces, text, lines, and surfaces difficult.
Airbrush Unpixelate Image can help reduce the appearance of pixelation and produce a cleaner version of the image. This is particularly useful when the original high-quality file is no longer available.
Old online photos, downloaded images, cropped pictures, and previously compressed files can all benefit when there is enough information in the source for AI to work with.
Increase the Resolution of Small Images
Sometimes an image looks reasonably clear but simply does not have enough resolution for its new purpose.
A photograph originally created for a small social media post, for example, may not look good when used in a larger website section, presentation, or print layout. Simply stretching the file makes the pixels larger without adding meaningful detail.
Airbrush Image Upscaler can increase image dimensions while working to retain important edges, textures, and visible details.
Upscaling can make older or smaller images more practical for modern displays, but users should still choose an appropriate output size rather than making every image unnecessarily large.
Clean Up Distracting Photo Elements
Image quality does not always refer to its resolution and sharpness.Sometimes the technical quality is perfectly acceptable, but the content inside the frame is the problem.
A travel photo might have strangers in the background. A product image may include packaging or props that are no longer needed. A property photo could contain temporary equipment, while a portrait might have distracting objects behind the subject.
Airbrush Object Remover provides a way to select these elements and clean up the affected areas. This can save an otherwise strong image from being abandoned because of one unwanted detail.
The best results usually come from making focused corrections rather than trying to change large portions of the original scene.
Improve Poorly Lit Photos
The lighting can play an important role in determining the quality of the picture.
Photos taken indoors may look too dark, while outdoor shots can contain strong shadows or uneven illumination. Smartphone cameras compensate for many lighting problems automatically, but difficult conditions can still produce images that lack balance.
Airbrush Image Relighter can be used to rectify the problem of lighting after taking the picture. Different lighting treatments can be applied depending on what suits the original photograph.
This can be helpful when reshooting is impossible, particularly for travel photos, events, older images, portraits, and other one-time moments.
Improve the Quality of Existing Videos
Low-quality video can result from older cameras, poor recording conditions, repeated compression, or files being shared across different platforms.
Soft texture and reduced clarity will become especially apparent when old videos are watched on modern high-definition screens.
Airbrush Video Enhancer can improve the visual quality of existing footage and make it more suitable for reuse. This can be useful for personal clips, marketing videos, product demonstrations, social content, and other footage that remains relevant even though its technical quality is no longer ideal.
Rather than recording everything again, enhancement gives users an opportunity to get more value from footage they already have.
Adapt Images for Different Sizes and Layouts
A good image can still be difficult to use if its composition does not match the required layout.
A wide photograph may work well on a website but not in a vertical social post. Cropping can solve the dimension problem, but it may also remove people, products, scenery, or other important parts of the image.
Airbrush Image Extender can produce visual space that surrounds an existing image. Thus, it will provide more options while preparing one and the same image for various sizes.
The expanded areas should always be checked before the final image is published, especially when the scene contains detailed objects, architecture, or recognizable surroundings.
Start With the Best Source File Available
There are lots of visual quality problems that AI can solve, but using the best source image first is still important.
Whenever possible, use the original photo or video rather than a version downloaded from social media or sent through an application that heavily compresses files. Each additional round of compression can remove information from the source.
Make sure your original images are backed up.  An original high-resolution photograph gives enhancement and editing tools much more information to work with than a small screenshot or repeatedly compressed copy.
Improve What You Already Have
Not all bad photos have to be deleted, and not all bad videos have to be re-filmed. Existing content can often remain useful if the specific problem affecting it can be corrected.
Airbrush brings together tools for enhancing photos, reducing pixelation, increasing resolution, removing unwanted objects, adjusting lighting, improving videos, removing video watermarks from authorized content, and modifying images depending on the size needed.
The key is to identify what is actually wrong with the visual before editing it. Instead of applying unnecessary changes, choose the tool that addresses the specific problem. This approach can help turn older, imperfect, or difficult-to-use photos and videos into content that is ready to be shared again.
Does Airbrush sharpen blurry photos?
Airbrush can help to sharpen blurry or fuzzy photos, but there is not much information to restore in heavily blurred photos.
Does Airbrush improve image resolution?
Yes, Airbrush Image Upscaler can enlarge your image and try to keep the edges and other important features of your photo.
Can Airbrush correct the bad lighting in pictures?
Yes, Airbrush Image Relighter can change the lighting and improve poorly lit pictures that are too dark, have bad lighting, or have shadowed parts.
Can Airbrush improve existing videos?
Yes, Airbrush Video Enhancer will be able to improve the visuals of existing videos, making old or compressed video material usable.
