Reviews » Gaming » Prodcut » Viotek GN27dw- A Gaming Monitor That You Always Want
Posted on March 12, 2020 | by Freddie George
Introduction
A pro gamer can’t be separated from their monitor, and there’s good reason for that. Using the right monitor while gaming will make it easier to navigate and initiate actions without straining your neck.
It’s no doubt that there’s a ton of options when a gaming monitor is what you seek, but the right choice is available with so much ease in this Viotek GN27dw Review.
Gamers tend to spend a lot of hours looking at their monitors. With a poor quality monitor, eye strain and poor visibility could cost you many games.
A lot of gamers think monitors get better as they get bigger, but a good number of gamers beg to differ. A curved monitor is the gold standard for lots of gamers, and there’s good reason as to why that is.
Specs
Before making a display monitor your ideal choice, it’s more advisable to get acquainted with all the features it has to offer.
When you’re fully aware of what this monitor can fully provide, your choice is surely more natural than expected. Here’s every spec you should know about this monitor, take a look;
  • Screen dimension: 27”
  • Overall unit dimension: 24.1” X 17.8” X 9.5”
  • Style: Curved monitor (1800R)
  • Xbox Sync monitor compatible
  • Resolution: 1440p (2560 X 1440)
  • Color: 16.7 million color possibilities
  • Refresh rate: 144Hz
  • Adjustable: Yes (up to 15°)
  • Color Scale: 85% NTSC/110% RGB
  • Response time: 4.8milliseconds
  • (Dynamic Contrast Ratio)DCR: 1000000:1
  • Free Sync feature included
  • Game Plus feature
  • 16:9 Widescreen
  • Ports: 2 X HDMI ports (single 1.4 and 2.0 ports)
  • Speakers included
What’s in the Box?
When you’ve received this package, you’ll surely be impressed by the covering’s overall black design. It’s an indication that you’re in for a real sturdy gaming session with this monitor.
If the covering thrills you, then wait till you get your package open! You’ll notice your monitor neatly packed with Styrofoam to prevent any damage during shipping.
The foam locks tightly, and you’ll be impressed at how well it protects your regardless of how many dents you find on your monitor’s packaging.
To crown the usefulness of this monitor set, it comes with accessories intact. Here’s a list of every accessory you’ll find in your package alongside your 27” monitor;
  • Power cable
  • Display port cable
  • Instructional manual
  • TV stand
The power cable is used in getting the monitor locked on to an available power source. The display port cable connects your new display to the console or processor of your choosing.
Also, the instructional manual of this set ensures you get it right when installing this display for the very first time. Finally, the TV stand is added to make it easier to mount your new display on a shelf or table anywhere around your room.
Design
This display comes in a white color, and is a perfect match for your game room irrespective of your chosen color scheme. If the color of this display’s covering doesn’t thrill you on its own, then it’s a fact that the other features will get you interested in a jiff.
Your monitor’s design is a sure fixture when you need the best from your gaming monitor. This monitor comes with a high quality QHD design which promotes easier viewing.
With this monitor’s build, you’ll find it easier to look through the screen while you enjoy your favorite games.
It’s no secret that curved monitors take up lesser space while providing more visibility, and that’s what users of this display are assured. It comes with a curved 1800R display for easier visibility.
Also, the control buttons for the display are located in the best possible area – the bottom left corner of the monitor’s base. Such a design makes operation easier while keeping the physical appearance of the monitor neater than you’d expect.
To make your games a lot more interesting, there’s something this display provides that sets it apart. Users get to access the Game-Plus crosshairs feature, ensuring targeting on your action games are worlds easier than before.
This monitor comes with an ideal set of features that gives it a plug-n-play status when it comes to your display choices. It can be used for more than gaming, as you could connect it to your processor.
But if you’re bent on using this monitor for gaming, then it can be easily used on any console that supports the HDMI ports provided.
Display
When you’re in need of a white curved monitor that boasts the finest, blitz displays, then this is your top choice. This monitor has 144Hz as its refresh rate, meaning that your games will not experience any glitches when seamless visibility matters the most.
Also, when color is an issue, 16.7 million colors from this monitor are more than capable to provide all your needs.
Screen resolutions have a lot to offer when HD gaming is what you seek. And there’s certainly the finest on this set with 1440p resolution. With this crisp display, your monitor doesn’t have to be too close to your eyes before you get a clear view.
For the finest immersion rates, the GN27dw comes with a 16:9 wide-screen feature, making it ideal for tweaking aspect ratios as you please.
This monitor is also designed to provide more than enough to keep your eyes healthy. With the anti-glare setting, you won’t experience any eye trouble even if you’ve been looking at the screen for a long time.
Also, this HD monitor comes with a light blue setting to help maintain your eyesight further.
Apart from your eyesight being properly maintained, this set has more features to boost gamers chances of winning at all times!
It comes with the AMD Free Sync tech which helps you game display achieve a more crisp status while lowering the chances of any dull or glitches from your images.
Value
The market value of this monitor isn’t what you’d expect. It comes as rather cheap compared to other brands with similar or even inferior features.
First of all, you’re assured the best customer service response on any unit of this display you purchase.
Also, you’ll have no fear of being misunderstood as the customer service team is fully-based in the US. With such a support team for your display, it’s a sure thing that your investment isn’t wasted.
Furthermore, the zero tolerance policy for dead LED monitors sets this unit apart. Your purchase is covered with a three-year limited warranty along with the dead LED cover for more value added to your buy.
Final Word
With a ton of favorable reviews about this display, it’s no secret why many gamers will gain the most from making this monitor their choice.
The monitor packs all the features that ensure your gaming sessions are hitch-free. These features are backed by a Samsung VA panel making sure your display remains crisp with so many exciting elements to boot!
With this curved monitor, your games will surely be better played, and it’ll be much easier to progress regardless of the genre you’re engaged in. Look through this set closely, as it’s surely the best fit for all your gaming needs right now!
Tweet
Share
Pin
Share
0 Shares
  • Type Your Question
    • What Evidence Do I Need to Hold My Landlord Liable For My Slip and Fall Injuries?
    • Unstoppable Creation for Instagram in 2021: Where to Get Content?
    • Beginner Tips on How to Make Music Videos in 2021
    • Honda still believes in the sedan, do you?
    • AI Making Lawyers Redundant: How Can Legal Education Change It?
    • Digital Learning from the Pupil’s Perspective: Is It Easier to Learn Remotely at Home?
    • File for Divorce Online – Already Possible Today
    • 5 Technologies That Will Amaze Every Student
    • How to Choose the Best Hardwood Flooring for Your Home?
  • best gaming mouse for fortnite
    Top 5 Best Gaming Mouse for Fortnite in 2020
  • Subscribe to Our Newsletter
    • Blog
    Mail Id: info@getassist.net
