Although a study room has always been a part of traditional homes, post-pandemic, the importance, and necessity of one have been emphasized further. While every house may not necessarily be able to accommodate a separate room altogether for studying or working purposes, a designated study area is a must. This can be assigned either in a quiet corner of the living room or the bedroom. The study area requires specific furniture set to make work and study easier. An essential element of the is worth checking out.
Although study tables are available in a variety of materials, the most commonly used study table is the wooden study table. The wooden study table is definitely a better option than other study tables made of materials like plastic, metal, and stone. Wooden study tables are not only abundant in a variety of designs and colors but also have unique features which are not seen in other study tables.
Why Would a Wooden Study Table Help You Study Better?
Amongst the top tips for studying at home is the requirement of an appropriate study table. This is because a decent study environment is necessary to be productive and avoid distractions. All their books and stationery should be kept in one place and should be easily accessible while studying. Some students are often seen studying on the couch in the living room or on their bed. Studying in such a manner is not helpful and useful. To help one study better, they need to be comfortable while studying. This is achieved by proper selection of the study table. The best wooden study table has the following qualities which can help you study better:
Excellent Durability:
Solid wood is naturally a long-lasting and durable material that can last for years with little or no maintenance requirements.
Smooth, Flat Surface:
Wooden tables are flat and smooth in nature and do not cause any friction while reading, writing, or drawing on their surface.
Easy to Clean:
Unlike tables made of other materials, a wooden table is fairly easy to clean and maintain. It does not accumulate any stains and spills nor retains any dust particles. A simple wipe with a sponge cloth is enough to clean it.
Natural Insulator:
Wood does not conduct heat; therefore, it acts as a natural insulator, and the wooden study tables are cool while using, regardless of the weather.
Choosing the Right Study Table
So how do we decide which study table is the most appropriate for our needs? We have compiled below a list of factors that should be considered while buying a home and office study table
Size:
It is important to determine the size of the study table with respect to the available space in the study before making a purchase. If you are purchasing a study table for kids to study and complete their homework, then you can opt for a single large table sufficient to accommodate their stationery and books. If you are short on space, you can also choose the wall-mounted folding study table, which is very convenient for kids and adults. If you are looking for a work-from-home setup, you need to buy a study table for adults that can accommodate a desk lamp, laptop or desktop, a keyboard, a mouse, and some extra space to make notes.
Style:
Your study table design and style should complement the rest of the furniture in the room. For instance, if the rest of the furniture in the room is made of dark brown polished wood, choose a similar colored study table.
Storage:
Most study tables are designed to store basic stationery and accessories in adjacent drawers beneath the table. However, if you require more storage, you can opt for study tables with open drawers to store books and additional drawers to store other stationery, files, and work-related items.
Ergonomics:
Make sure that the study table you buy is of appropriate height with respect to the user. A very high desk is not suitable for kids as it can lead to poor posture, leading to back pain, and inattentiveness while studying. The same rule applies to adults too. You must make sure that you can rest your elbows on the study table comfortably. While seated, The table should ideally be of a height between 26 and 30 inches to ensure a comfortable seating posture. Always verify the appropriate height of the table by making the user sit at the table.
Budget:
The price of study tables can vary depending upon the size, design, material, and brand. Typically, the price for a study table starts at INR 3000 and can go higher based on comfort. Set your budget for the study table beforehand to filter items while browsing and avoid confusion while purchasing.
We hope our curated guide will help you choose the right study table for your needs. Do let us know how this guide helped you in your shopping experience.
