A poorly equipped meeting room can cause so many inconveniences than you can imagine. Poor sound quality, display issues, missing tools, technical failures, and poor WiFi can make your client angry. Imagine you have booked a meeting room for a video conferencing but the video call drops in the middle of your conversation. Now you are fighting with the poor connectivity, how frustrating it is, right?
This article provides a troubleshooting checklist you should consider before booking any meeting room, including Wi-Fi setup, display checks, sound quality, and video conferencing.
Most meeting room tech issues aren’t just hardware failures. There are mismatches between what the room actually has and what the organiser assumed it had. A listing photo showing a big screen doesn’t tell you whether that screen supports wireless casting, whether the room has a dedicated conferencing camera, or whether the Wi-Fi is shared with fifty other tenants on the same floor. This creates a big confusion. The fix is the same one we’d give for any tech support ticket: verify details before you rely on them, not after.
If your meeting includes remote participants, the video conferencing setup is the single biggest point of failure. Before you finalise a booking, confirm these basics with the provider and, where possible, ask to test them on-site or via a walkthrough video.
**Ask the following questions:**
– Which platforms the room’s conferencing hardware actually supports (Zoom, Google Meet, Microsoft Teams) rather than just “video calls”
– Whether the camera and speaker are a proper conferencing bar or just a webcam clipped to a monitor
– Whether you can connect your own laptop via HDMI or USB-C as a backup if the built-in system misbehaves
– Whether someone on-site can restart or troubleshoot the AV system if it freezes during a call
A room that looks professional in photos can still have a camera angle that cuts off half the table or a microphone that only picks up the person sitting directly under it. Ask these questions, and if the provider can’t give a clear answer before you book, treat that as a warning sign, not a minor detail to sort out later.
Slow or unstable Wi-Fi is the most common complaint in shared meeting spaces, and it’s rarely mentioned in listings until it becomes a big problem. Ask specifically about connection speed, not just whether Wi-Fi is “available.”
**Questions worth asking before you book:**
– Is the meeting room on a dedicated network, or does it share bandwidth with the whole building?
– What’s the actual upload speed, since video calls depend more on upload than download?
– Is there a wired Ethernet option as a fallback for a large call or a file-heavy presentation?
– Does the provider have a way to reset the router if the connection drops mid-session?
If you’re running a client pitch or a hybrid meeting with multiple remote attendees, it’s worth doing a quick speed test on-site beforehand or asking the space to confirm bandwidth in writing. A room with strong Wi-Fi for one person checking email can still freeze the moment three laptops try to screen share at once.
Beyond the camera and the network, the rest of the AV setup deserves the same scrutiny you’d give any unfamiliar piece of equipment. A screen that can’t mirror your laptop, or a whiteboard that’s actually a glass panel with no markers in sight, will slow down your meeting at the worst possible moment.
**Before the day of your meeting, make sure to verify:**
– The display supports both wired and wireless screen sharing, and you know which cables to bring as backup
– Sound output should work for both in-room speakers and video call audio simultaneously
– Basic supplies are stocked: markers, an eraser, extension cords, and adapters for different laptop ports
– Someone is reachable on-site or by phone if any problem occurs during your meeting.
Once you’ve run through the checklist above, the last step is choosing a provider that treats meeting room tech as a standard feature rather than an upsell. This matters more in Singapore’s crowded coworking market, where two rooms can look identical in photos but differ wildly in how reliably the AV and internet can actually perform. Providers like The Work Project list their meeting rooms as video-conferencing-equipped by default, which is worth using as a benchmark when you’re comparing quotes: ask any space you’re considering whether their rooms meet that same standard before you commit to a booking.
It’s also worth asking what happens if something does go wrong. A provider that can give a clear answer and exactly who to call when something happens and how fast they will respond is much better than one that simply says the tech “usually works fine.” Treat that response the same way you’d treat a vague answer from tech support: politely, but with a follow-up question.
Bring a basic HDMI and USB-C adapter regardless of what the provider promises. It takes seconds to pack and saves you from being stuck if the room’s cable is missing or damaged.
Ask in advance whether the room has a wired Ethernet backup or a mobile hotspot on standby. A five-minute outage is manageable if you know the fallback plan before it happens, not while your client is waiting.
Usually, yes, if the alternative is troubleshooting hardware in front of a client. The cost difference between a basic room and a properly video-conferencing-equipped one is often small compared to the time lost fixing avoidable tech issues mid-meeting.
