9 Ideas to Transform Your kitchen on a Budget
| Updated on November 3, 2023
Do Mississauga kitchen renovations mean you have to stick to the trends? Not at all! If you are up for transforming your kitchen layout, there are several directions for you to go in. And by adding subtle touches you can make your kitchen appear more modern.
For those who don’t have a huge budget, transforming the kitchen’s layout doesn’t have to cost an arm and a leg. With simple tactics, you can update your kitchen and make it feel homey again. So roll up your sleeves for some easy DIY ideas to change the layout of your Kitchen:
Choose a Triangular Layout
If you are designing your kitchen from scratch, go for a triangular kitchen. There will be three points of this layout – cooking, preparation, and food storage.
The idea of this layout is to keep these functions in close proximity to another so that you may run the kitchen effectively. Such a layout is perfect for those with mobility issues or those who don’t want to bend much to grab the essential items.
Reduce Traffic
Hands down, the kitchen is one of the most high-traffic areas of the house. If yours is filled with mail, coats, and backpacks (in case you have kids), this is the first thing that needs to be sorted.
Get rid of all the traffic from the kitchen. Create a mudroom for all this clutter. Once the mess is out, you can then focus on other things.
Use a Dash of Art
Whether big or small, art can transform any living space. Why not use it for transforming your kitchen? It could be a hand painting or small pictures, with a touch of creativity, make it an attractive space.
In most houses, the kitchen is the heart of the home. Get your family to create some fun DIY art. You can also place pictures of your family.
Another idea is to install a chalkboard wall and write your favorite quotes there. You may also include a to-do list.
Go for Vertical Storage
Instead of focusing your time and energy on creating cabinet and drawer storage, choose convenient wall storage. It’s a great way to store small appliances, pantry items, baking accessories, and more all conveniently in one location.
Your options in vertical storage include wall hooks, open shelves, overhead pot racks, etc. This type of storage is not just convenient, it also helps you stock the right stuff and adds to the aesthetics of your kitchen’s layout.
Change the Flooring
Flooring can make or break the look of your entire kitchen. Switch from the traditional linoleum or vinyl flooring to wood, stone, or tiles. I know, these materials can be expensive. But they add value to your home. This investment will eventually pay off if you plan on selling your house in the future.
Install New Lights
Don’t forget the lighting. It may be an afterthought for some homeowners but it’s essential if you want to make your kitchen versatile.
An overhead ambient lighting fixture on top of the table is enough to add modern illumination. Or you can install a simmer switch to make the kitchen more entertaining while you cook.
You can also install pendant lighting over the kitchen island or rope lights under the cabinets to illuminate the countertops. Check out what kitchen lights are available in your local hardware store to make your kitchen space shine.
Paint the Cabinets
If you don’t have to budget to have the cabinets renovation, then simply have them painted. It’s an easy and cheap way to create a fresh look. For instance, if you have a cream background, choose any trending color for the cabinets. Before painting the cabinets, make sure to prime them first for lasting results.
Add Paneling
Another nice and simple way to give your kitchen a fresh look is to panel the walls. You can even do it yourself over the weekend if you don’t have a huge kitchen.
Install a Pan Rack
A ceiling rack is a great option if you are short on storage. Install a ceiling rack above your store and hand the bulky pans and utensils there. To soften the look, decorate the kitchen it rustic basket, and some dried flowers.
These small changes don’t require a huge budget nor do they require the services of an expensive remodeler. Take help from the Internet to find simple DIY tutorials on these transformation ideas and completely alter the way your kitchen looks. We hope these tips help you to improve your home, you can keep learning more remodeling tips on blogs like Hardie Boys.
