How to Make Perfect Tableside Ordering in Your Restaurant
| Updated on June 18, 2026
Tableside ordering looks easy on paper. Put a QR code on the table, let guests order through their phones and watch the magic happen. The restaurants that truly benefit from tableside ordering are the ones that have thought through the details; those that simply bolt on a QR code without planning.
The difference between a tableside ordering system that genuinely improves your operation and one that creates new problems comes down to execution. Here is how to get it right, from the guest’s first scan to the final payment.
  • Exploring how to start with the guest experience, not the technology
  • Analyzing  why to design your menu for a phone screen, not a printed page
  • Assessing the plan for the moments tableside ordering does not cover
  • Evaluating why to keep the menu current in real time
Start With the Guest Experience, Not the Technology
The most common mistake restaurants make when implementing tableside ordering is choosing a platform first and figuring out the guest experience second.
This makes for systems that are technically functional but feel clunky from the customer’s side and that kills the entire point of the upgrade.
Before choosing any platform, walk through the experience as a guest would. You sit down.
What do you see on the table that tells you a QR menu is available? You scan the code. How long does it take to load, and what does the first screen look like? You browse the menu. Is it organized logically, with clear photos and descriptions? You decide on an item. How do you customize it if needed? You submit your order. What confirmation do you get that it went through? You finish your meal. How do you pay?
Every one of these moments is an opportunity for friction or for smoothness, and the platform you choose should make every step of that journey feel natural.
Design Your Menu for a Phone Screen, Not a Printed Page
A printed menu and a digital menu are different mediums, and treating a digital menu as just a PDF version of your printed menu produces a worse experience than either format on its own.
Printed menus often rely on :
  • dense layouts
  • small text
  • and minimal photography because space is limited and printing photos is expensive.
None of those constraints apply to a digital menu, and a menu that does not take advantage of that is missing an opportunity.
Every item should have a high-quality photo. Guests browsing on their phone make decisions partly based on what looks appealing, and a menu without photos is asking guests to imagine dishes they have never tried.
Dietary information and allergens should be visible without requiring a separate inquiry, which both serves guests with restrictions and reduces the questions your staff field during service.
The goal is a menu that feels like browsing a well-designed app, not like reading a scanned document.
Get the Ordering Flow Right
The actual ordering process, from selecting an item to submitting the order, is where many tableside systems either shine or fall apart. A few principles make a significant difference.
Modifiers and customizations need to be intuitive. If a guest wants to add a side, remove an ingredient or select a cooking preference, that should be an option clearly displayed at the time of item selection and not hidden in a separate menu or note field that the kitchen has to manually decipher.
The cart and order summary should be clear before submission. Guests should be able to see exactly what they have selected, with any modifications, and confirm everything is correct before sending it to the kitchen.
This reduces order errors significantly compared to verbal ordering, but only if the summary is genuinely clear.
For restaurants using Restaurant Order Management System with Digital QR Code from Menu Tiger, this entire flow is designed around these principles. The ordering process from browsing to cart to kitchen submission is built to feel natural on a phone, with modifiers handled cleanly within the item selection and clear confirmation once an order goes through.
Orders arrive at the kitchen tagged to the correct table without any manual entry required.
Plan for the Moments Tableside Ordering Does Not Cover
Even the best tableside ordering system does not eliminate the need for staff. It changes what staff are doing.
Knowing what still needs a human touch is vital to making the system work well, as opposed to creating gaps in service.
Greeting guests when they arrive still matters. Even if ordering happens digitally, the warmth of a welcome sets the tone for the entire visit. Checking in during the meal still matters. A server stopping by to ask how everything is going, refill water, or address any issues shows attentiveness that no app can replicate.
The restaurants that get the most value from tableside ordering use the time saved on order-taking to do more of these things, not less.
The technology should create space for better hospitality, not replace it.
Train Your Staff Before Guests Ever See It
A soft launch period, even just a few days, makes an enormous difference in how smoothly tableside ordering rolls out.
They need to know how to handle a table that prefers a traditional printed menu, which should always be available as an option. They need to understand what an order confirmation looks like from their side, so they can quickly identify and address any issues.
The goal of training is for the technology to become invisible to guests.
 When staff are confident and the system runs smoothly, guests experience tableside ordering as a natural part of the visit rather than a noticeable change in how the restaurant operates.
Keep the Menu Current in Real Time
One of the biggest advantages of a digital tableside menu is the ability to update it instantly, but that advantage only matters if someone actually uses it.
Build a habit of updating the menu in real time as items sell out, as daily specials change, and as prices are adjusted.
Real-time accuracy is part of what makes a tableside ordering system feel trustworthy to guests.
When the menu consistently matches what is actually available, guests develop confidence in the system, which makes them more likely to use it fully rather than defaulting to asking a server about every item.
Use the Data You Are Now Collecting
Every order placed through a tableside ordering system generates data that a handwritten ticket never could.
Reviewing this data regularly, even just weekly, helps identify opportunities. An item that is rarely ordered might need repositioning on the menu or removal altogether.
A modification that is requested constantly might indicate the default preparation should change. A particular time slot that consistently sees higher order volume might need additional staffing.
The restaurants getting the most out of tableside ordering treat the data it generates as an ongoing input into how the operation runs, not just a record of transactions.
Bring It All Together
Perfect tableside ordering is less about any single feature and more about how all the pieces fit together. The guest experience needs to feel smooth from scan to payment.
The menu needs to be designed for the medium it is presented on. Staff need to understand their evolving role and be ready to fill the gaps the technology does not cover. The menu needs to stay accurate in real time. And the data the system generates needs to actually inform decisions.
Manage your tableside ordering system from anywhere with the latest smartphone. Find the best models and prices at Priceka.
What is tableside ordering?
Tableside ordering is a restaurant service model where staff or guests place and manage food and drink orders directly at the dining table using handheld POS devices, tablets, or smartphones.
What are the benefits of tableside service?
By sending orders straight to the kitchen, tableside ordering eliminates the need for servers to manually relay information.
What are the 5 factors of service quality?
These five key pillars of service quality—tangibility, reliability, responsiveness, assurance, and empathy—are the building blocks of exceptional customer service.
What is the golden rule of customer service?
Despite all the noise and hype involving customer service these days, it truly boils down to one simple, age-old truth.
