HSR Relic Sets 3.8: What You Should Actually Farm for Every New Character
| Updated on February 3, 2026
Lingsha, Sunday, The Dahlia, Fugue, and other new and interesting characters are now available in version 3.8. Since their kits actually require certain stats to function, you must prepare the appropriate equipment to prevent these units from feeling weak.
To ensure you don’t waste your Trailblaze Power on the wrong caverns, this guide breaks down the key choices for HSR relic sets 3.8. Obtaining flawless stats can be quite difficult, and while pursuing god-tier rolls, you may run out of resources.
If you ever need to top up Oneiric Shards for more pulls or stamina refreshes, just check out a game top-up site, BuffBuff, for your game top-up needs. Now, let’s see exactly what you need to farm to maximize every new character’s potential through this blog post.
  • Uncovering the healing attributes of Lingisha
  • Exploring the damaging abilities of Sunday
  • Discovering core elements of Fague and Firefly
  • Understading thunder powers of Aglaea
Lingsha
Lingsha is basically your go-to break healer, so you should max out her Break Effect using the Iron Cavalry set. The best option among the relic sets HSR 3.8 brought us gives you defense ignore based on your break stats. You should try to hit at least 250% Break Effect to get the full benefits from these HSR relic sets 3.8 options.
For her ornaments, the Forge of the Kalpagni Lantern is the top pick because it gives speed and a huge Break Effect boost. Since Lingsha hits everyone and breaks fire weakness constantly, this set from the Honkai Star Rail relic sets 3.8 list guarantees high uptime. You get free stats that directly help her healing and damage without any complicated conditions.
This remains a premier set, as it is essential for Break Effect teams and provides massive damage bonuses to Super Break compositions, which are critical for the new 3.8 meta.
Sunday
Sunday is amazing for boosting Crit Damage, making the Relieved Ordeal set his absolute best slot for team damage. This specific set among HSR relic sets 3.8 boosts the target’s Crit Damage whenever Sunday uses his skill on them. You can stack this effect super fast with the right relic sets HSR 3.8 pieces to turn your DPS into a total beast.
Lushaka is likely the most consistent ornament set for him because it gives Energy Regeneration and an Attack buff. Energy is super important for Sunday, and this set fits perfectly into the Honkai Star Rail relic sets 3.8 support meta. You ensure he gets his Ultimate back faster while passively boosting your main damage dealer.
The Dahlia
The Dahlia, or Constance, is a break-focused monster who really needs the Iron Cavalry set for big damage. This set is a staple in HSR relic sets 3.8 discussions for anyone dealing Super Break damage because it ignores defense. You want high Break Effect stats to ensure she converts toughness reduction into massive numbers with these relic sets HSR 3.8 items.
You should strictly farm the Forge of the Kalpagni Lantern set for The Dahlia to max out her speed and break potential. This set dominates the HSR relic sets 3.8 discussion because she implants fire weakness easily for permanent uptime. The extra speed helps her reach high breakpoints, while the Break Effect boost directly scales her damage.
Fugue
Fugue needs a ton of Break Effect, making the Iron Cavalry set her best bet for personal damage. Just like other break units in the Honkai Star Rail relic sets 3.8 roster, she benefits a lot from the defense ignore mechanics. You need to ensure her Break Effect reaches around 220% to really use her traces, and these HSR relic sets 3.8 potentials.
If you just care about speed and support, a mix of two-piece speed and two-piece break sets works perfectly fine. This simple approach allows you to use various relic sets HSR 3.8 offers to hit the 160+ speed threshold easily. Speed is often more valuable than raw damage here, so she can apply debuffs before the enemy moves.
Firefly
Firefly is still the queen of the meta, and her best set remains the Iron Cavalry due to its defense ignore. Nothing in the Honkai Star Rail relic sets 3.8 update has beaten this set, as it works perfectly with her Super Break mechanics. You should aim for 360% Break Effect in battle to get the absolute most out of these HSR relic sets 3.8 bonuses.
The Forge of the Kalpagni Lantern is the only ornament set you should even look at for a serious Firefly build. Since she implants fire weakness herself, she activates the HSR relic sets 3.8 bonus effect with 100% consistency. You can rely on the free speed to help her hit the 210 speed threshold in her ultimate form.
Aglaea
Aglaea is a bit picky with her gear, and her best setup usually involves a Lightning damage orb and attack percent substats. Her synergy with Sunday is non-negotiable, so you must select your relic sets HSR 3.8 pieces to match his buffs. You can manage your Honkai Star Rail relic sets 3.8 choices to maximize her “Supreme Stance” so that she acts twice before Sunday acts once..
You have two main build paths for her, choosing between a Base Speed build or a Double-Speed build. The right choice depends on whether you can farm high-speed substats from HSR relic sets 3.8 caverns to reach specific breakpoints. Without proper speed tuning, you will lose the massive energy and speed benefits that her optimal team composition provides.
This update clearly shifts the meta toward high-speed Break Effect teams, so you really need to adapt your farming plan. You will find that most new characters rely heavily on the HSR relic sets 3.8 domains like Iron Cavalry and Forge. Prioritizing these caverns ensures you get the most value for your Trailblaze Power in the long run.
You now have all the info you need to build these powerhouse characters with the best relic sets HSR 3.8 has to offer. Before you get back into the game, make sure to check the latest HSR redeem codes to grab some extra freebies. Good luck with your relic rolls and enjoy the new content in version 3.8!
What is considered a good relic in HSR?
If you get 3 rolls into effective substats.
Who will rerun in 3.8 HSR?
The Dahlia (Constance), a brand new 5-star Fire Nihility character will debut in the first half of HSR 3.8 banner.
What are level 70 relic weapons?
Eureka Weapons are the level 70 Relic Weapons for Stormbloo
Sudhanyo Chatterjee
